10-10-2008, 11:51 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: on a different planet
Member: 228253 Status: Offline Thanks Meter: 22 | ultimate logs |
10-10-2008, 13:23 | #2 (permalink) |
Registered User Join Date: Feb 2006 Location: Ireland / Belarus
Member: 234917 Status: Offline Thanks Meter: 160 | Where did you calculate 15 phones from?? Usage when you buy 3 D-unlocker credits (for use without 07 card) is .43 logs per phone which will give you 6 unlocks of A2 and also a DB2020 unlock as well. If you had a 07 card you would have been able to unlock 12 phones with 3 logs which is not expensive. The log usage is clearly explained here: http://www.cruisersuite.com/default....y_csca_credits |
10-10-2008, 13:57 | #3 (permalink) | |
No Life Poster Join Date: May 2009
Member: 67277 Status: Offline Thanks Meter: 5,588 | Quote:
http://www.cruisersuite.com/default....y_csca_credits | |
10-10-2008, 18:34 | #4 (permalink) | |
Member: 228253 Status: Offline Thanks Meter: 22 | Quote:
10-10-2008, 18:54 | #5 (permalink) | |
10-10-2008, 19:18 | #6 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ENGLAND
Member: 3811 Status: Offline Thanks Meter: 24 | same problem bought 1 supreme credit to unlock 5 a2 mobiles ( non smart card ) managed only to unlock 1 w910i then credit expired reseller also confused your pricing structure changed last night ???????????????????????? |
10-10-2008, 19:27 | #7 (permalink) |
Member: 234917 Status: Offline Thanks Meter: 160 | Pricing structure has been the same for nearly 2 weeks. Check here for proof: http:///vbb/showthread.php?t=603865 |
10-10-2008, 21:29 | #8 (permalink) | |
10-11-2008, 06:54 | #10 (permalink) |
Member: 67277 Status: Offline Thanks Meter: 5,588 | You simply cannot loose 1 for 1 phone if you used one of Ultimate Unlocker applications. Send here full log of communication from Ultimate Unlocker so we can see what was done? You can find it saved according to the path in help file. Send here also your username. |
10-11-2008, 12:15 | #11 (permalink) |
Member: 3811 Status: Offline Thanks Meter: 24 | @Mizar thanks for your quick responce here is the information requested Dear Customer Welcome to be part of CruserLog Team. Your User Account details as below: Account Type : D-Account (non-card) Login : user_246ff4cd Password : 808546 Total Standard Logs : 0.00 Total Supreme Logs : 1.00 Code: 21:58:07 D-Unlocker v2.13 by Cruiser Team 21:58:07 Initializing... ! 21:58:07 1. Please see the documentation first (a PDF installed with the application) ! 21:58:07 2. Make sure the appropriate phone modem drivers are installed ! 21:58:07 3. Fill in the connection settings under settings tab ! 21:58:07 4. Turn the phone ON ! 21:58:07 5. Connect the phone… 21:58:41 Connecting via SEMC WMC Device (COM9, COM10)… 21:58:41 Starting communication... 21:58:41 Communicating with server… 21:58:45 Remainig credit (supreme): 0.00 21:58:45 Restarting phone … 21:59:08 Connecting via SEMC USB Flash Device (USB2)… 21:59:08 Device driver version: 2.1.0.0 21:59:08 Device driver date: 3-20-2008 21:59:08 Starting communication... 21:59:08 Connecting to the baseband CPU... 21:59:08 Entering baseband CPU service mode... 21:59:09 Detected chipset: DB3150 21:59:09 Boot mode: EROM 21:59:09 Sending loader... 21:59:09 IMEI: 351829******** 21:59:09 OTP CID: 52 21:59:09 OTP area status: Locked 21:59:09 Product type: Retail 21:59:09 Effective color: Red 21:59:09 Sending loader... 21:59:12 Communicating with server… E 21:59:15 Error: 0xE1E2479D E 21:59:15 Error: 0xFEC2C417 E 21:59:15 Error: 0xFEC2C417 E 21:59:15 Error: 0xFEC2C417 E 21:59:15 Error: 0xFEC2C417 E 21:59:15 Error: 0xFEC2C417 E 21:59:15 Error: 0xFEC2C417 E 21:59:15 Error: 0x07F5EFDA E 21:59:16 Error: 0x05190628 E 21:59:16 Error: 0xFEC2C417 E 21:59:16 Error: 0xFEC2C417 E 21:59:16 Error: 0xFEC2C417 E 21:59:16 Error: 0xFEC2C417 E 21:59:16 Error: 0xFEC2C417 E 21:59:16 Not enough credit E 21:59:16 Error: 0xFEC2C417 E 21:59:16 Error: 0x07F5EFDA E 21:59:16 Error: 0x28FF3CA4 E 21:59:16 Failed! ! 21:59:16 Please disconnect battery and cable from the phone! ! 21:59:16 To report errors right-click this window many thanks |
