Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 40
Member: 3617 Status: Offline Thanks: 549
| Tested and 100% procedure Repairing Gdfs in DB2020 with cruiser From My experience i want to share this procedure 1..connect and do repair gdfs see the log here Code: 18:26:12 SE Ultimate Unlocker v3.07 by Cruiser Team 18:26:12 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 18:26:12 Initializing... ! 18:26:12 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 18:26:12 2. Choose the phone model ! 18:26:12 3. Select the desired options ! 18:26:12 4. Please connect the phone either via USB while holding 2-5… ! 18:26:12 - or via a serial cable and double-click on it in the device list 18:26:38 Selected phone: K770 18:26:38 Connecting via Generic EMP USB Flash Device (USB1)… 18:26:38 Device driver version: 2.2.0.2 18:26:38 Device driver date: 12-5-2008 18:26:38 Connecting to the baseband CPU... 18:26:38 Entering baseband CPU service mode... 18:26:38 Detected chipset: DB2020 18:26:38 Boot mode: ROM 18:26:38 Sending loader... 18:26:39 IMEI: 35238402484393 18:26:39 OTP CID: 51 18:26:39 Effective CID: 53 18:26:41 Please reconnect the phone (disconnect, connect while holding 2-5) 18:26:51 Sending loader... 18:26:51 Communicating with server… ! 18:26:56 News: Your credit consumption policy: Level 1 (Novice) 18:26:56 Remainig credit (supreme): 0.78 18:26:59 Remainig credit (supreme): 0.45 18:27:02 Please reconnect the phone (disconnect, connect while holding 2-5) 18:27:10 Sending loader... E 18:28:17 Error: 0x6C729765 E 18:28:17 Error: 0x8CDFAB78 E 18:28:17 Error: 0xFA7863EC E 18:28:17 Error: 0x780BA8B0 E 18:28:18 Error: 0x599D63C1 E 18:28:18 Error: 0x10BE36DC E 18:28:18 Error: 0x59AF7680 E 18:28:18 GDFS start-up problem E 18:28:18 Failed! ! 18:28:18 To report errors right-click this windowit seems it is not ok reparing till now but i leave the phone about 10 second i switch on the phone and wating about 20 sec 2.phone now is alive after i reaatch the phone see the log here Code: 18:35:11 SE Ultimate Unlocker v3.07 by Cruiser Team 18:35:11 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 18:35:11 Initializing... ! 18:35:11 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 18:35:11 2. Choose the phone model ! 18:35:11 3. Select the desired options ! 18:35:11 4. Please connect the phone either via USB while holding 2-5… ! 18:35:11 - or via a serial cable and double-click on it in the device list 18:35:26 Selected phone: K770 18:35:26 Connecting via Generic EMP USB Flash Device (USB1)… 18:35:26 Device driver version: 2.2.0.2 18:35:26 Device driver date: 12-5-2008 18:35:26 Connecting to the baseband CPU... 18:35:26 Entering baseband CPU service mode... 18:35:26 Detected chipset: DB2020 18:35:26 Boot mode: ROM 18:35:26 Sending loader... 18:35:27 IMEI: 35238402484393 18:35:27 OTP CID: 51 18:35:27 Effective CID: 49 18:35:29 Please reconnect the phone (disconnect, connect while holding 2-5) 18:35:36 Sending loader... 