12-14-2005, 19:03 | #1 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Sao Paulo - BRAZIL Age: 49
Member: 26751 Status: Offline Thanks Meter: 2 | V801sh problem Continue at your own risk... Please, disconnect phone and select its type manually. Report this TAC number together with phone type: 021753 Just attached a V801sh and got this msg. IMEI is note the same as the label. Is there a way to fix it? Best Regards, Sergio |
12-14-2005, 21:35 | #2 (permalink) |
Member: 26751 Status: Offline Thanks Meter: 2 | When trying to flash: Version 7.10 beta ready! Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd Sharp 3G phone detected. Phone CID: 24 Phone color: Brown Flash certificate: A1_SHARP_AS_CUSTOMER Trying Brown CID24 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x8910 OTP Security Level: 0 (Developer) OTP CID: 24 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 24 Primary certificate color: Brown Secondary certificate not found. OSE configuration found. Analysing GDFS... Done. Analyzing RSA protection... RSA protection is normal. Use the Unlock RSA function first! Flash file: "Sharp_V801SH_Full_Repair.flp" Waiting for flash file to load... Reading phone RSA certificate... Error: EAccessViolation |
12-15-2005, 16:54 | #5 (permalink) |
Member: 26751 Status: Offline Thanks Meter: 2 | It was just battery... but the problem persists... Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd Sharp 3G phone detected. Phone CID: 24 Phone color: Brown Flash certificate: A1_SHARP_AS_CUSTOMER Trying Brown CID24 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x8910 OTP Security Level: 0 (Developer) OTP CID: 24 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 24 Primary certificate color: Brown Secondary certificate not found. OSE configuration found. Analysing GDFS... Done. Analyzing RSA protection... RSA protection is weak. RSA protection weakness type: PERMANENT Flash file: "Sharp_V801SH_Full_Repair.flp" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Defeating RSA protection... Sending applet... Defeated! Sending applet... Baudrate = 921600Bd Programming flash... RSA protection was set back to normal. Time: 00:18:07 Flash process done. Now flash stops at 63% as it was really finished. Any suggestion? Regards, Sergio |
12-16-2005, 09:29 | #6 (permalink) | |
Major Poster Join Date: Nov 2005
Member: 203118 Status: Offline Thanks Meter: 0 | 801sh Quote:
BR | |
12-16-2005, 12:43 | #8 (permalink) | |
Member: 26751 Status: Offline Thanks Meter: 2 | Quote:
Regards, | |
12-20-2005, 09:25 | #11 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Timeless zone! Age: 35
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | Hi Mate, Lead should take some serious steps on it and he will think abt it becaz cruiser team is always great................Ok Br Muneeb Akhtar Raza |
acount id problem.help uregent plz [SOLVED] | dani2080 | PolarBox 3 | 2 | 03-29-2010 12:46 |
BIG PROBLEM V801SH & Cruiser :( :( | UnlockBR | Cruiser Suite | 9 | 02-12-2006 11:55 |
v801sh IMEI problem after Cruiser | UnlockBR | Cruiser Suite | 1 | 02-02-2006 17:20 |
v801sh imei problem | sahin_tr | Cruiser Suite | 0 | 11-19-2005 13:29 |
Problem With v801sh | afacandenis | Cruiser Suite | 1 | 07-01-2005 13:49 |
