07-16-2005, 16:47 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 43
Member: 110141 Status: Offline Thanks Meter: 0 | R1L005 Europe_2 and Europe_5 ? what about this files ? I canīt find them Or are this files not released yet ? I would like to have an Europe_2 or Europe_5 Version on my K750i. But the only possible firmware i found is the Europe_3 version. Regards Basti BTW: I canīt use the R1N versions, they are much to buggy |
07-16-2005, 18:10 | #3 (permalink) |
Member: 110141 Status: Offline Thanks Meter: 0 | And then i have a "retail" version of this EU version ? In EU_3 for example the "PlayNow" button is not integrated. If i flash my K750i with EU_3 and afterwards with the EU_2 SFA, will i have this button then ? I know, this question is not very important, but im interessted anyway Regards Basti |
07-17-2005, 13:58 | #6 (permalink) |
Member: 110141 Status: Offline Thanks Meter: 0 | Now i have tried it on my own But, like i was thinking, it is NOT an retail EU_5 or EU_2 Version after flashing the SFA. So Lead, what about this files ? Will you release them ? Exept the R1N files there is no EU_2 or EU_5 Firmware for K750i. Regards Basti |
07-17-2005, 15:18 | #7 (permalink) |
Member: 110141 Status: Offline Thanks Meter: 0 | What does SFA do ? Now i have the CDA string of an Europe_5 K750i. But nothing has changed The languages in the phone have not been changed either. I still have the complete Europe_3 languages in my K750i. Now I have flashed it with R1L by SEUS. I got an Europe_5 Firmware, but the languages are still the same like before. Seems as if the only possibility is to got to a service-point and flash a xfile. But can it be that this is the only solution ? |
07-17-2005, 18:31 | #11 (permalink) |
Member: 110141 Status: Offline Thanks Meter: 0 | You are not crazy There are no R1L flashes in support. I would be glad if Lead would release them, it would bei time for. I have done it that way: -Flashed R1J Main FW -Flashed R1J Europe_3 Filesystem -Flashed R1J Europe_5 SFA -Customised filesystem -Shutdown filesystem Then i turned on my K750i and made a master-reset. After that i have made an update to R1L by SEUS. But now i still have the languages of Europe_3. |
07-17-2005, 18:43 | #13 (permalink) |
Member: 110141 Status: Offline Thanks Meter: 0 | I donīt think so Otherwise i would allways get an "german E-Plus" firmware if i would update by SEUS. But i can watch the files that SEUS is downloading before it flashes. And this files are Europe_5 versions. So i think only CDA is getting checked. BTW: Could it be that the EU_5 SFA is faulty ? After flashing that SFA i can not connect by bluetooth. Before flashing SFA this had worked without any problems. But were ist Lead ? An answer, if R1L files (EU_2 and EU_5) will be released would be great Regards Basti |
07-17-2005, 21:57 | #14 (permalink) |
Crazy Poster Join Date: May 2004
Member: 64757 Status: Offline Thanks Meter: 3 | Hi, where is your problem? Take DaVinci Client and flash the R1L EU2 or EU5 and do no finalization. After flashing the FW and the FS connect it to cruiser and use the build in customization. The only point you will be missing is the play now button. BR Kai |
07-17-2005, 23:20 | #15 (permalink) |
Member: 110141 Status: Offline Thanks Meter: 0 | Hello Coyote, this is one of the (many) reasons why i bought cruiser Not to have to use DaVinci client anymore. The only problem ist that Lead doesnīt release that firmware. Instead of that we only have a very buggy developers firmware called R1N Regards Basti |
All Blackberry Hardware and Software Solution | youssef01 | BlackBerry (RIM) | 34 | 11-01-2012 17:31 |
LG-KH1800 SHOW (KOREAN PHONE) UNLOCKED DONE AGAIN! PIC'S and PROCEDURE INSIDE | Ligalig | LG | 1 | 03-30-2010 07:40 |
Rx2 and vpp button missing on my setup | luyanda | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-29-2010 16:07 |
@ Cruiser-Team: What about R1L005 for K750i ? | bmwbasti | Cruiser Suite | 9 | 07-21-2005 22:43 |