18:35:39 Code NCK for relock: 9211324260753353 18:35:39 Code NSCK for relock: 1969954361064952 18:35:39 Code SPCK for relock: 9085525849448979 18:35:39 Code CCK for relock: 8635265339788044 18:35:40 Code PCK for relock: 3134626068517252 18:35:40 Code ESLCK for relock: 3219847942181935 18:35:40 Code NCK for unlock: 8962651602873649 18:35:40 Code NSCK for unlock: 5786406576009437 18:35:40 Code SPCK for unlock: 6369006569470688 18:35:40 Code CCK for unlock: 3245219438451312 18:35:40 Code PCK for unlock: 6279660297678806 18:35:40 Code ESLCK for unlock: 2816940829488474 18:35:41 To enter a code, type < * * < on the phone with SIM-card inserted 18:35:41 Writing flash… 18:35:41 Turning off the phone... 18:35:43 Done. you see everything is ok now STEP 3 just flash the phone 100% phone repair and unlock good luck guys dont be jealous say thanks anytime |
| The Following 8 Users Say Thank You to Unlocker AL For This Useful Post: |
| | #2 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2003 Location: Pearl of the Orient
Member: 42539 Status: Offline Thanks: 47
| Quote:
just need to attach again to put back to red_cid52/53 & then after to customize fs only.... anyway, more successfull gdfs wotp repair to come.... .:Live a Happy Life:. | |
| | #4 (permalink) |
| S 500 another repair phone here is the first log Code: 15:10:45 SE Ultimate Unlocker v3.07 by Cruiser Team 15:10:45 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 15:10:45 Initializing... ! 15:10:46 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 15:10:46 2. Choose the phone model ! 15:10:46 3. Select the desired options ! 15:10:46 4. Please connect the phone either via USB while holding 2-5… ! 15:10:46 - or via a serial cable and double-click on it in the device list 15:10:57 Selected phone: S500 15:10:57 Connecting via Cruiser UC-20 Cable (COM5)… 15:10:57 Device driver version: 2.4.6.0 15:10:57 Device driver date: 3-13-2008 15:10:59 Connecting to the baseband CPU... 15:11:00 Entering baseband CPU service mode... 15:11:00 Detected chipset: DB2020 15:11:00 Boot mode: ROM 15:11:01 Sending loader... 15:11:01 IMEI: 35683301299472 15:11:01 OTP CID: 51 15:11:01 Effective CID: 52 15:11:02 Restarting phone … 15:11:04 Sending loader... 15:11:05 Communicating with server… ! 15:11:10 News: Your credit consumption policy: Level 1 (Novice) 15:11:10 Remainig credit (supreme): 0.45 15:11:13 Remainig credit (supreme): 0.12 15:11:14 Restarting phone … 15:11:17 Sending loader... E 15:12:21 Error: 0x07F5EFDA E 15:12:21 Error: 0x6C729765 E 15:12:21 Error: 0x8CDFAB78 E 15:12:21 Error: 0xFA7863EC E 15:12:21 Error: 0x780BA8B0 E 15:12:21 Error: 0x599D63C1 E 15:12:21 Error: 0x10BE36DC E 15:12:21 Error: 0x59AF7680 E 15:12:21 GDFS start-up problem E 15:12:21 Failed! ! 15:12:22 To report errors right-click this window Code: 15:16:27 SE Ultimate Unlocker v3.07 by Cruiser Team 15:16:27 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 15:16:27 Initializing... ! 15:16:28 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 15:16:28 2. Choose the phone model ! 15:16:28 3. Select the desired options ! 15:16:28 4. Please connect the phone either via USB while holding 2-5… ! 15:16:28 - or via a serial cable and double-click on it in the device list 15:16:44 Selected phone: S500 15:16:44 Connecting via Cruiser UC-20 Cable (COM5)… 15:16:44 Device driver version: 2.4.6.0 15:16:44 Device driver date: 3-13-2008 15:16:46 Connecting to the baseband CPU... 15:16:50 Entering baseband CPU service mode... 15:16:50 Detected chipset: DB2020 15:16:50 Boot mode: ROM 15:16:50 Sending loader... 