08-09-2006, 23:45 | #1 (permalink) | ||
No Life Poster Join Date: Jan 2006 Location: Canada
Member: 219362 Status: Offline Thanks Meter: 31 | W-810i problem (urgent) I have a problem with a W-810i. I tried to unlock it according to these instructions, but I hit a snag after Step #5 below. Quote:
Any help would be appreciated. Thanks in advance. EDIT: I even tried a fresh fully charged battery - same result. | ||
08-10-2006, 00:27 | #2 (permalink) |
No Life Poster Join Date: Aug 2004 Location: US/DK/S
Member: 76964 Status: Offline Thanks Meter: 2 | Have you tried this thread: http://forum.gsmhosting.com/vbb/show...=313129&page=2 |
08-10-2006, 01:25 | #3 (permalink) | |
Member: 219362 Status: Offline Thanks Meter: 31 | Quote:
08-10-2006, 02:43 | #7 (permalink) | |
Now, for the restoral, I only have to unzip the file and hit "Restore Firmware" right? | |
08-10-2006, 02:58 | #8 (permalink) |
Member: 76964 Status: Offline Thanks Meter: 2 | I use this procedure to unlock and flash if I do not have the restoral file for the SW version on the phone. 1. Attach the phone to Cruiser 2. Unlock RSA 3. Do Unlock 4. Flash FS (before Main Flash because Main Flash Rebuild RSA Lock!!!) 5. Customise FS 6. Shut Down FS 7. Flash Main (and you don't need to flash the Restoration File because the Main Flash contains the RSA Part!!!) |
08-10-2006, 03:31 | #9 (permalink) | |
No response This may indicate damaged EROM area! This seems pretty bad... EDIT - I now get to the Customize FS part, but with the above message [ --- Customize File System --- ] Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Waiting for acknowledge... No response This may indicate damaged EROM area! This seems pretty bad... Last edited by Jazz; 08-10-2006 at 04:09. | |
08-10-2006, 07:56 | #10 (permalink) |
Member: 219362 Status: Offline Thanks Meter: 31 | Finally taken care of. Did the process for the third time, and this time, the entire procedure at the lowest Baud rate (115...). Everything went by without a hitch and all is good now..... Thanks all! |
08-10-2006, 16:15 | #11 (permalink) |
Member: 76964 Status: Offline Thanks Meter: 2 | Congrats! Shows that persistence is sometimes a good thing! You now have knowledge to help out on a majority of the issues people post here on the board after your struggle... Guess you can be considered an expert now ! |
acount id problem.help uregent plz [SOLVED] | dani2080 | PolarBox 3 | 2 | 03-29-2010 12:46 |
Cruiser Box Tech. Problem (Very Urgent) | ajubaba | Cruiser Suite | 7 | 09-17-2008 05:42 |
W-810i hang problem | maheshsaiganesh | Cruiser Suite | 0 | 08-08-2007 15:26 |
Problem with v1075 (Pls help urgent) | wolf_19 | Smart-Clip | 20 | 07-19-2007 06:45 |
