Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 03-07-2006, 16:50   #1 (permalink)
odinb's Avatar
Member: 76964
Thanks Meter: 2
Problems connecting to W600i with UC-10
Hi!
Have a W600i in my possession that I need to unlock.
Trying to connect to the phone is not possible with my UC-10 cables.
When cruiser says powering on phone, the phone starts charging, and nothing else happens. Have tried different USB-ports, one on a hub with external power, and also directly in the computer. Even tried a second computer, but phone never enters bootstrap, it just starts charging.
Battery on the phone is almost full.
Have tried the "jumpstart" theory, by inserting battery when Cruiser says:
"Connecting via UC-10 Universal Cable...
Powering on the phone..." but this is as far as I get. It just sits at that point, charging the phone.
Have tried both v8.11 and v9.22, same result.
Is this a cable problem, or am I doing something wrong?
The connector is clean, since this is an almost new phone.
Would external power on the clips make a difference?
If so, what voltages are recommended 3v, 5v, 9v?
These Cruiser cable works with other Ericsson phones for the regular connector (the one that is on almost all phones, i.e. T610, z500 a.s.o), so if it is a cable problem, it must be the "k750"-part of the connector that is bad, since I have not used that piece previously with any phone.
Old 03-07-2006, 19:37   #2 (permalink)
Member: 210229
Thanks Meter: 12
Hello, just read your T610 post too.
I get these problems from time to time and reboot pc might help.
T610 part is probably firmware version - early CID27/29 later firmware usually boots quite quick - ie, same phone but firmware upgraded.
Also, is phone new or just new to you and therefor tampered with previously (probably not but just a thought).
Sorry I don't have a real solution - maybe Cruiser is getting too big and needs to branch off into CID groups...
...early phone CID's to 36 and later phones CIDs 36 up.
Don't know though - but that might help in trouble shooting even for Lead
BR stu
Old 03-07-2006, 20:12   #3 (permalink)
Nizze's Avatar
Member: 79724
Thanks Meter: 15
Originally Posted by odinb
Hi!
I usually use 9V battery.
But it is recommended to use 3V
But I find it easier to attach to phone using 9V
Nizze
Old 03-07-2006, 20:18   #4 (permalink)
odinb's Avatar
Member: 76964
Thanks Meter: 2
Well, the phone (W600i) is supposedly untampered, at least according to the owner (and he is trustworthy, at least to my knwledge). It powers on, and works normally except for this problem with not wanting to boot into bootstrap. A reboot did not change anything.
It is very new, date of manufacturing is 06W01 and it is Cingular branded/locked.
For the T610 issue (http://forum.gsmhosting.com/vbb/show....php?t=277433), rebooting did not help on that one either, and I booted it using EMMA-card, and it is now unbranded/unlocked.
I can probably find another T-mobile branded phone, if needed. I think it might have to do with the firmware being really old, it does not have RSA on it.
Old 03-07-2006, 20:35   #5 (permalink)
odinb's Avatar
Member: 76964
Thanks Meter: 2
Nizze
Stupid question, but red crocodile goes on positive + on 9V battery, right?
Better to be safe than sorry!
Do I leave the battery on throughout the procedure, or only during boot?
Old 03-07-2006, 20:38   #6 (permalink)
Nizze's Avatar
Member: 79724
Thanks Meter: 15
Yes red on +
You need to have battery on all time you work with phone.
Nizze
Old 03-07-2006, 20:45   #7 (permalink)
odinb's Avatar
Member: 76964
Thanks Meter: 2
Tackar så mycket för denna info!
Varför leder www.mobilteknik till ett företag i Älvsbyn? Din signatur säger ju Solna.
Will try when I get home tonight.
Thanks!
Old 03-07-2006, 21:16   #8 (permalink)
Nizze's Avatar
Member: 79724
Thanks Meter: 15
Thanks!
You have wrong address.
www.solnamobilteknik.se
Nizze
Old 03-07-2006, 23:52   #9 (permalink)
odinb's Avatar
Member: 76964
Thanks Meter: 2
The 9v battery sure did the trick! Thanks Nizze!
Phone now brown and unlocked!
Is there any standard FW available for this phone (non-branded), as I can only find Cingular FW on the support pages.
Old 03-08-2006, 06:19   #10 (permalink)
~mr_Ten$ion~'s Avatar
Member: 135601
Sonork: 100.1612518
Thanks Meter: 68
how u unlock it R u change your 9V battery to 3v battery??
plz reply??
Old 03-08-2006, 08:22   #11 (permalink)
Nizze's Avatar
Member: 79724
Thanks Meter: 15
You have this on support.
W600i_CXC1123107_All-in-One_CustomV1_R7B039_Brown49.rar
It is a special file Lead have done, I think it is swedish in that one "not 100%"
I know it is norwegian in file, so I tink you will find swedish in it to.
And main file are W600i_CXC1123106_EU1_R7B039_Brown49.rar
Nizze
Old 03-08-2006, 08:28   #12 (permalink)
Nizze's Avatar
Member: 79724
Thanks Meter: 15
plz reply??
He changed from 3V to 9V.
Nizze
Old 03-08-2006, 18:48   #13 (permalink)
odinb's Avatar
Member: 76964
Thanks Meter: 2
Nizze
Found it!
Thanks again!
Owner of the phone was so happy!
SE J132 really to make cable with UC-10? Chevron Cruiser Suite 2 01-27-2010 19:03
Can't Connect K790 red51 with the 10.41 wiky Cruiser Suite 2 04-10-2007 13:36
Unlocking old phones with UC-10/Cruiser cable laxxe Cruiser Suite 4 07-24-2006 22:38
Cant connect to W600i?? simlockgsm Cruiser Suite 6 01-18-2006 10:01
problems connecting to X460 with PC Toddzbox SYSOL Platform 0 02-22-2005 14:58
Page generated in 0.29124 seconds with 9 queries
