Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 10-10-2008, 11:51   #1 (permalink)
mickle1's Avatar
Member: 228253
Thanks Meter: 22
ultimate logs
yesterday i paid for 3 supreme logs what at the time of purchase would do 15 a2 phones today they will only do 6 that makes them the most expensive way of unlocking this type of phone on the market
Old 10-10-2008, 13:23   #2 (permalink)
Registered User
Member: 234917
Thanks Meter: 160
Where did you calculate 15 phones from?? Usage when you buy 3 D-unlocker credits (for use without 07 card) is .43 logs per phone which will give you 6 unlocks of A2 and also a DB2020 unlock as well. If you had a 07 card you would have been able to unlock 12 phones with 3 logs which is not expensive. The log usage is clearly explained here: http://www.cruisersuite.com/default....y_csca_credits
Old 10-10-2008, 13:57   #3 (permalink)
Member: 67277
Thanks Meter: 5,588
You did something wrong at your calculations. See this link and calculate the amount according qty phones bought and the level of consumption.
Old 10-10-2008, 18:34   #4 (permalink)
mickle1's Avatar
Member: 228253
Thanks Meter: 22
the calculations were made from my resseller who says you changed your logs last night
Old 10-10-2008, 18:54   #5 (permalink)
Member: 67277
Thanks Meter: 5,588
Nothing was changed last night. You can check all news in News section of www.cruisersuite.com. There are some new products like Cruiser Suite Ultimate Edition, and Starter Kit, but no price change.
Old 10-10-2008, 19:18   #6 (permalink)
Member: 3811
Thanks Meter: 24
same problem bought 1 supreme credit to unlock 5 a2 mobiles ( non smart card ) managed only to unlock 1 w910i then credit expired reseller also confused your pricing structure changed last night ????????????????????????
Old 10-10-2008, 19:27   #7 (permalink)
Registered User
Member: 234917
Thanks Meter: 160
Pricing structure has been the same for nearly 2 weeks. Check here for proof: http:///vbb/showthread.php?t=603865
Old 10-10-2008, 21:29   #8 (permalink)
Member: 67277
Thanks Meter: 5,588
Let me calculate.
  • If you bought 1 Supreme credit for non-card D-Ultimate Unlocker, consumption is 0.5 supreme credit / 1 A2 phone. So you can do totally 2 x A2 unlocks.
  • If you buy 1 Supreme credit for Cruiser Suite Ultimate Unlocker, consumption is 0.33 supreme credit / 1 A2 phone. So you can do totally 3 x A2 unlocks.
  • If you buy 5 Supreme credits for non-card D-Ultimate Unlocker, consumption is 0.33 supreme credits / 1 A2 phone. You can make 3 x A2 unlock per 1 supreme credit, totally 15 x A2 unlocks.
  • If you buy 5 Supreme credits for Cruiser Suite Ultimate Unlocker, consumption is 0.20 supreme credits / 1 A2 phone. So you can make 5 x A2 unlock per 1 supreme credit, totally 25 x A2 unlocks.
The consumption of Supreme Credits depends only on qty bought at last purchase. You have to use D-Ultimate Unlocker or Cruiser Suite Ultimate Unlocker to get this consumption.
Old 10-10-2008, 23:45   #9 (permalink)
Member: 3811
Thanks Meter: 24
@ Mizar many thanks for your explanation but as my post points out only managed to unlock 1 w910 then credit expired ??????????????????
Old 10-11-2008, 06:54   #10 (permalink)
Member: 67277
Thanks Meter: 5,588
You simply cannot loose 1 for 1 phone if you used one of Ultimate Unlocker applications. Send here full log of communication from Ultimate Unlocker so we can see what was done? You can find it saved according to the path in help file. Send here also your username.
Old 10-11-2008, 12:15   #11 (permalink)
Member: 3811
Thanks Meter: 24
@Mizar thanks for your quick responce here is the information requested
Dear Customer
Welcome to be part of CruserLog Team.
Your User Account details as below:
Account Type : D-Account (non-card)
Login : user_246ff4cd
Password : 808546
Total Standard Logs : 0.00
Total Supreme Logs : 1.00
  21:58:07  D-Unlocker v2.13 by Cruiser Team
  21:58:07  Initializing...
! 21:58:07  1. Please see the documentation first (a PDF installed with the application)
! 21:58:07  2. Make sure the appropriate phone modem drivers are installed
! 21:58:07  3. Fill in the connection settings under settings tab
! 21:58:07  4. Turn the phone ON
! 21:58:07  5. Connect the phone…
  21:58:41  Connecting via SEMC WMC Device (COM9, COM10)…
  21:58:41  Starting communication...
