10-18-2005, 08:55 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Timeless zone! Age: 35
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | K-700i Hang on Start up when we select the Language........ I have a K-700i who is hanging on start up when we select the language.Last time the phone was hanging on searching before i have flash it.After flash the phone is hang on select Language.Plz help me and guide me and i need ur help urgently........Thanxxxxxxxxxxxxxxxx BR Muneeb Akhtar Raza |
11-16-2005, 03:53 | #3 (permalink) | |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Quote:
>>> do compatibility software, thats software only | |
11-16-2005, 08:28 | #4 (permalink) |
No Life Poster Join Date: Sep 2004 Location: HR Age: 48
Member: 80391 Status: Offline Sonork: 100.1601620 Thanks Meter: 66 | Use SEMC Tool 1.228 Cracked and mark check box "K700 freezed", then click on Unlock/Repair. That's the best way to solove your problem, tested. |
The Following User Says Thank You to g-zona For This Useful Post: |
11-16-2005, 12:05 | #5 (permalink) |
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | Hi mates, I have checked the sonics \cracked and i check on freez fone and unlock it but no news with that plz if u have any other idea so post here....OK BR MUNEEB AKHTAR RAZA |
11-16-2005, 12:25 | #6 (permalink) | |
No Life Poster Join Date: May 2005 Location: Baguio City, Benguet
Member: 149576 Status: Offline Thanks Meter: 57 | K-700i Hang on Start up when Quote:
11-16-2005, 17:10 | #7 (permalink) | |
Member: 80391 Status: Offline Sonork: 100.1601620 Thanks Meter: 66 | Quote:
WBR! | |
02-15-2006, 18:20 | #9 (permalink) |
Crazy Poster Join Date: Jul 2004 Location: KSA
Member: 74223 Status: Offline Thanks Meter: 2 | Use SEMC Tool 1.218 by sonics and mark check box "K700 freezed", then click on Unlock/Repair. Maybe this work only with the original sonicsbox not for cracked. Tried and tested many times.. You may try semctool 1.228 same procedure and use twister or tornado. |
02-16-2006, 10:09 | #12 (permalink) |
No Life Poster Join Date: Jan 2004 Location: India Age: 43
Member: 50805 Status: Offline Thanks Meter: 101 | Here is the solution for that phone which got restart, hang when selecting lanugage..i test on K700I, K750i(many handset) and 100% working..i tested..(Cruiser) This solution unlock and hanging problem for K700 K750 1 Connect phone 2 Flash file with full GDFS 3 Use UnlockRSA 4 Use Direct Unlock.. all is ok insert sim and test the phone. Best Regards.. |
The Following User Says Thank You to muksforu For This Useful Post: |
06-07-2006, 18:26 | #14 (permalink) |
Freak Poster Join Date: Jun 2004 Age: 48
Member: 68824 Status: Offline Thanks Meter: 5 | hi with jerrel me to have the same problem. I just had 2 k700 with hang problem on the menu selection can enyone have a solution for it I bet I will create a solution because i'm trying it but iff a have a olution a bet I will send it to you all guys so who comes up first peace to you fellas |
N70 turns on and hang on start up | azeem781986 | Nokia Hardware & Hardware Repair | 1 | 09-05-2009 19:03 |
Moto A1000 hang on start up | i_am_rocky | Smart-Clip | 3 | 12-17-2005 09:20 |
E700 hang on start up | uk brothers | Samsung Hardware Repair | 3 | 12-09-2005 14:32 |
NEC 221i hangs on start up or after entering PIN | sat | NEC | 2 | 07-29-2003 13:21 |
