07-01-2008, 14:36 | #1 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Ireland
Member: 384012 Status: Offline Thanks Meter: 28 | SE W580i camera problem I have a problem with SE W580i. When i try to open a camera on this phone i get this LOG: Another application is running. Close it, and then start the camera. I flashed this phone several times to fix this problem but it did not help. Any ideas please! Thank you! |
07-24-2008, 22:08 | #3 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: 127.0.0.1 Age: 79
Member: 545165 Status: Offline Thanks Meter: 578 | Quote:
07-24-2008, 23:26 | #4 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 339455 Status: Offline Sonork: 100.1589401 Thanks Meter: 86 | Hello first replace upper side uif that cam on it. then replace b to b fpc that connect main board to upper side uif. if it is not solve problem try to cleaning the board and check camera module. |
03-12-2011, 05:52 | #5 (permalink) | |
Insane Poster Join Date: Oct 2010 Location: palavanthangal,chennai
Member: 1409087 Status: Offline Thanks Meter: 3 | Quote:
[email protected] | |
04-04-2011, 09:28 | #9 (permalink) |
Registered User Join Date: Jul 2008 Location: SIVAKASI
Member: 806063 Status: Offline Sonork: becozbecoz Thanks Meter: 26 | brother change mmc strip and then take old strip remove camera safely then fix it to new strip safely your probs solve. try it & then post reply. |
The Following User Says Thank You to becozbecoz For This Useful Post: |
04-05-2011, 17:46 | #10 (permalink) |
Insane Poster Join Date: Nov 2008
Member: 891091 Status: Offline Sonork: wonk Thanks Meter: 5 | Thanks for caring, here there are 2 types of W580 but this one was ok, and the second from the W580 still has yet to be fixed because the bottom of the connection between the camera and flexible cable corrosion is severe, had been cleaned but still not working, the software has maximized , the second case is what makes me confused ...... so to all that here if I can beg its support, especially a picture, it really helps. thanks..... |
se k800 camera problem | VIJEESHNK | Sony Ericsson Hardware Repair | 18 | 04-05-2011 11:54 |
W580i Camera Problem | Azhar Nazeer | Sony Ericsson Hardware Repair | 5 | 03-23-2010 04:30 |
se w800 camera problem | helloooooooo | Sony Ericsson | 0 | 09-21-2007 07:07 |
se k750i camera problem | nomi | Sony Ericsson Hardware Repair | 6 | 07-16-2007 09:05 |
SE w800 Camera Problem | alifia | Sonics Box | 1 | 11-15-2005 22:27 |
