Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 10-15-2004, 01:54   #1 (permalink)
Member: 85260
Wink Sandisk or Sony memory stick pro duo 1G
Does anyone tried the Sandisk or Sony memory stick pro duo 1G work on the p900-p910i?
how about the speed?
Old 10-16-2004, 05:18   #2 (permalink)
Member: 85260
NO ONE TEST it before? i plan to buy a 1G sandisk, but if i open it , can not get refund.....no change.....
Old 06-21-2005, 18:48   #3 (permalink)
nctrung_vn's Avatar
Member: 135671
Thanks Meter: 45
Some documetn is maximum í 128Mb.
What í prolem.
Old 06-21-2005, 18:51   #4 (permalink)
evan_silbert's Avatar
Member: 21920
Thanks Meter: 10
P910i accepts Memory Stick Pro Duo, so it will work. It won't work in P900 though, unless it is converted to P910x.
Old 06-22-2005, 04:01   #5 (permalink)
Member: 77254
Thanks Meter: 9
I'm using MS Pro Duo 256MB on P900 converted to P910, since P900 only support up to 128MB. Speed is normal.
Old 06-22-2005, 04:05   #6 (permalink)
nctrung_vn's Avatar
Member: 135671
Thanks Meter: 45
Convẻt my phone or use other Program convert Sundisk or Sony memory stick pro duo .
Thanhk & Best Regards
Old 06-22-2005, 04:17   #7 (permalink)
muppet's Avatar
Member: 42570
Thanks Meter: 11
Yes, no and a waffle iron.
(I don't understand, are you asking a question?)
This thread should be moved to the SE section, it's not really Fighter/Cruiser specific.
Old 06-23-2005, 03:29   #8 (permalink)
nctrung_vn's Avatar
Member: 135671
Thanks Meter: 45
How other program can convert Sony memory stick pro duo from p910i to p900.
What is solution can be.
Best & regards
Old 06-23-2005, 03:57   #9 (permalink)
muppet's Avatar
Member: 42570
Thanks Meter: 11
Only Fighter or Cruiser can convert your P900 phone to a P910, via a special firmware flashs created by Cruiser Team.
Then you can use your pro duo in a P900.
I assume that's what your asking, you can't convert a memory stick @ all.
Somebody interessted in 500x Memory Stick Pro Duo from Scandisk?? malcomxyz Sell ur Old and Used Stuff 4 05-08-2007 21:55
memory stick pro duo jrguy8 Sony Ericsson Hardware Repair 3 08-13-2006 10:29
can i make my p900 read memory stick PRO duo??? theknight_26 Sony Ericsson 0 08-02-2006 15:02
E616 and Sony Memory Stick Duo gibso NEC 5 05-22-2006 11:27
Page generated in 0.18553 seconds with 9 queries
