09-08-2005, 16:07 | #1 (permalink) |
Junior Member Join Date: Jan 2005 Age: 44
Member: 111436 Status: Offline Thanks Meter: 0 | v600i freeze after covert to k600i I converted my v600i to k600i using the standard procedure mentioned in the CID36 FAQ, now the phone boots fine, but after one minute into the system it will freeze, only thing can do is to remove the battery. Phone type is RED36, now converted to brown36. Flash ID: 0x890D Tried flash several times but no luck. Firmware used is R2j005 download from support section. Pls HELP AT EARLIEST CONVENIENCE!!! |
11-05-2005, 11:13 | #7 (permalink) |
Insane Poster Join Date: Apr 2004 Age: 44
Member: 64149 Status: Offline Thanks Meter: 0 | So LEAD please help us and find some solution Maybe other flash file in support Or I have to buy some other device for SE like MT-Box or USBSmart Maybe t solve my problem and some other in future BR Marcin |
12-30-2005, 00:54 | #10 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 50
Member: 104911 Status: Offline Thanks Meter: 42 | it only happens on about 5% of v600's when you convert them to a k600i,(there is a thread about it in tms section). I have only had one with this problem but it is easily fixed by used a different flash file, in my case i used r2k from setool. br james Last edited by James-R; 12-30-2005 at 01:31. |
The Following User Says Thank You to James-R For This Useful Post: |
12-30-2005, 01:15 | #11 (permalink) |
No Life Poster Join Date: Jun 2002 Location: *Portugal* Lisbon* Age: 45
Member: 13223 Status: Offline Thanks Meter: 59 | So if you had the badluck to have one of these phones in your hands, you have 2 choices.... 1.- Go to your Provider and request a dupe simcard with latest 64Kb and voltage technologies which exclusive supports R2J005 2.- Upgrade or Downgrade your phone only to R2F015 firmware... and your old simcard will work ok with your new phone and this firmware. cruiser don´t have this flash in suporte R2F015 |
12-30-2005, 01:30 | #12 (permalink) |
Member: 104911 Status: Offline Thanks Meter: 42 | yes, correct. i have cruiser/usb smart and setool, on setool site there is firmware r2k which fixes the problem. on cruiser there is only r2j. also the problem only happens when using a 3g sim, with a 2g sim it was ok. this is only my experience with v600i (vodafone) and k608i (uk 3), converting both to k600i all from the UK. br james |
E250i freezing after change to arabic, plz help | toms4gsm | UST Pro II | 6 | 10-10-2009 12:12 |
A727 freeze after try to unlock | chris2007 | UST Pro II | 8 | 05-28-2009 20:58 |
TV900 frist sim formated done but freeze after try to format sconed sim | Sudan-Mobiles | Infinity-Box | 3 | 02-21-2008 11:27 |
help in V600i freez after flash | tsarkh | Cruiser Suite | 0 | 10-06-2006 23:22 |
More problems after T68m coverted to T68i ... WAP & Shortcuts freezing | Burnt Cobba | Sony Ericsson | 4 | 09-19-2003 07:29 |
