07-01-2008, 10:28 | #1 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks Meter: 200 | W200i unlock OK BUT still Insert correct sim card that is log: Quote:
The Following User Says Thank You to denard For This Useful Post: |
07-01-2008, 10:48 | #5 (permalink) | |
No Life Poster Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | Quote:
Hello Denard All ok ? Enter service menu with > * << * < * and check if not have 5 locks closed BR Max_B | |
07-01-2008, 16:14 | #8 (permalink) |
Freak Poster Join Date: Jun 2005
Member: 149975 Status: Offline Thanks Meter: 37 | i use javer fast unlocker 1.00 then i delete "executor" in game menu PHONE IS unlocked but call "CODE VERROU " code 0000 or1234 no work ,please Help This is log procédure 16:33:02 SE A1 Fast Java Unlocker v1.00 by Cruiser Team 16:33:02 Initialisation en cours… ! 16:33:02 1. Please see the documentation first (tab 'Info') ! 16:33:02 2. Choisir le model du telephone ! 16:33:02 3. Connecter le telephone en maintenant le bouton C… 16:34:21 Se connecte via SEMC USB Flash Device (USB1)… 16:34:21 Device driver version: 2.0.0.4 16:34:21 Device driver date: 9-12-2007 16:34:21 Connexion a la Baseband CPU en cours… 16:34:21 Baseband CPU service mode entrant… 16:34:22 Chipset detecte: DB2012 16:34:22 Boot mode: EROM 16:34:22 EROM version: R3A022 prgCXC1250729_EROM_DB2010_MELINDA_FOTA_SIMLOCK_FLA FLA_SIBLEY_SEMCUSB 16:34:22 Envoi du loader en cours… 16:34:22 Envoi du loader en cours… 16:34:24 Starting up System... 16:34:24 Starting up GDFS... 16:34:35 Starting up FS... 16:34:51 Effectue. ! 16:34:51 1. Disconnect the cable from the phone ! 16:34:51 2. Insert either a test-card or a SIM card which the phone accepts to the phone ! 16:34:51 3. Power on the phone by pressing the power ON/OFF button. ! 16:34:51 4. Go to the menu 'Entertainment' -> 'Games' and select/run the application 'executor' ! 16:34:51 5. Wait few seconds until the phone restarts by itself ! 16:34:51 6. Then the phone is unlocked, you may delete the 'executor' application from the phone |
The Following User Says Thank You to tewfik For This Useful Post: |
07-08-2008, 23:39 | #14 (permalink) |
Freak Poster Join Date: Mar 2008 Location: somali
Member: 717872 Status: Offline Sonork: 100.1589423 Thanks Meter: 22 | i can't unlock w200 cid 53 Code: 01:33:23 SE A1 Java Unlocker v1.10 by Cruiser Team 01:33:23 Initializing... ! 01:33:23 1. Choose the phone model ! 01:33:23 2. Select main firmware flash file (*.a1sw) ! 01:33:23 3. Select raw FS flash file (*.a1fs) ! 01:33:23 4. Please connect the phone while holding its C button… 01:34:01 Connecting via SEMC USB Flash Device (USB5)… 01:34:01 Device driver version: 1.0.0.8 01:34:01 Device driver date: 3-30-2006 01:34:01 Connecting to the baseband CPU... 01:34:01 Entering baseband CPU service mode... 01:34:01 Detected chipset: DB2012 01:34:01 Boot mode: EROM 01:34:01 EROM version: R3A023 prgCXC1250729_EROM_DB2010_MELINDA_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB 01:34:01 Initializing flash files... E 01:34:04 Error: 0x11B6D9FC E 01:34:04 Flash Firmware version is not supported. Try another version. E 01:34:04 Error: 0xD6C6C7B1 E 01:34:04 Error: 0xA8A269DB E 01:34:04 Error: 0xB63595F9 E 01:34:04 Cable disconnect detected E 01:34:04 Failed! ! 01:34:04 1. Please disconnect battery and cable from the phone! ! 01:34:04 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 01:34:04 3. Go to Entertainment and select Games. ! 01:34:04 4. Delete executor file. ! 01:34:04 5. Turn off the phone ! 01:34:04 To report errors right-click this window |
The Following User Says Thank You to baooshe2 For This Useful Post: |
07-08-2008, 23:49 | #15 (permalink) |
No Life Poster Join Date: Apr 2005 Location: between New Zealand - Canada Age: 42
Member: 135110 Status: Offline Thanks Meter: 302 | just read the log and do what is there written: E 01:34:04 Flash Firmware version is not supported. Try another version. |
The Following User Says Thank You to FilipLudvik For This Useful Post: |
Setool Pls Help w200i cid 52 Unlock Success but still Insert Correct Sim | dmaetrey | SETool2 | 32 | 05-06-2016 11:41 |
after unlock W580, still insert correct sim card | lamborghini | SETool2 | 27 | 05-19-2010 16:06 |
ke850 ***** unlocked succesfull ok but show insert right sim card | genci titi 2002 | Infinity-Box | 1 | 08-25-2009 17:25 |
ok.Tp -w200i cid 52 Unlock Success but still Insert Correct Sim | Nurettin Duman | Cruiser Suite | 5 | 11-02-2008 08:45 |
My W200 Unlock Sucess But Still Insert Correct Card | GSM-FUTURE | Seking Server | 13 | 04-17-2008 21:06 |