  21:58:41  Communicating with server…
  21:58:45  Remainig credit (supreme): 0.00
  21:58:45  Restarting phone …
  21:59:08  Connecting via SEMC USB Flash Device (USB2)…
  21:59:08  Device driver version: 2.1.0.0
  21:59:08  Device driver date: 3-20-2008
  21:59:08  Starting communication...
  21:59:08  Connecting to the baseband CPU...
  21:59:08  Entering baseband CPU service mode...
  21:59:09  Detected chipset: DB3150
  21:59:09  Boot mode: EROM
  21:59:09  Sending loader...
  21:59:09  IMEI: 351829********
  21:59:09  OTP CID: 52
  21:59:09  OTP area status: Locked
  21:59:09  Product type: Retail
  21:59:09  Effective color: Red
  21:59:12  Communicating with server…
E 21:59:15  Error: 0xE1E2479D
E 21:59:15  Error: 0xFEC2C417
E 21:59:15  Error: 0x07F5EFDA
E 21:59:16  Error: 0x05190628
E 21:59:16  Error: 0xFEC2C417
E 21:59:16  Not enough credit
E 21:59:16  Error: 0x07F5EFDA
E 21:59:16  Error: 0x28FF3CA4
E 21:59:16  Failed!
! 21:59:16  Please disconnect battery and cable from the phone!
! 21:59:16  To report errors right-click this window
had first unlocked W910i no problem ..........................
many thanks
Old 10-11-2008, 14:52   #12 (permalink)
Member: 137814
Sonork: 113690
Thanks Meter: 3
Well the blame is on you as you used D-Unlocker and not D-UltimateUnlocker
Look at your log: 21:58:07 D-Unlocker v2.13 by Cruiser Team
D-Unlocker consumes 1 credit pr phone, D-UltimateUnlocker consumes credits as Mizar explained earlier.
kooolkat357
Old 10-11-2008, 20:13   #13 (permalink)
Member: 3811
Thanks Meter: 24
@kooolkat357 please understand not all members are as smart on these things as you please explain what is the purpose of D-Unlocker v2.13 if it ACCEPTS 1 supreme log (at 25 english pound each ) to unlock 1 A2 ...
Any other members had the same problem or am i the only one ????????????
Old 10-12-2008, 08:44   #14 (permalink)
Member: 137814
Sonork: 113690
Thanks Meter: 3
Well it's like this D-Unlocker and D-UltimateUnlocker are two different programs.
The purpose of D-Unlocker are no different than D-UltimateUnlocker other than that D-Unlocker consumes 1 credit per phone and D-UltimateUlocker consumes credits as Mizar explained.
Let me calculate.
* If you bought 1 Supreme credit for non-card D-Ultimate Unlocker, consumption is 0.5 supreme credit / 1 A2 phone. So you can do totally 2 x A2 unlocks.
* If you buy 1 Supreme credit for Cruiser Suite Ultimate Unlocker, consumption is 0.33 supreme credit / 1 A2 phone. So you can do totally 3 x A2 unlocks.
* If you buy 5 Supreme credits for non-card D-Ultimate Unlocker, consumption is 0.33 supreme credits / 1 A2 phone. You can make 3 x A2 unlock per 1 supreme credit, totally 15 x A2 unlocks.
* If you buy 5 Supreme credits for Cruiser Suite Ultimate Unlocker, consumption is 0.20 supreme credits / 1 A2 phone. So you can make 5 x A2 unlock per 1 supreme credit, totally 25 x A2 unlocks.
D-Ultimate Unlocker
- is successor of the D-Unlocker, it uses D-Unlocker account (username & password)
As you can see of the cruiser announcement D-UltimateUnlocker are the successor of D-Unlocker, and therefore i think they want all users to use the D-UltimateUnlocker. May be therefore the consumption of credits are different between D-Unlocker and D-UltimateUnlocker.
kooolkat357 @ www.d-unlockerserver.com
Old 10-12-2008, 13:27   #15 (permalink)
Member: 3811
Thanks Meter: 24
@kooolkat357 many thanks for your reply but still cannot see why if as you explain ....
and ....
maybe good idea if d-unlocker is removed from server access to save confusion ....................
is there any method to get d-ultimate log after loss singh13 D-Unlock Suite 0 10-27-2009 13:34
who is supporter of ultimate logs jesto80 Cruiser Suite 3 07-09-2009 23:55
Where to buy cheapest(hehe) logs Supreme logs for Ultimate Unlocker ? GSMman187 Cruiser Suite 18 12-12-2008 15:15
d-client log can use for ultimate unlocker gsmsky D-Unlock Suite 2 10-12-2008 12:15
ultimate logs mickle1 Cruiser Suite 0 10-10-2008 11:52
Page generated in 0.29957 seconds with 10 queries
