Tested and 100% procedure Repairing Gdfs in DB2020 with cruiser From My experience i want to share this procedure 1..connect and do repair gdfs see the log here Code: 18:26:12 SE Ultimate Unlocker v3.07 by Cruiser Team 18:26:12 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 18:26:12 Initializing... ! 18:26:12 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 18:26:12 2. Choose the phone model ! 18:26:12 3. Select the desired options ! 18:26:12 4. Please connect the phone either via USB while holding 2-5… ! 18:26:12 - or via a serial cable and double-click on it in the device list 18:26:38 Selected phone: K770 18:26:38 Connecting via Generic EMP USB Flash Device (USB1)… 18:26:38 Device driver version: 2.2.0.2 18:26:38 Device driver date: 12-5-2008 18:26:38 Connecting to the baseband CPU... 18:26:38 Entering baseband CPU service mode... 18:26:38 Detected chipset: DB2020 18:26:38 Boot mode: ROM 18:26:38 Sending loader... 18:26:39 IMEI: 35238402484393 18:26:39 OTP CID: 51 18:26:39 Effective CID: 53 18:26:41 Please reconnect the phone (disconnect, connect while holding 2-5) 18:26:51 Sending loader... 18:26:51 Communicating with server… ! 18:26:56 News: Your credit consumption policy: Level 1 (Novice) 18:26:56 Remainig credit (supreme): 0.78 18:26:59 Remainig credit (supreme): 0.45 18:27:02 Please reconnect the phone (disconnect, connect while holding 2-5) 18:27:10 Sending loader... E 18:28:17 Error: 0x6C729765 E 18:28:17 Error: 0x8CDFAB78 E 18:28:17 Error: 0xFA7863EC E 18:28:17 Error: 0x780BA8B0 E 18:28:18 Error: 0x599D63C1 E 18:28:18 Error: 0x10BE36DC E 18:28:18 Error: 0x59AF7680 E 18:28:18 GDFS start-up problem E 18:28:18 Failed! ! 18:28:18 To report errors right-click this windowit seems it is not ok reparing till now but i leave the phone about 10 second i switch on the phone and wating about 20 sec 2.phone now is alive after i reaatch the phone see the log here Code: 18:35:11 SE Ultimate Unlocker v3.07 by Cruiser Team 18:35:11 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 18:35:11 Initializing... ! 18:35:11 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 18:35:11 2. Choose the phone model ! 18:35:11 3. Select the desired options ! 18:35:11 4. Please connect the phone either via USB while holding 2-5… ! 18:35:11 - or via a serial cable and double-click on it in the device list 18:35:26 Selected phone: K770 18:35:26 Connecting via Generic EMP USB Flash Device (USB1)… 18:35:26 Device driver version: 2.2.0.2 18:35:26 Device driver date: 12-5-2008 18:35:26 Connecting to the baseband CPU... 18:35:26 Entering baseband CPU service mode... 18:35:26 Detected chipset: DB2020 18:35:26 Boot mode: ROM 18:35:26 Sending loader... 18:35:27 IMEI: 35238402484393 18:35:27 OTP CID: 51 18:35:27 Effective CID: 49 18:35:29 Please reconnect the phone (disconnect, connect while holding 2-5) 18:35:36 Sending loader... 18:35:39 Code NCK for relock: 9211324260753353 18:35:39 Code NSCK for relock: 1969954361064952 18:35:39 Code SPCK for relock: 9085525849448979 18:35:39 Code CCK for relock: 8635265339788044 18:35:40 Code PCK for relock: 3134626068517252 18:35:40 Code ESLCK for relock: 3219847942181935 18:35:40 Code NCK for unlock: 8962651602873649 18:35:40 Code NSCK for unlock: 5786406576009437 18:35:40 Code SPCK for unlock: 6369006569470688 18:35:40 Code CCK for unlock: 3245219438451312 18:35:40 Code PCK for unlock: 6279660297678806 18:35:40 Code ESLCK for unlock: 2816940829488474 18:35:41 To enter a code, type < * * < on the phone with SIM-card inserted 18:35:41 Writing flash… 18:35:41 Turning off the phone... 18:35:43 Done. you see everything is ok now STEP 3 just flash the phone 100% phone repair and unlock good luck guys dont be jealous say thanks anytime |
just need to attach again to put back to red_cid52/53 & then after to customize fs only.... anyway, more successfull gdfs wotp repair to come.... .:Live a Happy Life:. |
good work........................ |
