Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 01-14-2009, 06:28   #1 (permalink)
Member: 200475
problem using S1 flasher & unlocker to unlock T303
Hi
I have tried UC10 cable and FTDI cable , all gone through and said "done" but the phone still said " insert correct sim card"
pls clarify.
___________________________________
  16:22:00  SE S1 Flasher & Unlocker v1.00 by Cruiser Team
  16:22:00  Initializing...
! 16:22:00  1. Choose the phone model
! 16:22:00  2. For flashing, select flash files and additional options
! 16:22:00  3. Double-click on the appropriate device (serial cable)
  16:22:14  Connecting via Generic FTDI Cable (COM12)…
  16:22:14  Device driver version: 2.0.0.0
  16:22:14  Device driver date: 5-19-2006
! 16:22:14  Connect the phone now
  16:22:14  Connecting to the baseband CPU...
  16:22:22  Entering baseband CPU service mode...
  16:22:23  IMEI: 35899402442598
  16:22:23  Phone type: T303
  16:22:23  CDA info: 1210-4475 R11A
  16:22:23  Phone software: 1209-8242 R2CC001
  16:22:23  Sending loader...
  16:22:42  Reading TA…
  16:22:43  Turning off the phone...
  16:22:43  Done.
! 16:22:43  Please disconnect battery and cable from the phone!
Old 01-14-2009, 15:46   #2 (permalink)
adriano II's Avatar
Member: 155242
also i have this problem
and when i chose For unsigned mode, choose to unlock the phone (by patch).
get error
Old 01-14-2009, 17:27   #3 (permalink)
Member: 670274
S1 Locosto unlock
Hi,
To unlock the phone, choose "Unsigned mode" and check the "Unlock" box.
If an error occurs, please post the error log, otherwise we cannot help.
Regards
GLaDOS
Old 01-14-2009, 20:20   #4 (permalink)
ruko's Avatar
Member: 205178
Unsigned mode and unlock marked
  21:19:00  SE S1 Flasher & Unlocker v1.00 by Cruiser Team
  21:19:00  Initializing...
! 21:19:00  1. Choose the phone model
! 21:19:00  2. For flashing, select flash files and additional options
! 21:19:00  3. Double-click on the appropriate device (serial cable)
  21:19:08  Connecting via Generic FTDI Cable (COM6)…
  21:19:08  Device driver version: 1.0.2176.0
  21:19:08  Device driver date: 12-12-2005
! 21:19:08  Connect the phone now
  21:19:08  Connecting to the baseband CPU...
E 21:19:53  Error: 0xE1E2479D
E 21:19:53  Error: 0x06EB86E0
E 21:19:53  Error: 0x7E23C4B3
E 21:19:53  Error: 0x275F2EE0
E 21:19:53  Failed!
! 21:19:53  Please disconnect battery and cable from the phone!
! 21:19:53  To report errors right-click this window
Old 01-14-2009, 20:28   #5 (permalink)
ruko's Avatar
Member: 205178
Signed mode
  21:21:35  SE S1 Flasher & Unlocker v1.00 by Cruiser Team
  21:21:35  Initializing...
! 21:21:35  1. Choose the phone model
! 21:21:35  2. For flashing, select flash files and additional options
! 21:21:35  3. Double-click on the appropriate device (serial cable)
  21:21:46  Connecting via Generic FTDI Cable (COM6)…
  21:21:46  Device driver version: 1.0.2176.0
  21:21:46  Device driver date: 12-12-2005
! 21:21:46  Connect the phone now
  21:21:46  Connecting to the baseband CPU...
  21:22:00  Entering baseband CPU service mode...
  21:22:01  IMEI: 35899402656864
  21:22:01  Phone type: T303
  21:22:01  CDA info: 1210-3362 R16A
  21:22:01  Phone software: 1210-4093 R2CA005
  21:22:01  Sending loader...
  21:22:20  Reading TA…
  21:22:21  About to flash 17 MB of data…
  21:22:21  Writing files…
  21:27:07  Turning off the phone...
  21:27:07  Done.
! 21:27:07  Please disconnect battery and cable from the phone!
I flash with T303_FW-LP_1209-8211_IBERIA_R2BB012_RED.s1fl, and the phone is branded yet!!
Thanks
Old 01-15-2009, 00:10   #6 (permalink)
Member: 200475
Originally Posted by ruko View Post
Signed mode
  21:27:07  Done.
Thanks
Hi
Yes. you are right. I got the same log for unlocking T303. I have tried on 3 different , the same problem. Is there any difference if the phone has different s/w version etc .. Because I have been using Smart-clip before, and some phones cannot be unlocked and some people recommend it is the s/w version issue.
Can you clarify ?
tks
SS
Old 01-15-2009, 13:27   #7 (permalink)
Member: 670274
E 21:19:53  Failed!
Hi,
The error 0x7E23C4B3 means a security bypass problem. If it occurs permanently (retries don't help), then it's caused by new phone hardware revision, which is not supported in the "Unsigned mode".
We are preparing an unlock solution for those new chips.
