06-13-2008, 18:11 | #1 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Heaven Age: 41
Member: 613221 Status: Offline Thanks Meter: 26 | Succesfully unlocked Z310a CID52 using java unlocker. Thank you very much cruiser team, you're the best on Sony Ericsson Solutions. |
06-16-2008, 18:12 | #8 (permalink) |
No Life Poster Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks Meter: 200 | yes if have -07 card what next should i have? do i need any flash files, how about using of test card or accepted card on what phone is locked? it is still necessary ? |
06-17-2008, 10:09 | #11 (permalink) |
Member: 118601 Status: Offline Thanks Meter: 200 | yes to follow instruction but why not just let me know if i need any particular flash file and what i hear somewhere that it need tes card? please be more precise in your answer! it is too easy to said just follow instruction when i hear some complain about a step the didn't remove card from phone and it fail...what about all that? |
06-17-2008, 10:49 | #12 (permalink) |
No Life Poster Join Date: Oct 2003 Location: South Spain
Member: 42553 Status: Offline Thanks Meter: 23 | Testing... and error Code: 11:45:05 SE A1 Java Unlocker v1.02 by Cruiser Team 11:45:05 Initializing... ! 11:45:06 1. Choose the phone model ! 11:45:06 2. Select main firmware flash file (*.a1sw) ! 11:45:06 3. Select raw FS flash file (*.a1fs) ! 11:45:06 4. Please connect the phone while holding its C button… 11:46:02 Connecting via Generic EMP USB Flash Device (USB1)… 11:46:02 Device driver version: 1.1.0.12 11:46:02 Device driver date: 9-25-2006 11:46:02 Connecting to the baseband CPU... 11:46:02 Entering baseband CPU service mode... 11:46:03 Detected chipset: PNX5230 11:46:03 Boot mode: EROM 11:46:03 EROM version: R4A012 prgCXC1250596_EROM_PNX5230_ALVA_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 11:46:03 Initializing flash files... E 11:46:16 Error: 0x11B6D9FC E 11:46:16 Flash Firmware version is not supported. Try another version. E 11:46:16 Error: 0xD6C6C7B1 E 11:46:16 Error: 0xA8A269DB E 11:46:16 Error: 0xB63595F9 E 11:46:16 Cable disconnect detected E 11:46:16 Failed! ! 11:46:16 Please disconnect battery and cable from the phone! ! 11:46:16 To report errors right-click this window |
K310i cid50 unlocked done with ERROR using Java Unlocker | right_click | Cruiser Suite | 0 | 02-11-2009 05:23 |
how to unlock w850 cid52 use setools v0.915016 | ahsam | SETool2 | 6 | 12-08-2008 14:34 |
HELP UNLOCK Z310a CID52 | emely | Sony Ericsson | 12 | 06-05-2008 09:54 |
can or can,t unlock k810i cid52 using cruiser | ruvanw1979 | Cruiser Suite | 5 | 01-09-2008 08:39 |
how to unlock k810i cid52 using cruiser | ruvanw1979 | Cruiser Suite | 3 | 01-08-2008 05:11 |