15:16:51 IMEI: 35683301299472 15:16:51 OTP CID: 51 15:16:51 Effective CID: 49 15:16:51 Restarting phone … 15:16:53 Sending loader... 15:16:58 Code NCK for relock: 4191962530676901 15:16:58 Code NSCK for relock: 2793318585382954 15:16:58 Code SPCK for relock: 0140697266690640 15:16:58 Code CCK for relock: 4546596519159528 15:16:58 Code PCK for relock: 6407561271650478 15:16:58 Code ESLCK for relock: 3232035534924325 15:16:58 Code NCK for unlock: 5486240869762821 15:16:58 Code NSCK for unlock: 0114584094083173 15:16:58 Code SPCK for unlock: 8717080542658898 15:16:58 Code CCK for unlock: 5798997695077323 15:16:58 Code PCK for unlock: 8725774441852235 15:16:58 Code ESLCK for unlock: 4113719017131350 15:16:58 To enter a code, type < * * < on the phone with SIM-card inserted 15:16:58 Writing flash… 15:17:00 Turning off the phone... 15:17:02 Done. after Step 3 flash the phone and all be ok |
| | #5 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2008
Member: 816217 Status: Offline Thanks: 27
| T650 repaired by cruiser First Log 19:21:52 D-Ultimate Unlocker v3.07 by Cruiser Team 19:21:52 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 19:21:52 Initializing... ! 19:21:52 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 19:21:52 2. Choose the phone model ! 19:21:52 3. Select the desired options ! 19:21:52 4. Please connect the phone either via USB while holding 2-5… ! 19:21:52 - or via a serial cable and double-click on it in the device list 19:22:02 Selected phone: T650/T658 19:22:02 Connecting via Cruiser UC-10 Cable (COM5)… 19:22:02 Device driver version: 1.0.2154.0 19:22:02 Device driver date: 4-16-2004 19:22:02 Connecting to the baseband CPU... 19:22:03 Entering baseband CPU service mode... 19:22:03 Detected chipset: DB2020 19:22:03 Boot mode: ROM 19:22:03 Sending loader... 19:22:04 IMEI: 35796601343768 19:22:04 OTP CID: 51 19:22:04 Effective CID: 52 19:22:04 Restarting phone … 19:22:07 Sending loader... 19:22:07 Communicating with server… ! 19:22:09 News: Your credit consumption policy: Level 2 (Junior) 19:22:10 Remainig credit (supreme): 1.75 19:22:11 Remainig credit (supreme): 1.50 19:22:12 Restarting phone … 19:22:14 Sending loader... E 19:23:18 Error: 0x6C729765 E 19:23:18 Error: 0x8CDFAB78 E 19:23:18 Error: 0xFA7863EC E 19:23:18 Error: 0x780BA8B0 E 19:23:18 Error: 0x599D63C1 E 19:23:18 Error: 0x10BE36DC E 19:23:18 Error: 0x59AF7680 E 19:23:18 GDFS start-up problem E 19:23:18 Failed! ! 19:23:18 To report errors right-click this window Second Log after phone alive 19:23:31 D-Ultimate Unlocker v3.07 by Cruiser Team 19:23:31 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 19:23:31 Initializing... ! 19:23:31 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 19:23:32 2. Choose the phone model ! 19:23:32 3. Select the desired options ! 19:23:32 4. Please connect the phone either via USB while holding 2-5… ! 19:23:32 - or via a serial cable and double-click on it in the device list 19:24:53 Selected phone: T650/T658 19:24:53 Connecting via Cruiser UC-10 Cable (COM5)… 19:24:53 Device driver version: 1.0.2154.0 19:24:53 Device driver date: 4-16-2004 19:24:54 Connecting to the baseband CPU... 19:24:54 Entering baseband CPU service mode... 19:24:54 Detected chipset: DB2020 19:24:54 Boot mode: ROM 19:24:55 Sending loader... 