11-25-2007, 00:55 | #1 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 394644 Status: Offline Thanks Meter: 0 | probleme with W580 cruiser 13.01 ? Version 13.01 ready! Do NOT connect the phone at this time! [ --- Attach to Phone --- ] Connecting via SEMC DCU-60... Connect the phone while holding its C button! USB connection established. Baseband chip ID: 0x9900 Protocol version: 3.1 Booting via EROM... Sony Ericsson phone detected. Phone CID: 52 Phone color: Red EROM version: R3A022 Trying CID52 recovery applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 0s Initializing phone hardware... Applet ID: 061220 1711 NPA4_CXC1329130_DB2020_... Flash manufacturer: Intel Flash ID: 0x897E OTP Security Level: 1 (Retail) OTP CID: 51 Phone CID: 52 Phone color: Red Sending applet... Applet ID: 061205 1523 HANCXC9876543210_DB2020... Sending applet... Applet ID: 061201 1314 HANCXC1329129_DB2020_FL... RSA protection state cannot be determined for this CID. Phone hardware initialized OK [ --- Unlock RSA --- ] Preparing to program flash... Programming flash... Time: 00:00:21 Flash process done. Preparing to program flash... Programming flash... Time: 00:00:02 Flash process done. Sending CS applet... Applet ID: 070410 1557 HANCXC1250562_DB2020_CS... Initializing CS applet... Starting up GDFS service... Starting up filesystem, please wait... Removing RSA lock... Restarting phone... Connect the phone while holding its C button! Sending applet... Sending applet prologue... Sending applet body... Applet ID: 061220 1711 NPA4_CXC1329130_DB2020_... Sending applet... Applet ID: 061201 1314 HANCXC1329129_DB2020_FL... Preparing to program flash... Programming flash... Time: 00:03:19 Flash process done. Please disconnect the phone and reinsert its battery! Connect the phone while holding its C button! Failed! [ --- Turn off Phone --- ] Turning off phone... Phone automatically detached. [ --- Attach to Phone --- ] Connecting via SEMC DCU-60... Connect the phone while holding its C button! USB connection established. Baseband chip ID: 0x9900 Protocol version: 3.1 Booting via EROM... Sony Ericsson phone detected. Phone CID: 52 Phone color: Red EROM version: R3A022 Trying CID52 recovery applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 0s Initializing phone hardware... Applet ID: 061220 1711 NPA4_CXC1329130_DB2020_... Flash manufacturer: Intel Flash ID: 0x897E OTP Security Level: 1 (Retail) OTP CID: 51 Phone CID: 52 Phone color: Red Sending applet... Applet ID: 061205 1523 HANCXC9876543210_DB2020... Sending applet... Applet ID: 061201 1314 HANCXC1329129_DB2020_FL... RSA protection state cannot be determined for this CID. Phone hardware initialized OK [ --- Unlock RSA --- ] Preparing to program flash... Programming flash... Time: 00:00:21 Flash process done. Preparing to program flash... Programming flash... Time: 00:00:02 Flash process done. Sending CS applet... Applet ID: 070410 1557 HANCXC1250562_DB2020_CS... Initializing CS applet... Starting up GDFS service... Starting up filesystem, please wait... Removing RSA lock... Restarting phone... Connect the phone while holding its C button! Sending applet... Sending applet prologue... Sending applet body... Applet ID: 061220 1711 NPA4_CXC1329130_DB2020_... Sending applet... Applet ID: 061201 1314 HANCXC1329129_DB2020_FL... Preparing to program flash... Programming flash... Time: 00:03:19 Flash process done. Please disconnect the phone and reinsert its battery! Connect the phone while holding its C button! Waiting for acknowledge... Please disconnect the phone and reinsert its battery! Connect the phone while holding its C button! Sending applet prologue... Sending applet body... Waiting for acknowledge... Applet ID: 070516 0311 CRU4_CXC1329130_DB2020_... Sending applet... Applet ID: 070516 0201 CRUCXC1329134_DB2020_PR... Done. [ --- Flash Main Firmware --- ] Flash file: "W580i_CXC1123362_Generic_R6BC002_Red52.cw58sw " Waiting for flash file to load... Preparing to program flash... Programming flash... Time: 00:03:47 Flash process done. [ --- Flash Raw File System --- ] Flash file: "W580i_CXC1123364_Europe1_R6BC002_Red52.cw58fs " Waiting for flash file to load... Preparing to program flash... Programming flash... Please remove battery from the phone... Final flash verification failed! Script error: Flash error [13.01.78] what is about ???? |
