Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 10-18-2007, 18:09   #1 (permalink)
Member: 324455
Thanks Meter: 3
testpoint first?
I have a W800i and a K800i to unlock i want to know before i use the cruiser box to unlock either one if i should do a testpoint unlock on these models first to ensure that the unlocking goes smoothly?
Craig
Old 10-18-2007, 18:21   #2 (permalink)
Super Moderator
THE CLASH's Avatar
Member: 173077
Sonork: 100.1594293
Thanks Meter: 2,783
You need to read the manual and search this forum,as for asking such silly question...NO, NO NO.
Old 10-18-2007, 18:25   #3 (permalink)
Member: 324455
Thanks Meter: 3
what manual? The one that was created since cruiser was at version 9 and it is now at 12? The one that doesn't tell any update on how to unlock any of these newer models? Ok sure thanks i will do just that.
Thanks for your response as well
Craig
Old 10-18-2007, 18:30   #4 (permalink)
mrmcox's Avatar
Member: 273918
Craig
No he means the up to date cruiser manual that you have installed on your PC.
Open cruiser click help then introduction. Voilla- a cruiser manaul
regards, mrmcox
Old 10-18-2007, 18:35   #5 (permalink)
Member: 324455
Thanks Meter: 3
regards, mrmcox
OHHHHHHHHH ok thanks mr cox
Old 10-18-2007, 18:39   #6 (permalink)
Super Moderator
THE CLASH's Avatar
Member: 173077
Sonork: 100.1594293
Thanks Meter: 2,783
Yes it does explain what to do, (i just checked).
the manual is on your pc, have you 12.10 installed.
ok, i will walk you through the W800. (easy unlock)
attach, you will see its a cid 36,
next on the security tab, you will see a box, CHANGE CERTIFAITE, from drop menue select brown 36,
change certifaite, now on locks tab, hit direct unlock, phone now unlocked ,
you dont have to change back to RED, phone will still work.
detach.
K800, now this is a different story, have you purchased logs, have you downloaded restore files.
add me to msn i will help you...
Old 10-18-2007, 18:44   #7 (permalink)
Member: 324455
Thanks Meter: 3
detach.
actually its w800i and its CID49, so k800 cannot be unlocked without logs? DAMN ok im adding you to msn now. thanks man
Old 10-18-2007, 18:55   #8 (permalink)
Super Moderator
THE CLASH's Avatar
Member: 173077
Sonork: 100.1594293
Thanks Meter: 2,783
DONT CHANGE THE CERTIFAITE then, its a different process, i will explain when we chat..
K800 stop on first testpoint fitserwis DreamBox 3 06-17-2008 09:34
First In The World: Nokia 6300 Testpoint Jig Ready ! fonesunlock Main Sales Section 0 09-30-2007 08:26
MX first in the world that change imei k1 without testpoint BESTDEALER Motorola P2k 6 08-07-2007 13:57
MX first in the world that change imei k1 without testpoint nnaeem11 GOT Motorola 0 07-07-2007 22:19
Setool-the First And Only Solution For Cid49-no Testpoint At Incredible Price !!! mobileland Main Sales Section 0 04-07-2006 20:38
Page generated in 0.19095 seconds with 9 queries
