Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 05-26-2009, 16:12   #1 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
Sony Ericsson K530i flash error
I have dead K530i and it won’t accept the flash.
Applet ID: 061220 1711 NPA4_CXC1329130_DB2020_...
Flash manufacturer: Intel
Flash ID: 0x897E
OTP Security Level: 1 (Retail)
OTP CID: 51
Phone CID: 52
Phone color: Red
Sending applet...
Applet ID: 061205 1523 HANCXC9876543210_DB2020...
Sending applet...
Applet ID: 061201 1314 HANCXC1329129_DB2020_FL...
RSA protection state cannot be determined for this CID.
Phone hardware initialized OK
[ --- Flash Main Firmware --- ]
Flash file: "K530i_CXC1250912_Generic_R8BB001_Red52.a1sw"
Waiting for flash file to load...
Preparing to program flash...
Programming flash...
Flash color/CID mismatch!
Script error: Flash error [13.20.77]
Old 05-27-2009, 02:32   #2 (permalink)
xerraco's Avatar
Member: 890926
Use USB cable & use other CID-52 File.
Old 05-27-2009, 10:27   #3 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
The same error with different file.
System diagnostics passed.
Version 13.20 ready!
Do NOT connect the phone at this time!
[ --- Attach to Phone --- ]
Connecting via SEMC DCU-60...
Connect the phone while holding its C button!
USB connection established.
Baseband chip ID: 0x9801
Protocol version: 3.1
Booting via EROM...
Sony Ericsson phone detected.
Phone CID: 52
Phone color: Red
EROM version: R3A016
Trying CID52 recovery applet...
Sending applet prologue...
Sending applet body...
Time spent entering bootstrap: 0s
Initializing phone hardware...
Flash ID: 0x897E
OTP CID: 51
Phone CID: 52
Phone color: Red
Sending applet...
Sending applet...
Flash file: "K530i_CXC1250912_Generic_R8BC004_Red52.a1sw"
Old 05-27-2009, 10:32   #4 (permalink)
xerraco's Avatar
Member: 890926
Use A1 JAva Unlocker to Flash/Unlock your phone Mate.
Old 05-27-2009, 10:51   #5 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
Same problem
  10:46:16  SE A1 Java Unlocker v1.11 by Cruiser Team
  10:46:16  Initializing...
! 10:46:16  1. Choose the phone model
! 10:46:16  2. Select main firmware flash file (*.a1sw)
! 10:46:16  3. Select raw FS flash file (*.a1fs)
! 10:46:16  4. Please connect the phone while holding its C button…
  10:47:29  Connecting via SEMC USB Flash Device (USB1)…
  10:47:29  Device driver version: 1.1.0.12
  10:47:29  Device driver date: 9-25-2006
  10:47:29  Connecting to the baseband CPU...
  10:47:29  Entering baseband CPU service mode...
  10:47:29  Detected chipset: DB2020
  10:47:29  Boot mode: EROM
  10:47:29  EROM version: R3A016      prgCXC1250461_EROM_DB2020_WILMA_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
  10:47:29  Initializing flash files...
  10:47:37  Sending loader...
  10:47:38  Sending loader...
  10:47:38  About to flash 40 MB of data…
E 10:47:49  Error: 0xA8A269DB
E 10:47:49  Error: 0x3173E984
E 10:47:49  Error: 0x4B055A8F
E 10:47:49  Error: 0x88B974CA
E 10:47:49  Error: 0x5684B2E4
E 10:47:49  Error: 0x28AB9F88
E 10:47:49  Error: 0x2701BE08
E 10:47:49  Error: 0xB63595F9
E 10:47:49  Cable disconnect detected
E 10:47:49  Failed!
! 10:47:49  1. Please disconnect battery and cable from the phone!
! 10:47:49  2. Turn on the phone with inserted test card or sim card for which is the phone locked
! 10:47:49  3. Go to Entertainment and select Games.
! 10:47:49  4. Delete executor file.
! 10:47:49  5. Turn off the phone
! 10:47:49  To report errors right-click this window
Old 05-27-2009, 11:07   #6 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
I forgot to tell you what phone came to me dead, won’t switch on.
Old 05-27-2009, 11:14   #7 (permalink)
xerraco's Avatar
Member: 890926
Its a HW problem then Mate.
Old 05-27-2009, 11:36   #8 (permalink)
Member: 57803
It's a long shot, but try to update your phone with SEUS. It's free so you are not losing anything only time.
It would be a very good idea to update your flash driver to 2.1.0.0, the one you are using is two years old and does not always work on some models.
Old 05-27-2009, 13:45   #9 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
SEUS says your software is up to date. I have updated flash driver to 2.1.0.0, but no luck, same error.
Old 05-27-2009, 14:13   #10 (permalink)
Member: 57803
I've just noticed you are using v1.11 Java.
Try v1.10, I'm certain I have seen on here others have had problems with 1.11
I have also had this problem a few times, repeated the procedure and it's worked on second or third time,
Old 05-27-2009, 14:24   #11 (permalink)
Member: 57803
Just had another thought, if SEUS is saying you have the latest firmware I would think your handset is CID53.
Try a CID53 generic flash.
Old 05-27-2009, 16:40   #12 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
No luck with CID53 generic flash. Still same error......
Old 05-27-2009, 17:49   #13 (permalink)
nasagih's Avatar
Member: 551188
Sonork: 100.1580118
use dcu60.........
1. Unlock Rsa
2. Main
3. FS
4. Direct Unlock
5. Customize
6. Turn off
7. Smoke your cigarette.......
Old 05-27-2009, 19:13   #14 (permalink)
fun
fun's Avatar
Member: 117145
Sonork: 1617520
Originally Posted by nasagih View Post
use dcu60.........
1. Unlock Rsa
2. Main
3. FS
4. Direct Unlock
5. Customize
6. Turn off
Booting via EROM...
Phone CID: 52
Phone color: Red
Flash ID: 0x897E
OTP CID: 51
Phone CID: 52
Phone color: Red
Sending applet...
Sending applet...
[ --- Unlock RSA --- ]
Time: 00:00:20
Flash process done.
Time: 00:00:02
Flash process done.
Sending CS applet...
Failed!
Failed!
Old 05-27-2009, 21:21   #15 (permalink)
nasagih's Avatar
Member: 551188
Sonork: 100.1580118
idenntify the phone please and thick analyze config and display more info..
wanna see the log.
sony ericsson k530i problem harryharry Sony Ericsson 5 04-28-2011 08:58
forgot pin code sony ericsson k530i plz help skagman Sony Ericsson 1 12-22-2008 02:20
sony ericsson k530i ebable usb cable harryharry Sony Ericsson 0 06-09-2008 07:40
Sony-Ericsson K530i locked to Orange France randy_z Phone Unlocking Codes & Maps 0 05-14-2008 14:43
Page generated in 0.75975 seconds with 11 queries
