Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 01-03-2004, 09:30   #1 (permalink)
The Racer's Avatar
Member: 20490
T68m gdfs imei FFFFFF-FF-FFFFFF. Help!
I have T68m & it shows GDFS imei FFFFFF-FF-FFFFFF. When i try to write security 1, after 1 hour at 100% it give me Update Fail. Phone is dead. What can i do?
Old 01-05-2004, 15:40   #2 (permalink)
Member: 17711
Seem like your phone's OTP area is not programmed. May be this is blank PCB, or flash chip is destroyed.
Anyway, try to write Patched flash into phone, change IMEI and Rebuild/Recreate GDFS (unfortunately, I have no Fighter, so, I can't tell what options to use).
Old 01-05-2004, 20:38   #3 (permalink)
The Racer's Avatar
Member: 20490
Thanks FractalizeR!
Where can i get the patched flash?
Old 01-05-2004, 20:45   #4 (permalink)
Member: 6142
@Racer!
1.Attach phone
2. Create security I zone ( with correct imei) and choose write otp and gdfs area
3. Flash avr with normal flash ( from support zone)
4. flash arm!
That is it!
Roniri
Old 01-06-2004, 09:01   #5 (permalink)
Member: 17711
Originally posted by The Racer
Thanks FractalizeR!
Hello.
I think these flashes must be in Fighter support area (I suppose you have Fighter, because your post in Fighter support area).
If not, you can use cracked DIV 8.2 and Patched flashes. It works with Terminator dongle. Last tme I downloaded them from www.cellular-support.com. After flashing just change IMEI with DIV and Rebuild CRCs if needed.
Old 01-06-2004, 18:39   #6 (permalink)
The Racer's Avatar
Member: 20490
thank u both, i'll test today.
thank u
Old 01-12-2004, 10:03   #7 (permalink)
Member: 45270
i had the same prob... tried every thing as mention above...
but the phone is still dead
Old 01-12-2004, 10:25   #8 (permalink)
krtko's Avatar
Member: 5155
Originally posted by FractalizeR
Hello.
for T68x u dont need any patched flash, just check phone by reading GDFS if u have gdfs data there, if not upload GDFS from another phone flash avr, arm, make new security zone with new imei, if otp is too empty u can use write too OTP imei and enjoy, another case is when this error is based on faulty flash IC etc...
krtko
Old 01-12-2004, 11:49   #9 (permalink)
Member: 45270
@krtko.... please can u give some more details.....
in my phone some time the otp gdfs shows the valid iemi... some time 999999999 and... when i rebuild the sec zone 1 it takes too much time and than says fail.. could it be a h/w fault ?...
in another phone i can create the sec zone sucessfully... than i have flashed avr / arm and the phone is still dead
Old 01-12-2004, 21:03   #10 (permalink)
SphereGSM's Avatar
Member: 6253
@talibshad
Seems your phones has hardware problem
Best Regards,
SphereGSM | info@spheregsm.com | ICQ: 38377906 | www.spheregsm.com
Old 01-13-2004, 12:46   #11 (permalink)
The Racer's Avatar
Member: 20490
@ SphereGSM
What about my phone(t68) with GDFS IMEI FFFFFF-FF-FFFFFF?
Old 01-14-2004, 06:32   #12 (permalink)
debeliamark's Avatar
Member: 4627
Sonork: 57528:debeliamark
But what is a problem to write IMEI? If after write IMEI is still FF...F, then just change flash IC with new one and reprogram phone. I have maded this on many T68 ...
P.S. OTP IMEI can be the FF...F and phone will work OK, but you MUST have the GDFS imei
T630 imei FFFFF-FF-FFFFFF-F f.i.t Cruiser Suite 8 08-22-2007 11:38
What can I do....GDFS IMEI: FFFFFF-FF-FFFFFF-F kosmonaft Cruiser Suite 9 03-26-2004 20:55
t68 GDFS imei = ffffff .... please help talibshad Cruiser Suite 0 01-08-2004 07:19
IMEI FFFFFF-FF-FFFFFF cannot be repaired with Fighter. Phantom Cruiser Suite 7 11-30-2003 12:45
GDFS IMEI: FFFFFF-FF-FFFFFF-F , Help!!!!!! VsH-GsM Sony Ericsson 20 10-13-2003 09:18
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
Page generated in 0.34203 seconds with 8 queries