19:24:55 IMEI: 35796601343768 19:24:55 OTP CID: 51 19:24:55 Effective CID: 49 19:24:55 Restarting phone … 19:24:58 Sending loader... 19:25:01 Code NCK for relock: 4350630564594689 19:25:01 Code NSCK for relock: 3773162433054794 19:25:01 Code SPCK for relock: 9179256305355505 19:25:01 Code CCK for relock: 3562905136331917 19:25:02 Code PCK for relock: 1422659573774033 19:25:02 Code ESLCK for relock: 5555435896341179 19:25:02 Code NCK for unlock: 9533677208894140 19:25:02 Code NSCK for unlock: 0194205899477129 19:25:02 Code SPCK for unlock: 9298327088737934 19:25:02 Code CCK for unlock: 1295598283834795 19:25:02 Code PCK for unlock: 3986489079431107 19:25:02 Code ESLCK for unlock: 0257161852418521 19:25:02 To enter a code, type < * * < on the phone with SIM-card inserted 19:25:02 Writing flash… 19:25:03 Turning off the phone... 19:25:05 Done. |
| | #6 (permalink) |
| k530 repaired by cruiser First log 12:41:05 D-Ultimate Unlocker v3.07 by Cruiser Team 12:41:05 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 12:41:05 Initializing... ! 12:41:05 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 12:41:05 2. Choose the phone model ! 12:41:05 3. Select the desired options ! 12:41:05 4. Please connect the phone either via USB while holding 2-5… ! 12:41:05 - or via a serial cable and double-click on it in the device list 12:41:29 Selected phone: K530 12:41:30 Connecting via Cruiser UC-10 Cable (COM5)… 12:41:30 Device driver version: 1.0.2154.0 12:41:30 Device driver date: 4-16-2004 12:41:30 Connecting to the baseband CPU... 12:41:31 Entering baseband CPU service mode... 12:41:31 Detected chipset: DB2020 12:41:31 Boot mode: ROM 12:41:31 Sending loader... 12:41:32 IMEI: 35602702123531 12:41:32 OTP CID: 51 12:41:32 Effective CID: 53 12:41:32 Restarting phone … 12:41:34 Sending loader... 12:41:35 Communicating with server… ! 12:41:37 News: Your credit consumption policy: Level 2 (Junior) 12:41:37 Remainig credit (supreme): 2.25 12:41:39 Remainig credit (supreme): 2.00 12:41:40 Restarting phone … 12:41:43 Sending loader... E 12:42:47 Error: 0x6C729765 E 12:42:47 Error: 0x8CDFAB78 E 12:42:47 Error: 0xFA7863EC E 12:42:47 Error: 0x780BA8B0 E 12:42:48 Error: 0x599D63C1 E 12:42:48 Error: 0x10BE36DC E 12:42:48 Error: 0x59AF7680 E 12:42:48 GDFS start-up problem E 12:42:48 Failed! ! 12:42:48 To report errors right-click this window Second log after phone alive 12:42:57 D-Ultimate Unlocker v3.07 by Cruiser Team 12:42:57 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 12:42:57 Initializing... ! 12:42:57 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 12:42:57 2. Choose the phone model ! 12:42:57 3. Select the desired options ! 12:42:57 4. Please connect the phone either via USB while holding 2-5… ! 12:42:57 - or via a serial cable and double-click on it in the device list 12:43:25 Selected phone: K530 12:43:25 Connecting via Cruiser UC-10 Cable (COM5)… 12:43:25 Device driver version: 1.0.2154.0 12:43:25 Device driver date: 4-16-2004 12:43:25 Connecting to the baseband CPU... 12:43:26 Entering baseband CPU service mode... 12:43:26 Detected chipset: DB2020 12:43:26 Boot mode: ROM 12:43:26 Sending loader... 12:43:27 IMEI: 35602702123531 12:43:27 OTP CID: 51 12:43:27 Effective CID: 49 12:43:27 Restarting phone … 12:43:29 Sending loader... 