06-02-2005, 14:18 | #1 (permalink) |
Freak Poster Join Date: May 2002 Location: Serbia Age: 42
Member: 11604 Status: Offline Thanks Meter: 7 | Unlocking K300i red CID36 method! -1- Open up your phone -2- Remove the shield form baseband part -3- Connect small wire to TP (as in picture) insulated wire!!! -4- Put your phone together (without the metal shield and front caseing) -5- Start Cruiser and attach phone -6- Go to "unlocking" tab and select "read codes" button -7- Wait for soft prompt for connecting the TP -8- Do it (connect TP tp GND) -9- Disconect the TP when told by the soft to do so DO NOT convert your phone to brown and DO NOT cut the test point!!! Flash files for K300i will follow soon, so be careful!!! Last edited by DeDaMrAz; 06-03-2005 at 23:45. |
06-02-2005, 16:31 | #3 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Boston
Member: 21920 Status: Offline Thanks Meter: 10 | This is a very useful tutorial Thank you. I am curious here, but did you solder the wire to the TP or attach it some other way? I would say it would be easier to use our old T610 cables with the battery clip and testpoint needle, no? And, finally, how about TPs for other phones? Last edited by evan_silbert; 06-02-2005 at 16:43. |
06-02-2005, 17:23 | #4 (permalink) |
Member: 11604 Status: Offline Thanks Meter: 7 | Well i attached TP with a very small (.0015 mm thick) wire and connected it to GND and it all went quite smooth. But you can always use old TP methods as long as you prefer them And for the TP pictures you will have to ask Lead because he is the one who releases them. regards. P.S. I assume that other phones will have similar methods of TP connection. |
06-03-2005, 21:38 | #6 (permalink) |
Insane Poster Join Date: May 2005 Age: 40
Member: 145385 Status: Offline Thanks Meter: 0 | i got few questions my friend, would u mind to teach me 1: how to open the metal cover on the phone's morther broad?? very hard , because the pictures show those are opened 2: i still dont understand how to connect all stuffs together, is using any metal wire connect from TP on the phone to GND ( usb cable connect with computer )??? thx |
06-04-2005, 00:05 | #8 (permalink) |
Member: 21920 Status: Offline Thanks Meter: 10 | You can find ground around the edge of the metal cover. I hope Cruiser testpoint cables with a VBAT alligator and GND needle will come from China soon.... hint to factories |
06-04-2005, 00:25 | #10 (permalink) |
Member: 21920 Status: Offline Thanks Meter: 10 | I can't see why those cables won't work. I don't have one though for Cruiser though I hope you're right about not needing TP, and I trust Lead, but this might take a while. For him to release this solution, he must have felt it would be a significant amount of time until he could relase another solution. |
06-04-2005, 00:29 | #11 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Sao Paulo - BRAZIL Age: 49
Member: 26751 Status: Offline Thanks Meter: 2 | Ok... Maybe you are right... but I don't think Lead will let other box ahead for too much time... as he said, TP will be neede in future CID releases but they will be supported faster... so I think older CIDS w/o TP will be always implemented fast... Anyway, let's wait what Lead will bring to us ;-) Cruiser was the 1st with CID36. No matter about TPs Regards, |
06-04-2005, 12:07 | #13 (permalink) |
No Life Poster Join Date: Jul 2004 Location: 0xBA, 0xBE Age: 38
Member: 73743 Status: Offline Thanks Meter: 2 | I bet Lead has plenty of reasons for doing what he is doing. Maybe i am foolish - but i trust Lead 100% in terms of Cruiser and i am sre there is always a reason behind his actions |
06-04-2005, 14:16 | #14 (permalink) |
Member: 21920 Status: Offline Thanks Meter: 10 | I agree, but I think in this case, testpoints should be avoided from more than a laziness perspective. SE already expected this and covered many testpoints with glue. Z800 has proven difficult to open without damage. I hope for an update without TP soon |
v600i language in red cid36 r2k005 | arturo1976 | Sony Ericsson | 0 | 03-19-2006 16:56 |
special red CID36 EROM file: (k750i) | green9 | Cruiser Suite | 1 | 09-08-2005 20:51 |
Need Recovery File for K300i red cid36 | taaz | Cruiser Suite | 4 | 07-19-2005 11:10 |
Any solutio to unlock K300i CID 36 RED retails phones? i get this erorr pls see?? | AE177 | Sony Ericsson | 12 | 05-30-2005 21:55 |
K300i RED CID36? | anduin | Cruiser Suite | 18 | 05-05-2005 14:27 |
