Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 02-11-2009, 06:42   #1 (permalink)
SanjanMobile's Avatar
Member: 316292
Se FAST JAVA unlock w350 successfully without flash file
  11:30:03  SE A1 Fast Java Unlocker v1.01 by Cruiser Team
  11:30:03  Initializing...
! 11:30:03  1. Please see the documentation first (tab 'Info')
! 11:30:03  2. Choose the phone model
! 11:30:03  3. Please connect the phone while holding its C button…
  11:31:44  Connecting via Generic EMP USB Flash Device (USB1)…
  11:31:44  Device driver version: 2.1.0.0
  11:31:44  Device driver date: 3-20-2008
  11:31:44  Connecting to the baseband CPU...
  11:31:44  Entering baseband CPU service mode...
  11:31:45  Detected chipset: PNX5230
  11:31:45  Boot mode: EROM
  11:31:45  EROM version: R4A018      prgCXC1250596_EROM_PNX5230_ALVA_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
  11:31:45  Sending loader...
  11:31:47  Starting up System...
  11:31:47  Starting up GDFS...
! 11:31:50  Rest-file not found, creating…
  11:31:50  Starting up FS...
! 11:31:56  1. Disconnect the cable from the phone
! 11:31:56  2. Turn the phone ON
! 11:31:56  3. Find the created rest-file in your phone file folders, with the following name:
! 11:31:56  - R11CA002_1204-3117_GENERIC_JH.rest
! 11:31:56  4. Download the rest-file into the following folder (see documentation):
! 11:31:56  - C:\Documents and Settings\AverComp\Application Data\Cruiser Suite\SE A1 Fast Java Unlocker
insert test card or (active card) in your phone and switch on your phone
there are file R11CA002_1204-3117_GENERIC_JH.rest in phone OTHER folder
copy it to your memory card or other trick and paste this file into this folder
(if u have not this folder create it) and paste the file
run again fast java unlock and attached the phone
  11:43:57  SE A1 Fast Java Unlocker v1.01 by Cruiser Team
  11:43:57  Initializing...
! 11:43:57  1. Please see the documentation first (tab 'Info')
! 11:43:57  2. Choose the phone model
! 11:43:57  3. Please connect the phone while holding its C button…
  11:44:33  Connecting via Generic EMP USB Flash Device (USB1)…
  11:44:33  Device driver version: 2.1.0.0
  11:44:33  Device driver date: 3-20-2008
  11:44:33  Connecting to the baseband CPU...
  11:44:33  Entering baseband CPU service mode...
  11:44:33  Detected chipset: PNX5230
  11:44:33  Boot mode: EROM
  11:44:33  EROM version: R4A018      prgCXC1250596_EROM_PNX5230_ALVA_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
  11:44:33  Sending loader...
  11:44:34  Sending loader...
  11:44:36  Starting up System...
  11:44:36  Starting up GDFS...
  11:44:39  Starting up FS...
  11:44:45  Done.
! 11:44:45  1. Disconnect the cable from the phone
! 11:44:45  2. Insert either a test-card or a SIM card which the phone accepts to the phone
! 11:44:45  3. Power on the phone by pressing the power ON/OFF button.
! 11:44:45  4. Go to the menu 'Entertainment' -> 'Games' and select/run the application 'executor'
! 11:44:45  5. Wait few seconds until the phone restarts by itself
! 11:44:45  6. Then the phone is unlocked, you may delete the 'executor' application from the phone
great job from cruiser team no need flash file direct unlock
The Following 3 Users Say Thank You to SanjanMobile For This Useful Post:
Old 02-13-2009, 13:48   #2 (permalink)
marcopolod's Avatar
Member: 543191
please, help me. how to create this folder?