10-11-2008, 14:52 | #12 (permalink) |
Freak Poster Join Date: Apr 2005
Member: 137814 Status: Offline Sonork: 113690 Thanks Meter: 3 | Well the blame is on you as you used D-Unlocker and not D-UltimateUnlocker Look at your log: 21:58:07 D-Unlocker v2.13 by Cruiser Team D-Unlocker consumes 1 credit pr phone, D-UltimateUnlocker consumes credits as Mizar explained earlier. Br kooolkat357 |
10-11-2008, 20:13 | #13 (permalink) |
Member: 3811 Status: Offline Thanks Meter: 24 | @kooolkat357 please understand not all members are as smart on these things as you please explain what is the purpose of D-Unlocker v2.13 if it ACCEPTS 1 supreme log (at 25 english pound each ) to unlock 1 A2 ... Any other members had the same problem or am i the only one ???????????? |
10-12-2008, 08:44 | #14 (permalink) | |
Member: 137814 Status: Offline Sonork: 113690 Thanks Meter: 3 | Quote:
The purpose of D-Unlocker are no different than D-UltimateUnlocker other than that D-Unlocker consumes 1 credit per phone and D-UltimateUlocker consumes credits as Mizar explained. Let me calculate. * If you bought 1 Supreme credit for non-card D-Ultimate Unlocker, consumption is 0.5 supreme credit / 1 A2 phone. So you can do totally 2 x A2 unlocks. * If you buy 1 Supreme credit for Cruiser Suite Ultimate Unlocker, consumption is 0.33 supreme credit / 1 A2 phone. So you can do totally 3 x A2 unlocks. * If you buy 5 Supreme credits for non-card D-Ultimate Unlocker, consumption is 0.33 supreme credits / 1 A2 phone. You can make 3 x A2 unlock per 1 supreme credit, totally 15 x A2 unlocks. * If you buy 5 Supreme credits for Cruiser Suite Ultimate Unlocker, consumption is 0.20 supreme credits / 1 A2 phone. So you can make 5 x A2 unlock per 1 supreme credit, totally 25 x A2 unlocks. The consumption of Supreme Credits depends only on qty bought at last purchase. You have to use D-Ultimate Unlocker or Cruiser Suite Ultimate Unlocker to get this consumption. D-Ultimate Unlocker - is successor of the D-Unlocker, it uses D-Unlocker account (username & password) As you can see of the cruiser announcement D-UltimateUnlocker are the successor of D-Unlocker, and therefore i think they want all users to use the D-UltimateUnlocker. May be therefore the consumption of credits are different between D-Unlocker and D-UltimateUnlocker. Br kooolkat357 @ www.d-unlockerserver.com | |
10-12-2008, 13:27 | #15 (permalink) |
Member: 3811 Status: Offline Thanks Meter: 24 | @kooolkat357 many thanks for your reply but still cannot see why if as you explain .... Well it's like this D-Unlocker and D-UltimateUnlocker are two different programs. and .... The purpose of D-Unlocker are no different than D-UltimateUnlocker other than that D-Unlocker consumes 1 credit per phone and D-UltimateUlocker consumes credits as Mizar explained. maybe good idea if d-unlocker is removed from server access to save confusion .................... |
is there any method to get d-ultimate log after loss | singh13 | D-Unlock Suite | 0 | 10-27-2009 13:34 |
who is supporter of ultimate logs | jesto80 | Cruiser Suite | 3 | 07-09-2009 23:55 |
Where to buy cheapest(hehe) logs Supreme logs for Ultimate Unlocker ? | GSMman187 | Cruiser Suite | 18 | 12-12-2008 15:15 |
d-client log can use for ultimate unlocker | gsmsky | D-Unlock Suite | 2 | 10-12-2008 12:15 |
ultimate logs | mickle1 | Cruiser Suite | 0 | 10-10-2008 11:52 |