S 500 another repair phone here is the first log Code: 15:10:45 SE Ultimate Unlocker v3.07 by Cruiser Team Code: 15:16:27 SE Ultimate Unlocker v3.07 by Cruiser Team after Step 3 flash the phone and all be ok |
T650 repaired by cruiser First Log 19:21:52 D-Ultimate Unlocker v3.07 by Cruiser Team 19:21:52 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 19:21:52 Initializing... ! 19:21:52 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 19:21:52 2. Choose the phone model ! 19:21:52 3. Select the desired options ! 19:21:52 4. Please connect the phone either via USB while holding 2-5… ! 19:21:52 - or via a serial cable and double-click on it in the device list 19:22:02 Selected phone: T650/T658 19:22:02 Connecting via Cruiser UC-10 Cable (COM5)… 19:22:02 Device driver version: 1.0.2154.0 19:22:02 Device driver date: 4-16-2004 19:22:02 Connecting to the baseband CPU... 19:22:03 Entering baseband CPU service mode... 19:22:03 Detected chipset: DB2020 19:22:03 Boot mode: ROM 19:22:03 Sending loader... 19:22:04 IMEI: 35796601343768 19:22:04 OTP CID: 51 19:22:04 Effective CID: 52 19:22:04 Restarting phone … 19:22:07 Sending loader... 19:22:07 Communicating with server… ! 19:22:09 News: Your credit consumption policy: Level 2 (Junior) 19:22:10 Remainig credit (supreme): 1.75 19:22:11 Remainig credit (supreme): 1.50 19:22:12 Restarting phone … 19:22:14 Sending loader... E 19:23:18 Error: 0x6C729765 E 19:23:18 Error: 0x8CDFAB78 E 19:23:18 Error: 0xFA7863EC E 19:23:18 Error: 0x780BA8B0 E 19:23:18 Error: 0x599D63C1 E 19:23:18 Error: 0x10BE36DC E 19:23:18 Error: 0x59AF7680 E 19:23:18 GDFS start-up problem E 19:23:18 Failed! ! 19:23:18 To report errors right-click this window Second Log after phone alive 19:23:31 D-Ultimate Unlocker v3.07 by Cruiser Team 19:23:31 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 19:23:31 Initializing... ! 19:23:31 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 19:23:32 2. Choose the phone model ! 19:23:32 3. Select the desired options ! 19:23:32 4. Please connect the phone either via USB while holding 2-5… ! 19:23:32 - or via a serial cable and double-click on it in the device list 19:24:53 Selected phone: T650/T658 19:24:53 Connecting via Cruiser UC-10 Cable (COM5)… 19:24:53 Device driver version: 1.0.2154.0 19:24:53 Device driver date: 4-16-2004 19:24:54 Connecting to the baseband CPU... 19:24:54 Entering baseband CPU service mode... 19:24:54 Detected chipset: DB2020 19:24:54 Boot mode: ROM 19:24:55 Sending loader... 19:24:55 IMEI: 35796601343768 19:24:55 OTP CID: 51 19:24:55 Effective CID: 49 19:24:55 Restarting phone … 19:24:58 Sending loader... 19:25:01 Code NCK for relock: 4350630564594689 19:25:01 Code NSCK for relock: 3773162433054794 19:25:01 Code SPCK for relock: 9179256305355505 19:25:01 Code CCK for relock: 3562905136331917 19:25:02 Code PCK for relock: 1422659573774033 19:25:02 Code ESLCK for relock: 5555435896341179 19:25:02 Code NCK for unlock: 9533677208894140 19:25:02 Code NSCK for unlock: 0194205899477129 19:25:02 Code SPCK for unlock: 9298327088737934 19:25:02 Code CCK for unlock: 1295598283834795 19:25:02 Code PCK for unlock: 3986489079431107 19:25:02 Code ESLCK for unlock: 0257161852418521 19:25:02 To enter a code, type < * * < on the phone with SIM-card inserted 19:25:02 Writing flash… 19:25:03 Turning off the phone... 19:25:05 Done. |