Old 02-14-2009, 05:17   #3 (permalink)
Member: 316292
go to my computer -->> double click on c: drive go to Documents and setting there are your (computer name) avercomp (avercomp is my computer name) go to application data if not create a folder name Application Data double click on it and create a new folder Cruiser Suite double click on it and create new folder SE A1 Fast JAVA Unlocker double click an paste that file which is in your mobile (R11CA002_1204-3117_GENERIC_JH.rest phone's filemanager OTHER folder)
thanks
The Following 2 Users Say Thank You to SanjanMobile For This Useful Post:
Old 02-19-2009, 05:38   #4 (permalink)
Member: 316292
i have also unlocked w380 as same as above
Old 04-07-2009, 21:12   #5 (permalink)
Member: 170822
fast java unlocker
is good idea to create a folder in to mi computer name with "application data and it gives me an error can not renamenew folder:a file with that name you specified allready exist.especify a diferent file name.
I have try 3 diferent computers same error any ideas?
Old 04-09-2009, 02:27   #6 (permalink)
ptt
ptt's Avatar
Member: 348680
the folder "C:\Documents and Settings\"your session name" \Application Data" is a system folder, its crated by Windows....
try with "search" tool of windows an you see that folder already exists (maybe hidden folder) search for: "C:\Documents and Settings\"your session name"\Application Data\Cruiser Suite\SE A1 Fast Java Unlocker" if don find search for: "C:\Documents and Settings\"your session name"\Application Data\Cruiser Suite" if find, then crate new folder named "SE A1 Fast Java Unlocker" thats all
sorry my bad eng.
The Following User Says Thank You to ptt For This Useful Post:
Old 03-04-2010, 01:54   #7 (permalink)
Member: 1246631
I cant connect my phone!! it is just stuck at begining screen...
eventhough the place for device says "Generic EMP USB Flash Device (USB2)"...
is there anything else i need??
please help!!
The Following User Says Thank You to spdrcd For This Useful Post:
Old 03-10-2010, 11:53   #8 (permalink)
mdalamgir's Avatar
Member: 694638
How to unlock w350i without flash
1.Open 'SE A1 Fast Java Unlocker'
2.Select phone model
3.connect phone holding'c' or nay how
4.When 1st step complete, disconect phone
5.Insert test sim or accepted sim
6.Power on phone and go to file manager->In phone other folder->Copy 'R11CA002_1204-3117_GENERIC_JH.rest' this file
from 'other folder' and past it in your computer C:\Documents and Settings\AverComp\Application Data\Cruiser Suite\SE A1 Fast Java Unlocker
7.run again fast java unlock and attached the phone
8.At the end Disconnect the cable from the phone
9.Insert either a test-card or a SIM card which the phone accepts to the phone
10.Power on the phone by pressing the power ON/OFF button.
11.Go to the menu 'Entertainment' -> 'Games' and select/run the application 'executor'
12.Wait few seconds until the phone restarts by itself
13.Then the phone is unlocked, you may delete the 'executor' application from the phone
Now enjoy unlock phone without flash.
The Following 4 Users Say Thank You to mdalamgir For This Useful Post:
Old 03-10-2010, 12:02   #9 (permalink)
mdalamgir's Avatar
Member: 694638
Here is the picture of w350i
Old 03-12-2010, 18:34   #10 (permalink)
Member: 1258666
I have the same problem as spdrcd has where the unlocker does not recognize the phone (it IS connected), and nothing happens.
I am using a newer DCU 65 cable as the DCU 60 was not supplied when i bought the device ...
Is it because of the newer cable, or am i doing something wrong? (Connect phone while it's off while holding 'c' and waiting)
Old 03-13-2010, 04:54   #11 (permalink)
Member: 376471
How and where to get the restore file....................
Details please..............
Se fast java unlocker -==unloOok==- Cruiser Suite 3 09-04-2009 23:39
How can i connect SE W350 to unlock with Crusier A1 fast Java unlocker???? Unlocker AL Cruiser Suite 9 07-22-2009 10:57
se fast java unlocker just freezes on unlock hollyann Cruiser Suite 3 02-13-2009 12:46
se fast java unlocker freezes on fs hollyann Cruiser Suite 0 02-07-2009 11:40
Post Here Successfully unlocked using SE A1 Fast Java unlocker bhart Cruiser Suite 90 01-27-2009 21:07
Page generated in 0.32875 seconds with 11 queries