12:43:34 Code NCK for relock: 4798312788889691 12:43:34 Code NSCK for relock: 6431088540153972 12:43:34 Code SPCK for relock: 9898335778068708 12:43:34 Code CCK for relock: 4110085970119213 12:43:34 Code PCK for relock: 0958942155459042 12:43:34 Code ESLCK for relock: 5035098376951711 12:43:34 Code NCK for unlock: 9744464332000454 12:43:34 Code NSCK for unlock: 9201702467757115 12:43:34 Code SPCK for unlock: 3977416664469868 12:43:34 Code CCK for unlock: 4155484724707960 12:43:34 Code PCK for unlock: 9847423304048790 12:43:34 Code ESLCK for unlock: 1607346315072990 12:43:34 To enter a code, type < * * < on the phone with SIM-card inserted 12:43:34 Writing flash… 12:43:36 Turning off the phone... 12:43:38 Done. also success repaired for w880 and w850 |
| | #7 (permalink) |
| Junior Member Join Date: Feb 2005 Age: 28
Member: 117121 Status: Offline Thanks: 0
| Code: 15:05:59 SE Ultimate Unlocker v3.07 by Cruiser Team 15:05:59 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 15:05:59 Initializing... ! 15:05:59 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 15:05:59 2. Choose the phone model ! 15:05:59 3. Select the desired options ! 15:05:59 4. Please connect the phone either via USB while holding 2-5… ! 15:05:59 - or via a serial cable and double-click on it in the device list 15:07:51 Selected phone: K770 15:07:51 Connecting via Generic EMP USB Flash Device (USB2)… 15:07:51 Device driver version: 2.2.0.2 15:07:51 Device driver date: 12-5-2008 15:07:52 Connecting to the baseband CPU... 15:07:52 Entering baseband CPU service mode... 15:07:52 Detected chipset: DB2020 15:07:52 Boot mode: ROM 15:07:52 Sending loader... 15:07:52 IMEI: 35223902084xxx 15:07:52 OTP CID: 51 15:07:52 Effective CID: 53 15:07:54 Please reconnect the phone (disconnect, connect while holding 2-5) 15:08:01 Sending loader... 15:08:01 Communicating with server… E 15:08:02 Error: 0x1F41CF97 E 15:08:02 Error: 0x41F19ADB E 15:08:02 Error: 0x51A411A0 E 15:08:02 Error: 0x78E56923 E 15:08:02 Error: 0x5C5AEBE3 E 15:08:02 Error: 0x3D35EAF1 E 15:08:02 Cannot connect to the server E 15:08:02 Failed! ! 15:08:02 To report errors right-click this window What is wrong ? |
| | #9 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Jun 2009 Location: Albania
Member: 1051603 Status: Offline Thanks: 29
| thank you bro unlocker but i could not tried your manner cause since i bought cruiser dongle reseller of gsmserver lied me selling none supreme credits as he promised |
| | #10 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks: 4
| repair GDFS for DB2020 need credit as i see! anyways i don't have supreme log price too much for me. but let me know something, when phone refuse to "could start gdfs" we need repair it !i would like to know if in soft ultimate unlocker we should select gdfs reconstruction or only Repair Erom/ SEMC boot? |
| | #12 (permalink) | |
| Quote:
Repair Erom/Semc boot Show codes Set Cerificate to......52 or 53 | |
| | #13 (permalink) |
