09-26-2008, 13:39 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: nigeria
Member: 757064 Status: Offline Sonork: 11111111 Thanks Meter: 365 | Two w910 successfully unlock in less than two minutes Code: 13:28:40 SE Ultimate Unlocker v1.01 by Cruiser Team 13:28:40 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 13:28:41 Initializing... ! 13:28:41 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 13:28:41 2. Choose the phone model ! 13:28:41 3. Select the desired options ! 13:28:41 4. Please connect the phone either via USB while holding 2-5… ! 13:28:41 - or via a serial cable and double-click on it in the device list 13:29:32 Connecting via Generic EMP USB Flash Device (USB2)… 13:29:32 Device driver version: 2.0.0.4 13:29:32 Device driver date: 9-12-2007 13:29:33 Connecting to the baseband CPU... 13:29:33 Entering baseband CPU service mode... 13:29:33 Detected chipset: DB3150 13:29:33 Boot mode: ROM 13:29:34 Sending loader... 13:29:36 IMEI: 357392**************** 13:29:36 OTP CID: 52 13:29:36 Product type: Retail 13:29:36 Effective color: Red 13:29:37 Sending loader... 13:29:39 Communicating with server… 13:29:59 Remainig credit (supreme): 1.00 13:30:17 Remainig credit (supreme): 1.00 13:30:17 Converting phone to blue… 13:30:18 Please reconnect the phone (disconnect, connect while holding 2-5) 13:31:00 Sending loader... 13:31:02 IMEI: 35739202159889 13:31:02 OTP CID: 52 13:31:02 Product type: Retail 13:31:02 Effective color: Blue 13:31:03 Sending loader... 13:31:08 Code NCK for relock: 3168879106281683 13:31:08 Code NSCK for relock: 7860474037138896 13:31:08 Code SPCK for relock: 5747823364170356 13:31:08 Code CCK for relock: 9822763766136357 13:31:08 Code PCK for relock: 6340637792238677 13:31:08 Code ESLCK for relock: 8708142295916043 13:31:08 Code NCK for unlock: 6146322823374926 13:31:08 Code NSCK for unlock: 4694691454091700 13:31:08 Code SPCK for unlock: 0574100168928754 13:31:08 Code CCK for unlock: 3232877897580093 13:31:08 Code PCK for unlock: 3472634113959385 13:31:08 Code ESLCK for unlock: 5283917967042817 13:31:08 To enter a code, type < * * < on the phone with SIM-card inserted 13:31:08 Turning off the phone... 13:31:10 Done. ! 13:31:10 Please disconnect battery and cable from the phone! Code: 13:33:03 SE Ultimate Unlocker v1.01 by Cruiser Team 13:33:03 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 13:33:03 Initializing... ! 13:33:03 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 13:33:03 2. Choose the phone model ! 13:33:03 3. Select the desired options ! 13:33:03 4. Please connect the phone either via USB while holding 2-5… ! 13:33:03 - or via a serial cable and double-click on it in the device list 13:33:45 Connecting via Generic EMP USB Flash Device (USB2)… 13:33:45 Device driver version: 2.0.0.4 13:33:46 Device driver date: 9-12-2007 13:33:46 Connecting to the baseband CPU... 13:33:46 Entering baseband CPU service mode... 13:33:47 Detected chipset: DB3150 13:33:47 Boot mode: ROM 13:33:47 Sending loader... 13:33:49 IMEI: 35739202159904 13:33:49 OTP CID: 52 13:33:49 Product type: Retail 13:33:49 Effective color: Red 13:33:50 Sending loader... 13:33:52 Communicating with server… 13:34:15 Remainig credit (supreme): 1.00 13:34:47 Remainig credit (supreme): 1.00 13:34:47 Converting phone to blue… 13:34:47 Please reconnect the phone (disconnect, connect while holding 2-5) 13:35:12 Sending loader... 13:35:14 IMEI: 3573920************************* 13:35:14 OTP CID: 52 13:35:14 Product type: Retail 13:35:14 Effective color: Blue 13:35:16 Sending loader... 13:35:21 Code NCK for relock: 5553519929627970 13:35:21 Code NSCK for relock: 6822713518746076 13:35:21 Code SPCK for relock: 8624538953588044 13:35:21 Code CCK for relock: 5504034234960709 13:35:22 Code PCK for relock: 4325088385765596 13:35:22 Code ESLCK for relock: 3313359563265344 13:35:28 Code NCK for unlock: 0240155383120504 13:35:28 Code NSCK for unlock: 9498136587975466 13:35:28 Code SPCK for unlock: 7514922419309974 13:35:29 Code CCK for unlock: 7185592700428955 13:35:36 Code PCK for unlock: 4026948397163112 13:35:39 Code ESLCK for unlock: 3482770984187511 13:35:39 To enter a code, type < * * < on the phone with SIM-card inserted 13:35:39 Turning off the phone... 13:35:41 Done. ! 13:35:41 Please disconnect battery and cable from the phone! |
The Following User Says Thank You to skyulock For This Useful Post: |
09-26-2008, 15:33 | #4 (permalink) |
Super Moderator Join Date: Aug 2005 Location: UK.... Age: 57
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,783 | Its been said many times,,,, But just for you,,, You need 1 supreme credit in your Account, this is so you Can Access the server.(credit not used.) Untill END of September this Service is FREEEEEEE.. |
N78 unlock done in less than 2 minutes | d_installer99 | Nokia Base Band 5 ( BB-5 ) | 0 | 11-25-2009 12:32 |
HTC & T-Mobile G1 Code in less than 20 minutes 24/24, 7/7 Only at UnlockBase.com | UnlockBase.com | Main Sales Section | 0 | 11-11-2008 03:51 |
A2 W910 Unlocked with 4 Credits in less than 1 Minute | .::Gsm Killer::. | Sony Ericsson | 16 | 03-14-2008 11:46 |