Regards
GLaDOS
Old 01-15-2009, 14:57   #8 (permalink)
Member: 52091
Thanks Glados,
I´m test this phone ant flash in signed mode work ok, but unlock in unsigned mode not work... Update asap please.
  15:55:48  SE S1 Flasher & Unlocker v1.00 by Cruiser Team
  15:55:48  Initializing...
! 15:55:48  1. Choose the phone model
! 15:55:48  2. For flashing, select flash files and additional options
! 15:55:48  3. Double-click on the appropriate device (serial cable)
  15:56:08  Connecting via Generic FTDI Cable (COM6)…
  15:56:08  Device driver version: 2.2.4.0
  15:56:08  Device driver date: 6-27-2007
! 15:56:08  Connect the phone now
  15:56:08  Connecting to the baseband CPU...
E 15:56:54  Error: 0x06EB86E0
E 15:56:54  Error: 0x7E23C4B3
E 15:56:54  Error: 0x275F2EE0
E 15:56:54  Failed!
! 15:56:54  Please disconnect battery and cable from the phone!
! 15:56:54  To report errors right-click this window
Thanks
jalbi69
Old 01-15-2009, 15:12   #9 (permalink)
Member: 670274
Signed mode
  21:27:07  Done.
Thanks
To debrand a phone, an important thing is to flash a customization (CDA) file. This will not unlock the phone, of course.
Regards
GLaDOS
Old 01-15-2009, 15:43   #10 (permalink)
emilkawa's Avatar
Member: 112498
in my t303 is:
  16:38:17  SE S1 Flasher & Unlocker v1.00 by Cruiser Team
  16:38:17  Initializing...
! 16:38:17  1. Choose the phone model
! 16:38:17  2. For flashing, select flash files and additional options
! 16:38:17  3. Double-click on the appropriate device (serial cable)
  16:38:26  Connecting via Cruiser UC-10 Cable (COM11)…
  16:38:26  Device driver version: 1.0.2176.0
  16:38:26  Device driver date: 12-12-2005
! 16:38:26  Connect the phone now
  16:38:27  Connecting to the baseband CPU...
  16:38:43  Reading TA…
  16:38:50  Reading EROM…
  16:38:53  Unlocking…
  16:39:06  The phone has been successfully unlocked.
  16:39:06  Turning off the phone...
  16:39:06  Done.
! 16:39:06  Please disconnect battery and cable from the phone!
Thanks cruiser team.
Emilkawa
Old 01-16-2009, 00:26   #11 (permalink)
Member: 200475
Originally Posted by emilkawa View Post
in my t303 is:
  16:38:53  Unlocking…
  16:39:06  Done.
Emilkawa
So, your phone said "insert correct sim " as well ?
SS
Old 01-16-2009, 10:27   #12 (permalink)
Member: 145234
T303
11:22:52 SE S1 Flasher & Unlocker v1.00 by Cruiser Team
11:22:52 Initializing...
! 11:22:53 1. Choose the phone model
! 11:22:53 2. For flashing, select flash files and additional options
! 11:22:53 3. Double-click on the appropriate device (serial cable)
11:23:03 Connecting via Generic FTDI Cable (COM73)…
11:23:03 Device driver version: 2.0.0.0
11:23:03 Device driver date: 5-19-2006
! 11:23:03 Connect the phone now
11:23:03 Connecting to the baseband CPU...
E 11:23:48 Error: 0xE1E2479D
E 11:23:48 Error: 0x06EB86E0
E 11:23:48 Error: 0x7E23C4B3
E 11:23:48 Error: 0x275F2EE0
E 11:23:48 Failed!
! 11:23:48 Please disconnect battery and cable from the phone!
! 11:23:48 To report errors right-click this window
Old 01-16-2009, 11:00   #13 (permalink)
Member: 145234
T303 Any solution????
Old 01-16-2009, 11:12   #14 (permalink)
FilipLudvik's Avatar
Member: 135110
E 11:23:48 Error: 0x7E23C4B3 means new HW detected as Glados said. you have to wait until new update.
Old 01-16-2009, 11:17   #15 (permalink)
Member: 257142
Wink
This platform have a new chipset not supported with any tool? But just with log in setool
.: New release: S1 Flasher & Unlocker v2.05 - Instant S1 unlock in many languages :. Mizar Cruiser Suite 71 09-16-2009 05:59
.: Crusier Suite S1 Flasher & Unlocker: Instant unlock of all S1, no more waiting :. Mizar Main Sales Section 0 05-26-2009 10:33
.: Crusier Suite S1 Flasher & Unlocker: Instant unlock of all S1, no more waiting :. Mizar Main Sales Section 0 03-27-2009 13:28
.: New release: S1 Flasher & Unlocker v2.05 - Instant S1 unlock, GUI in many langs :. Mizar GSM News & Updates 0 03-25-2009 19:38
.: CruiserSuite S1 Flasher & Unlocker v2.03 released - Instant S1 unlock supported :. Mizar Cruiser Suite 69 03-23-2009 19:35
Page generated in 0.88583 seconds with 11 queries