| S 500 another one GDFS repair Code: 17:58:54 SE Ultimate Unlocker v3.07 by Cruiser Team 17:58:54 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 17:58:54 Initializing... ! 17:58:55 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 17:58:55 2. Choose the phone model ! 17:58:55 3. Select the desired options ! 17:58:55 4. Please connect the phone either via USB while holding 2-5… ! 17:58:55 - or via a serial cable and double-click on it in the device list 17:59:08 Selected phone: S500 17:59:08 Connecting via Cruiser UC-20 Cable (COM5)… 17:59:08 Device driver version: 2.4.6.0 17:59:08 Device driver date: 3-13-2008 17:59:10 Connecting to the baseband CPU... 17:59:12 Entering baseband CPU service mode... 17:59:12 Detected chipset: DB2020 17:59:12 Boot mode: ROM 17:59:13 Sending loader... 17:59:14 IMEI: 35683301145818 17:59:14 OTP CID: 51 17:59:14 Effective CID: 52 17:59:14 Restarting phone … 17:59:16 Sending loader... 17:59:17 Communicating with server… ! 17:59:21 News: Your credit consumption policy: Level 1 (Novice) 17:59:22 Remainig credit (supreme): 1.12 17:59:24 Remainig credit (supreme): 0.79 17:59:25 Restarting phone … 17:59:28 Sending loader... E 18:00:32 Error: 0x07F5EFDA E 18:00:32 Error: 0x6C729765 E 18:00:32 Error: 0x8CDFAB78 E 18:00:32 Error: 0xFA7863EC E 18:00:32 Error: 0x780BA8B0 E 18:00:32 Error: 0x599D63C1 E 18:00:32 Error: 0x10BE36DC E 18:00:32 Error: 0x59AF7680 E 18:00:32 GDFS start-up problem E 18:00:32 Failed! ! 18:00:32 To report errors right-click this window Step 2 Code: 18:07:20 SE Ultimate Unlocker v3.07 by Cruiser Team 18:07:20 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 18:07:20 Initializing... ! 18:07:20 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 18:07:20 2. Choose the phone model ! 18:07:20 3. Select the desired options ! 18:07:20 4. Please connect the phone either via USB while holding 2-5… ! 18:07:20 - or via a serial cable and double-click on it in the device list 18:07:23 Selected phone: S500 18:07:23 Connecting via Cruiser UC-20 Cable (COM5)… 18:07:23 Device driver version: 2.4.6.0 18:07:23 Device driver date: 3-13-2008 18:07:25 Connecting to the baseband CPU... 18:07:26 Entering baseband CPU service mode... 18:07:26 Detected chipset: DB2020 18:07:26 Boot mode: ROM 18:07:26 Sending loader... 18:07:27 IMEI: 35683301145818 18:07:27 OTP CID: 51 18:07:27 Effective CID: 49 18:07:27 Restarting phone … 18:07:30 Sending loader... 18:07:34 Code NCK for relock: 8784261666084085 18:07:34 Code NSCK for relock: 8242642106976457 18:07:34 Code SPCK for relock: 0342303983245603 18:07:34 Code CCK for relock: 2492049331885337 18:07:34 Code PCK for relock: 7464527885174329 18:07:34 Code ESLCK for relock: 8554617854667155 18:07:34 Code NCK for unlock: 6014114814840300 18:07:34 Code NSCK for unlock: 8131704403864263 18:07:34 Code SPCK for unlock: 3793758649846173 18:07:34 Code CCK for unlock: 0391335160108887 18:07:34 Code PCK for unlock: 4482134196480179 18:07:34 Code ESLCK for unlock: 5062721054858933 18:07:34 To enter a code, type < * * < on the phone with SIM-card inserted 18:07:35 Writing flash… 18:07:37 Turning off the phone... 18:07:39 Done. without open phone |
| | #14 (permalink) |