k530 repaired by cruiser First log 12:41:05 D-Ultimate Unlocker v3.07 by Cruiser Team 12:41:05 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 12:41:05 Initializing... ! 12:41:05 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 12:41:05 2. Choose the phone model ! 12:41:05 3. Select the desired options ! 12:41:05 4. Please connect the phone either via USB while holding 2-5… ! 12:41:05 - or via a serial cable and double-click on it in the device list 12:41:29 Selected phone: K530 12:41:30 Connecting via Cruiser UC-10 Cable (COM5)… 12:41:30 Device driver version: 1.0.2154.0 12:41:30 Device driver date: 4-16-2004 12:41:30 Connecting to the baseband CPU... 12:41:31 Entering baseband CPU service mode... 12:41:31 Detected chipset: DB2020 12:41:31 Boot mode: ROM 12:41:31 Sending loader... 12:41:32 IMEI: 35602702123531 12:41:32 OTP CID: 51 12:41:32 Effective CID: 53 12:41:32 Restarting phone … 12:41:34 Sending loader... 12:41:35 Communicating with server… ! 12:41:37 News: Your credit consumption policy: Level 2 (Junior) 12:41:37 Remainig credit (supreme): 2.25 12:41:39 Remainig credit (supreme): 2.00 12:41:40 Restarting phone … 12:41:43 Sending loader... E 12:42:47 Error: 0x6C729765 E 12:42:47 Error: 0x8CDFAB78 E 12:42:47 Error: 0xFA7863EC E 12:42:47 Error: 0x780BA8B0 E 12:42:48 Error: 0x599D63C1 E 12:42:48 Error: 0x10BE36DC E 12:42:48 Error: 0x59AF7680 E 12:42:48 GDFS start-up problem E 12:42:48 Failed! ! 12:42:48 To report errors right-click this window Second log after phone alive 12:42:57 D-Ultimate Unlocker v3.07 by Cruiser Team 12:42:57 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 12:42:57 Initializing... ! 12:42:57 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 12:42:57 2. Choose the phone model ! 12:42:57 3. Select the desired options ! 12:42:57 4. Please connect the phone either via USB while holding 2-5… ! 12:42:57 - or via a serial cable and double-click on it in the device list 12:43:25 Selected phone: K530 12:43:25 Connecting via Cruiser UC-10 Cable (COM5)… 12:43:25 Device driver version: 1.0.2154.0 12:43:25 Device driver date: 4-16-2004 12:43:25 Connecting to the baseband CPU... 12:43:26 Entering baseband CPU service mode... 12:43:26 Detected chipset: DB2020 12:43:26 Boot mode: ROM 12:43:26 Sending loader... 12:43:27 IMEI: 35602702123531 12:43:27 OTP CID: 51 12:43:27 Effective CID: 49 12:43:27 Restarting phone … 12:43:29 Sending loader... 12:43:34 Code NCK for relock: 4798312788889691 12:43:34 Code NSCK for relock: 6431088540153972 12:43:34 Code SPCK for relock: 9898335778068708 12:43:34 Code CCK for relock: 4110085970119213 12:43:34 Code PCK for relock: 0958942155459042 12:43:34 Code ESLCK for relock: 5035098376951711 12:43:34 Code NCK for unlock: 9744464332000454 12:43:34 Code NSCK for unlock: 9201702467757115 12:43:34 Code SPCK for unlock: 3977416664469868 12:43:34 Code CCK for unlock: 4155484724707960 12:43:34 Code PCK for unlock: 9847423304048790 12:43:34 Code ESLCK for unlock: 1607346315072990 12:43:34 To enter a code, type < * * < on the phone with SIM-card inserted 12:43:34 Writing flash… 12:43:36 Turning off the phone... 12:43:38 Done. also success repaired for w880 and w850 |
Code: 15:05:59 SE Ultimate Unlocker v3.07 by Cruiser Team What is wrong ? |
wrong is problem at server. the time i try same problem. |
thank you bro unlocker but i could not tried your manner cause since i bought cruiser dongle reseller of gsmserver lied me selling none supreme credits as he promised |
repair GDFS for DB2020 need credit as i see! anyways i don't have supreme log price too much for me. but let me know something, when phone refuse to "could start gdfs" we need repair it !i would like to know if in soft ultimate unlocker we should select gdfs reconstruction or only Repair Erom/ SEMC boot? |
r306 ???????????????????????????????????????? |
Repair Erom/Semc boot Show codes Set Cerificate to......52 or 53 |
S 500 another one GDFS repair Code: 17:58:54 SE Ultimate Unlocker v3.07 by Cruiser Team Step 2 Code: 18:07:20 SE Ultimate Unlocker v3.07 by Cruiser Team without open phone |
Another S 500 repaired first logo Code: 19:32:50 SE Ultimate Unlocker EXPERIMENTAL VERSION v3.10 by Cruiser Team second logo Code: 19:39:02 SE Ultimate Unlocker EXPERIMENTAL VERSION v3.10 by Cruiser Team everything ok |
w 880 red blink gdfs repaired First logo Code: 10:05:54 SE Ultimate Unlocker v4.01 by Cruiser Team Code: ! 10:20:52 - for W880/W888 phone, connect it while holding 2-* instead of 2-5 ok 100% repaired |
