02-29-2008, 10:25 | #1 (permalink) |
Freak Poster Join Date: Nov 2005 Location: UK
Member: 196365 Status: Offline Thanks Meter: 35 | V630i from Vodafone to K610i unbranded - RED/GREEN key problem I have V630i from vodafone, only way to have Polish (Polski) language is flashing as K610i and is all right without one: Vodafone have RED/GREEN keys , and in unbranded flash this two keys are for another function. Anyone have any patch to change that? regards |
03-25-2008, 16:18 | #6 (permalink) |
Freak Poster Join Date: Nov 2007
Member: 627885 Status: Offline Thanks Meter: 27 | Need to do this with V630i It was CID49 and I change to CID52 and flashed with these files as I need Lithuanian language K610i_CXC1250374_Generic_R1KC001_Red52.ck61sw & K610i_CXC1250376_Baltic_R1KC001_Red52.ck61fs Unlock went ok but now have red and green button issue. Problem is if I am to keep Lithuanian language, I must go back to CID49 flash to get ARM from V630i and RAW FS from K610i that match in versions Is it possible to flash CID49 into phone now as it has been changed to CID52? |
03-25-2008, 21:17 | #7 (permalink) |
Super Moderator Join Date: Aug 2005 Location: UK.... Age: 57
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | You unlock RSA, and you should be ok to cross flash, just dont forget you will need to unlock again (if patch unlocked) do this just before you customise FS. |
03-25-2008, 21:26 | #8 (permalink) |
Member: 627885 Status: Offline Thanks Meter: 27 | hope this works! will try now and post log <EDIT>so what you are saying is this: unlock rsa flash raw fs unlock rsa again??? flash arm direct unlock customize turn off phone </EDIT> |
03-25-2008, 21:44 | #10 (permalink) |
Member: 627885 Status: Offline Thanks Meter: 27 | System diagnostics passed. Version 13.01 ready! Do NOT connect the phone at this time! [ --- Attach to Phone --- ] Connecting via SEMC DCU-60... Connect the phone while holding its C button! USB connection established. Baseband chip ID: 0x9900 Protocol version: 3.1 Booting via EROM... Sony Ericsson phone detected. Phone CID: 52 Phone color: Red EROM version: R3A016 Trying CID52 recovery applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 0s Initializing phone hardware... Applet ID: 061220 1711 NPA4_CXC1329130_DB2020_... Flash manufacturer: ST Microelectronics Flash ID: 0x2019 OTP Security Level: 1 (Retail) OTP CID: 49 Phone CID: 52 Phone color: Red Sending applet... Applet ID: 061205 1523 HANCXC9876543210_DB2020... Sending applet... Applet ID: 061201 1314 HANCXC1329129_DB2020_FL... RSA protection state cannot be determined for this CID. Phone hardware initialized OK [ --- Unlock RSA --- ] Preparing to program flash... Programming flash... Time: 00:00:20 Flash process done. Preparing to program flash... Programming flash... Time: 00:00:02 Flash process done. Sending CS applet... Applet ID: 070410 1557 HANCXC1250562_DB2020_CS... Initializing CS applet... Starting up GDFS service... Starting up filesystem, please wait... Removing RSA lock... Restarting phone... Connect the phone while holding its C button! Sending applet... Sending applet prologue... Sending applet body... Applet ID: 061220 1711 NPA4_CXC1329130_DB2020_... Sending applet... Applet ID: 061201 1314 HANCXC1329129_DB2020_FL... Preparing to program flash... Programming flash... Time: 00:03:18 Flash process done. Please disconnect the phone and reinsert its battery! Connect the phone while holding its C button! Waiting for acknowledge... Please disconnect the phone and reinsert its battery! Connect the phone while holding its C button! Sending applet prologue... Sending applet body... Waiting for acknowledge... Applet ID: 070516 0311 CRU4_CXC1329130_DB2020_... Sending applet... Applet ID: 070516 0201 CRUCXC1329134_DB2020_PR... Done. [ --- Flash Raw File System --- ] Flash file: "K610i_CXC1250376_Baltic_R1GB001_Red51.ck61fs" Waiting for flash file to load... Preparing to program flash... Programming flash... Time: 00:00:55 Flash process done. [ --- Flash Main Firmware --- ] Flash file: "V630i_CXC1250556_Vodafone_R1GB001_Red51.cv63s w" Waiting for flash file to load... Preparing to program flash... Programming flash... Time: 00:03:43 Flash process done. [ --- Direct Unlock --- ] ****yzing firmware... Preparing for direct unlock... Processing... Status: Success [O] Creating firmware backup file... Preparing to program flash... Programming flash... Time: 00:00:02 Flash process done. If the phone cannot be turned on anymore, report its type and firmware version. Starting up GDFS service... Unlocking phone... Recalculating CRCs... Done. [ --- Customize File System --- ] Sending CS applet... Applet ID: 061114 0304 CRUCXC1250562_DB2020_CS... Initializing CS applet... Starting up GDFS service... Starting up filesystem, please wait... Building customization... Customizing phone... Done. Writing CDA Article MS string... New value: CDA102568/1 Done. Writing CDA Version MS string... New value: R4A Done. Writing Default Article MS string... New value: cxc1250376 Done. Writing Default Version MS string... New value: R1GB001 Done. Writing langpack string... New value: BALTIC Done. Writing country... New value: Generic Trade Done. [ --- Turn off Phone --- ] Turning off phone... Phone turned off. Phone automatically detached. Thank you to mily2 and THE_CLASH!!! All is well. Now red and green button work, but there is Ticker at bottom left of screen and now the left soft button above the green will not select Ticker so I can switch it off!! |
Mt-box - red - green blinking problem | Mgs | MT-BOX | 4 | 09-28-2009 05:36 |
c330 send/green key problem | okiki | Motorola Hardware Repair | 0 | 12-08-2005 09:52 |
MENU cnahge from Vodafone to original??? | civkar1 | ARM9 BASED M62 / M62+ | 0 | 08-19-2005 16:03 |
3300 RED and Green keys not working | Singh05 | Nokia Hardware & Hardware Repair | 6 | 08-13-2005 14:37 |