| Another S 500 repaired first logo Code: 19:32:50 SE Ultimate Unlocker EXPERIMENTAL VERSION v3.10 by Cruiser Team 19:32:50 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 19:32:50 Initializing... ! 19:32:51 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 19:32:51 2. Choose the phone model ! 19:32:51 3. Select the desired options ! 19:32:51 4. Please connect the phone either via USB while holding 2-5… ! 19:32:51 - or via a serial cable and double-click on it in the device list 19:32:53 Selected phone: S500 19:32:53 Connecting via Cruiser UC-20 Cable (COM5)… 19:32:53 Device driver version: 2.4.6.0 19:32:53 Device driver date: 3-13-2008 19:32:55 Connecting to the baseband CPU... 19:33:00 Entering baseband CPU service mode... 19:33:00 Detected chipset: DB2020 19:33:00 Boot mode: ROM 19:33:00 Sending loader... 19:33:01 IMEI: 35908501520870 19:33:01 OTP CID: 51 19:33:01 Effective CID: 52 19:33:01 Restarting phone … 19:33:04 Sending loader... 19:33:05 Communicating with server… ! 19:33:08 News: Your credit consumption policy: Level 1 (Novice) 19:33:09 Remainig credit (supreme): 2.06 19:33:11 Remainig credit (supreme): 1.73 19:33:12 Restarting phone … 19:33:15 Sending loader... E 19:34:19 Error: 0x6C729765 E 19:34:19 Error: 0x8CDFAB78 E 19:34:19 Error: 0xFA7863EC E 19:34:19 Error: 0x780BA8B0 E 19:34:19 Error: 0x599D63C1 E 19:34:19 Error: 0x10BE36DC E 19:34:19 Error: 0x59AF7680 E 19:34:19 GDFS start-up problem E 19:34:19 Failed! ! 19:34:19 To report errors right-click this window second logo Code: 19:39:02 SE Ultimate Unlocker EXPERIMENTAL VERSION v3.10 by Cruiser Team 19:39:02 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 19:39:02 Initializing... ! 19:39:03 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 19:39:03 2. Choose the phone model ! 19:39:03 3. Select the desired options ! 19:39:03 4. Please connect the phone either via USB while holding 2-5… ! 19:39:03 - or via a serial cable and double-click on it in the device list 19:40:12 Selected phone: S500 19:40:12 Connecting via Cruiser UC-20 Cable (COM5)… 19:40:12 Device driver version: 2.4.6.0 19:40:12 Device driver date: 3-13-2008 19:40:14 Connecting to the baseband CPU... 19:40:15 Entering baseband CPU service mode... 19:40:15 Detected chipset: DB2020 19:40:15 Boot mode: ROM 19:40:16 Sending loader... 19:40:17 IMEI: 35908501520870 19:40:17 OTP CID: 51 19:40:17 Effective CID: 49 19:40:17 Restarting phone … 19:40:19 Sending loader... 19:40:23 Code NCK for relock: 2553927851567034 19:40:23 Code NSCK for relock: 0064225560072770 19:40:23 Code SPCK for relock: 0486450659077687 19:40:23 Code CCK for relock: 0482354823392122 19:40:23 Code PCK for relock: 1718000968798826 19:40:23 Code ESLCK for relock: 3830954642889493 19:40:23 Code NCK for unlock: 3117537204612704 19:40:23 Code NSCK for unlock: 1724137177277547 19:40:24 Code SPCK for unlock: 7945169049237554 19:40:24 Code CCK for unlock: 4205547611868081 19:40:24 Code PCK for unlock: 3072141107618232 19:40:24 Code ESLCK for unlock: 0398456109744467 19:40:24 To enter a code, type < * * < on the phone with SIM-card inserted 19:40:24 Writing flash… 19:40:26 Turning off the phone... 19:40:28 Done. everything ok |
| | #15 (permalink) |