11-25-2007, 00:59 | #2 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 25671 Status: Offline Thanks Meter: 719 | all is about you don't follow guide... check www.cruiserlogs.net/guide before you will try again, first get phone to working state by simply flashing ARM+FS and customizing. |
11-25-2007, 01:05 | #3 (permalink) |
Member: 394644 Status: Offline Thanks Meter: 0 | i was following this http://forum.gsmhosting.com/vbb/showthread.php?t=469511 it work for DOUHAL ??? |
11-25-2007, 01:21 | #5 (permalink) | |
Member: 394644 Status: Offline Thanks Meter: 0 | Quote:
you are susceptible my friend i am in process i have cruiserlogs . net opened and waiting in cruiser 13.01 that the correct process to be finished ... bay the way you have good advice every time | |
11-29-2007, 20:44 | #6 (permalink) | |
Junior Member Join Date: Mar 2005 Age: 70
Member: 126368 Status: Offline Thanks Meter: 0 | Similar problem with W580i and Cruiser 13.01 Quote:
See log below, is there a way to fix this? System diagnostics passed. Version 13.01 ready! Do NOT connect the phone at this time! [ --- Attach to Phone --- ] Connecting via SEMC DCU-60... Connect the phone while holding its C button! USB connection established. Baseband chip ID: 0x9900 Protocol version: 3.1 Booting via EROM... Sony Ericsson phone detected. Phone CID: 52 Phone color: Red EROM version: R3A022 Trying CID52 recovery applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 0s Initializing phone hardware... Applet ID: 061220 1711 NPA4_CXC1329130_DB2020_... Flash manufacturer: Intel Flash ID: 0x897E OTP Security Level: 1 (Retail) OTP CID: 51 Phone CID: 52 Phone color: Red Sending applet... Applet ID: 061205 1523 HANCXC9876543210_DB2020... Sending applet... Applet ID: 061201 1314 HANCXC1329129_DB2020_FL... RSA protection state cannot be determined for this CID. Phone hardware initialized OK [ --- Flash Raw File System --- ] Flash file: "W580a_CXC1123364_America1_R6BC002_Red52.cw58f s" Waiting for flash file to load... Preparing to program flash... Programming flash... Time: 00:01:42 Flash process done. [ --- Unlock RSA --- ] Preparing to program flash... Programming flash... Time: 00:00:21 Flash process done. Preparing to program flash... Programming flash... Time: 00:00:02 Flash process done. Sending CS applet... Applet ID: 070410 1557 HANCXC1250562_DB2020_CS... Initializing CS applet... Starting up GDFS service... Starting up filesystem, please wait... Removing RSA lock... Restarting phone... Connect the phone while holding its C button! Failed! [ --- Turn off Phone --- ] Turning off phone... Phone automatically detached. [ --- Attach to Phone --- ] Connecting via SEMC DCU-60... Connect the phone while holding its C button! USB connection established. Baseband chip ID: 0x9900 Protocol version: 3.1 Booting via EROM... Sony Ericsson phone detected. Phone CID: 52 Phone color: Red EROM version: R3A022 Trying CID52 recovery applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 0s Initializing phone hardware... Applet ID: 061220 1711 NPA4_CXC1329130_DB2020_... Flash manufacturer: Intel Flash ID: 0x897E OTP Security Level: 1 (Retail) OTP CID: 51 Phone CID: 52 Phone color: Red Sending applet... Applet ID: 061205 1523 HANCXC9876543210_DB2020... Sending applet... Applet ID: 061201 1314 HANCXC1329129_DB2020_FL... RSA protection state cannot be determined for this CID. Phone hardware initialized OK [ --- Unlock RSA --- ] Preparing to program flash... Programming flash... Time: 00:00:20 Flash process done. Preparing to program flash... Programming flash... Time: 00:00:02 Flash process done. Sending CS applet... Applet ID: 070410 1557 HANCXC1250562_DB2020_CS... Initializing CS applet... Starting up GDFS service... Starting up filesystem, please wait... Removing RSA lock... Restarting phone... Connect the phone while holding its C button! Failed! | |
Problem with Sagem EG 13.9 and 13.8... | MACKIE | SAGEM JTAG UNLOCKER | 5 | 01-11-2010 16:05 |
CRUISER 13.01 Could not retrieve cable identifier! | dibwe | Cruiser Suite | 1 | 12-25-2007 08:27 |
..:: BIG NEWS - Cruiser 13.01 - Standalone DB2020 CID52 unlock for free !!! ::.. | Mizar | Main Sales Section | 0 | 11-26-2007 11:12 |
To cruiser team problem with my cruiser pro2 | ami236 | Cruiser Suite | 10 | 10-27-2006 20:46 |
SOUND PROBLEM WITH MY S25 V14.01 | Dead_S25 | x1x to x45/x50 | 0 | 03-07-2001 08:28 |
