07-13-2008, 17:57 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: iraq
Member: 214010 Status: Offline Thanks Meter: 23 | help me fast k320i not bunlock..... Go to the menu 'Entertainment' -> 'Games' and select/run the application 'executor' ) any on can tell me step by step......or all steps??? |
07-15-2008, 16:26 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks Meter: 200 | Man where is yours problem? access Games menu? all is specify in soft when you are unlocking phone. soft give you step to step procedure and you can't unlock? anyway, you must have and "TEST CARD" or any "ACCEPT CARD" by the lock phone to be able to access games menu, run "executor", then phone "off" then "on" again. now you delete " executor" in game menu. for example, if phone is lock on SFR, you must have any SFR "SIM CARD" or "MOTOROLA TEST CARD" to be able to access "Entertainment",and "Game" menu |
07-15-2008, 17:04 | #6 (permalink) | |
Junior Member Join Date: Jul 2008 Location: TP is OK .... Unlock Done
Member: 812576 Status: Offline Thanks Meter: 2 | Quote:
we did everything the problem is the phone can't be unlocked with FAST java unlocker i already run the executor ( with testcard ) and the phone is restarted but it's still locked Last edited by Mainboard; 07-15-2008 at 18:53. Reason: no ad | |
07-15-2008, 17:05 | #7 (permalink) |
Freak Poster Join Date: Mar 2006 Location: HP Mnla,Philippines Age: 38
Member: 247410 Status: Offline Thanks Meter: 161 | i have same problem..... but i fixed it,,, i run the executor 2 times,,,, when first try not unlock.... insert accepted simcard and run executor again.... |
07-15-2008, 18:12 | #8 (permalink) | |
Member: 214010 Status: Offline Thanks Meter: 23 | Quote:
07-15-2008, 18:55 | #9 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 25671 Status: Offline Thanks Meter: 719 | @helin 3 days you are asking here for help, but till now you didn't post full log from java unlocker or from fast java unlocker, so don't be surprised that nobody help you |
07-15-2008, 20:11 | #10 (permalink) |
Member: 812576 Status: Offline Thanks Meter: 2 | ok what about me Mr MainBoard http:///vbb/showthread.php?t=564354 |
07-15-2008, 21:37 | #11 (permalink) |
Freak Poster Join Date: Apr 2008 Location: East Sus***
Member: 739858 Status: Offline Thanks Meter: 9 | this is not new... I have to sometimes 8-10 times run executor , then mobile (w200i, cid 53) is unlocked. Very,very strange problem. Fast Java Unlocker works - but not always |
07-16-2008, 14:37 | #12 (permalink) | |
17:32:29 SE A1 Fast Java Unlocker v1.01 by Cruiser Team 17:32:29 Initializing... ! 17:32:29 1. Please see the documentation first (tab 'Info') ! 17:32:29 2. Choose the phone model ! 17:32:29 3. Please connect the phone while holding its C button… 17:32:39 Connecting via SEMC USB Flash Device (USB1)… 17:32:39 Device driver version: 1.1.0.12 17:32:39 Device driver date: 9-25-2006 17:32:39 Connecting to the baseband CPU... 17:32:39 Entering baseband CPU service mode... 17:32:39 Detected chipset: DB2012 17:32:39 Boot mode: EROM 17:32:39 EROM version: R3A017 prgCXC1250692_EROM_DB2010_MARTINA_FOTA_FLAFLA_SIBL EY_SEMCUSB 17:32:39 Sending loader... 17:32:40 Sending loader... 17:32:42 Starting up System... 17:32:42 Starting up GDFS... 17:33:07 Starting up FS... 17:33:21 Done. ! 17:33:21 1. Disconnect the cable from the phone ! 17:33:21 2. Insert either a test-card or a SIM card which the phone accepts to the phone ! 17:33:21 3. Power on the phone by pressing the power ON/OFF button. ! 17:33:21 4. Go to the menu 'Entertainment' -> 'Games' and select/run the application 'executor' ! 17:33:21 5. Wait few seconds until the phone restarts by itself ! 17:33:21 6. Then the phone is unlocked, you may delete the 'executor' application from the phone this is my log sir .....now can you help me?????? | |
hi UNI box Team plz help me fast | gsmshahrayar | Universalbox | 15 | 05-09-2013 17:22 |
help...e51 charging not show please help me ..fast | nakshatrahir | Nokia Hardware & Hardware Repair | 1 | 02-19-2009 14:10 |
help me fast w200i not bunlock | fateh76dz | Cruiser Suite | 3 | 07-28-2008 19:05 |
help me pls k320i | vash08 | SETool2 | 4 | 05-20-2008 13:02 |
Pls help me fast | mafolk | Nokia Hardware & Hardware Repair | 4 | 02-23-2008 12:40 |