| w 880 red blink gdfs repaired First logo Code: 10:05:54 SE Ultimate Unlocker v4.01 by Cruiser Team 10:05:55 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 10:05:55 Initializing... ! 10:05:55 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 10:05:55 2. Choose the phone model ! 10:05:55 3. Select the desired options ! 10:05:55 4. Please connect the phone either via USB while holding 2-5… ! 10:05:55 - or via a serial cable and double-click on it in the device list ! 10:06:03 - for W880/W888 phone, connect it while holding 2-* instead of 2-5 10:06:46 Selected phone: W880/W888 10:06:46 Connecting via Cruiser UC-20 Cable (COM5)… 10:06:46 Device driver version: 2.4.6.0 10:06:46 Device driver date: 3-13-2008 10:06:48 Connecting to the baseband CPU... 10:06:49 Entering baseband CPU service mode... 10:06:49 Detected chipset: DB2020 10:06:49 Boot mode: ROM 10:06:50 Sending loader... 10:06:50 IMEI: 35159602248054 10:06:50 OTP CID: 51 10:06:50 Effective CID: 52 10:06:51 Restarting phone … 10:06:53 Sending loader... 10:06:54 Communicating with server… ! 10:06:57 News: Your credit consumption policy: Level 1 (Novice) 10:06:58 Remainig credit (supreme): 1.73 10:07:00 Remainig credit (supreme): 1.4 10:07:01 Restarting phone … 10:07:04 Sending loader... E 10:08:08 Error: 0x6C729765 E 10:08:08 Error: 0x8CDFAB78 E 10:08:08 Error: 0xFA7863EC E 10:08:08 Error: 0x780BA8B0 E 10:08:08 Error: 0x599D63C1 E 10:08:08 Error: 0x10BE36DC E 10:08:08 Error: 0x59AF7680 E 10:08:08 GDFS start-up problem E 10:08:08 Failed! ! 10:08:08 To report errors right-click this window Code: ! 10:20:52 - for W880/W888 phone, connect it while holding 2-* instead of 2-5 10:20:53 SE Ultimate Unlocker v4.01 by Cruiser Team 10:20:53 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 10:20:53 Initializing... ! 10:20:53 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 10:20:53 2. Choose the phone model ! 10:20:53 3. Select the desired options ! 10:20:53 4. Please connect the phone either via USB while holding 2-5… ! 10:20:53 - or via a serial cable and double-click on it in the device list 10:21:12 Selected phone: W880/W888 10:21:12 Connecting via Cruiser UC-20 Cable (COM5)… 10:21:12 Device driver version: 2.4.6.0 10:21:12 Device driver date: 3-13-2008 10:21:14 Connecting to the baseband CPU... 10:21:16 Entering baseband CPU service mode... 10:21:16 Detected chipset: DB2020 10:21:16 Boot mode: ROM 10:21:16 Sending loader... 10:21:17 IMEI: 35159602248054 10:21:17 OTP CID: 51 10:21:17 Effective CID: 49 10:21:17 Restarting phone … 10:21:20 Sending loader... 10:21:24 Code NCK for relock: 2764312326602703 10:21:24 Code NSCK for relock: 9889077906982632 10:21:24 Code SPCK for relock: 1295191116794385 10:21:24 Code CCK for relock: 2150848774177675 10:21:24 Code PCK for relock: 5268255851023269 10:21:24 Code ESLCK for relock: 8513561490144881 10:21:24 Code NCK for unlock: 0063386854383117 10:21:24 Code NSCK for unlock: 3920376174064603 10:21:24 Code SPCK for unlock: 3913026524102309 10:21:24 Code CCK for unlock: 7633213917118421 10:21:24 Code PCK for unlock: 6061355380866137 10:21:24 Code ESLCK for unlock: 1127649169810962 10:21:24 To enter a code, type < * * < on the phone with SIM-card inserted 10:21:24 Writing flash… 10:21:26 Turning off the phone... 10:21:28 Done. ok 100% repaired |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to Repair GDFS of K800 with Cruiser+ | rajinder1978 | Cruiser Suite | 3 | 04-10-2009 22:07 |
| Does cruiser can repair gdfs in w380 using credits | CHAGUA | Cruiser Suite | 1 | 12-27-2008 06:04 |
| LG KE500 tested and unlocking procedure 100% | Unlocker AL | FuriouS TeaM Products | 4 | 07-23-2008 10:40 |
| Exact Procedure repair Gdfs Db2020 Here | FullFLASHgSMPH | DreamBox | 7 | 05-02-2008 02:43 |
