03-16-2009, 18:35 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 39
Member: 138583 Status: Offline Thanks Meter: 120 | Big problem w810 cid50 I tried to repair and I get this: Code: 11:31:08 SE Ultimate Unlocker v3.07 by Cruiser Team 11:31:08 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 11:31:08 Initializing... ! 11:31:08 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 11:31:08 2. Choose the phone model ! 11:31:08 3. Select the desired options ! 11:31:08 4. Please connect the phone either via USB while holding 2-5… ! 11:31:08 - or via a serial cable and double-click on it in the device list 11:31:19 Selected phone: W200 11:31:19 Connecting via Generic FTDI Cable (COM11)… 11:31:19 Device driver version: 2.0.0.0 11:31:19 Device driver date: 5-19-2006 11:31:20 Connecting to the baseband CPU... 11:31:20 Entering baseband CPU service mode... 11:31:20 Detected chipset: DB2012 11:31:20 Boot mode: ROM 11:31:20 Sending loader... 11:31:21 IMEI: 35657301419133 11:31:21 OTP CID: 50 11:31:21 Effective CID: 51 11:31:21 Restarting phone … 11:31:23 Sending loader... E 11:31:28 Error: 0x916000B5 E 11:31:28 Error: 0x10BE36DC E 11:31:28 Error: 0x59AF7680 E 11:31:28 Failed! ! 11:31:28 To report errors right-click this window What can I do now? |
03-18-2009, 18:27 | #4 (permalink) |
Freak Poster Join Date: Dec 2006 Location: indonesia
Member: 412834 Status: Offline Thanks Meter: 215 | are this phone is realy sw problem???? maybe your phone is hw problem i think flash ic problem try this trick 1.flash it with cruiser 2.your phone is on now but only red blink and have error on costumize 3.repair it with ultimate unlocker and write gdfs to 4.costumize with cruiser again if your flash ic problem your phone can't powered on after stage 2 br. |
problem to unlock w810 cid50 | sonumobilewala | SETool2 | 23 | 09-26-2010 10:28 |
W810 cid50 probleme | cooloxf | Universalbox | 5 | 06-16-2009 11:29 |
W810 Cid50 Red Blink Problem......... | dil_PAKISTANI | SETool2 | 3 | 11-24-2008 09:03 |
w810 cid50 lock problem | nafg | Cruiser Suite | 2 | 10-14-2007 03:58 |
W810 Cid50 Attach Problem | CONCORDIA GSM | Universalbox | 0 | 10-02-2007 06:57 |
