10-10-2005, 08:36 | #1 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 72567 Status: Offline Thanks Meter: 8 | Update Cruiser! Can not remove RSA on D750i with OTP CID 29 It seems that only Lead can fix the problem in Cruiser by updating the tool but he seems far away.. |
10-10-2005, 12:10 | #3 (permalink) | |
No Life Poster Join Date: Sep 2000 Location: Czech Republic
Member: 1993 Status: Offline Thanks Meter: 94 | Quote:
i had here also one of this PROTO too so this is what u must do: attach as CID36 - repair certificate repair EROM (brown36) flash R1k001 main flash and some filesystem all..... if still not work u must do this but also: format gdfs upload k750 gdfs recalc crc and all steps (brown36/erom/and R1K W800 (this filesystem needs no customization) so u will have fully ok W800 from that prototype and u must not unlock RSA (that not work) Eerchant | |
10-10-2005, 13:50 | #4 (permalink) |
Member: 72567 Status: Offline Thanks Meter: 8 | Thank you Eerchant The first alternative worked. Even if the phone is buggy with R1K it is better than dead. By formating the GDFS it is possible to revive the phone with full GDFS. I did not know that until now. Do you think Lead is preparing support for OTP CID 29 or are you also left in the dark? |
10-10-2005, 14:14 | #5 (permalink) | |
Eerchant | |
10-10-2005, 14:25 | #7 (permalink) | |
so as i say use R1K and HOPE that some day will be supported or some day will appear K750/W800 R1N035 that will be already signed with customization (5mins work for lead) Eerchant | |
10-25-2005, 09:17 | #11 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | yes, i have same problem about the RSA . show me: Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Phone color: None Flash certificate: - Trying CID29 recovery applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D The OTP area is unlocked! Phone hardware initialized OK Analyzing RSA protection... RSA protection is normal. |
10-25-2005, 09:21 | #13 (permalink) |
Member: 79315 Status: Offline Thanks Meter: 6,024 | and i can not flash any ARM files, when i try to format GDFS but show me : No suitable applet found. Error: Could not initialize GDFS access. ??? how to? |
02-17-2006, 01:34 | #15 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Quote:
Can you post a log of the problem? Also tell us what version you're using? Tim | |
problem cruiser can not unlock z310a cid 52 | increas | Cruiser Suite | 1 | 11-23-2007 22:39 |
How to remove rsa on the div5 and what is privileged instructions? | mobilestation | DIV | 5 | 11-25-2004 05:16 |
When i removed RSA on t610 phone are death....any solution? | piscancek | Sony Ericsson | 23 | 10-20-2004 22:56 |
Cannot Remove RSA on T630 | apple inside | Cruiser Suite | 13 | 10-07-2004 15:51 |
can i remove simlock on MX7931 with code? | L_DIM2003 | Various | 0 | 01-20-2004 09:24 |
