Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 04-03-2009, 16:00   #1 (permalink)
Registered User
Member: 55026
Thanks Meter: 53
W200i unlock - serial cable - ok
when trying W200i always getting error, is this w200 different or something is going wrong?
  16:57:11  SE Ultimate Unlocker v3.07 by Cruiser Team
  16:57:11  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  16:57:11  Initializing...
! 16:57:11  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 16:57:11  2. Choose the phone model
! 16:57:11  3. Select the desired options
! 16:57:11  4. Please connect the phone either via USB while holding 2-5…
! 16:57:11  - or via a serial cable and double-click on it in the device list
  16:57:40  Selected phone: W200
  16:57:40  Connecting via SEMC USB Flash Device (USB1)…
  16:57:40  Device driver version: 2.2.0.0
  16:57:40  Device driver date: 9-18-2008
  16:57:41  Connecting to the baseband CPU...
  16:57:41  Entering baseband CPU service mode...
  16:57:41  Detected chipset: DB2012
  16:57:41  Boot mode: EROM
  16:57:41  EROM version: R3A022      prgCXC1250729_EROM_DB2010_MELINDA_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
E 16:57:41  Error: 0x889C690F
E 16:57:41  Unsupported boot mode
! 16:57:41  Please boot via ROM
E 16:57:41  Failed!
! 16:57:41  To report errors right-click this window
Old 04-03-2009, 16:03   #2 (permalink)
Registered User
Member: 55026
Thanks Meter: 53
problem solved with using figter cable!
Old 04-03-2009, 16:09   #3 (permalink)
FilipLudvik's Avatar
Member: 135110
Thanks Meter: 302
ofcourse.
If you read instructions written in manual, you would see that DB2012 is supported only via serial cables.
Old 05-23-2009, 14:26   #4 (permalink)
Member: 318507
Thanks Meter: 16
I can't get W200i to connect.
In the devices list in Ultimate Unlocker only the COM USB cable is listed. No serial option.
Old 05-23-2009, 15:48   #5 (permalink)
bogdanrex0's Avatar
Member: 289243
Thanks Meter: 15
HI there can you take a look when problem is hard or soft& how can i solve this problem
any helping will be very apreciated.thx in avdance
w.b.r. bogdanrex0
15:44:25 SE Ultimate Unlocker v3.07 by Cruiser Team
15:44:25 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
15:44:25 Initializing...
! 15:44:25 1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 15:44:25 2. Choose the phone model
! 15:44:25 3. Select the desired options
! 15:44:25 4. Please connect the phone either via USB while holding 2-5…
! 15:44:25 - or via a serial cable and double-click on it in the device list
15:44:42 Selected phone: W200
15:44:42 Connecting via Cruiser UC-10 Cable (COM3)…
15:44:42 Device driver version: 2.4.6.0
15:44:42 Device driver date: 3-13-2008
15:44:43 Connecting to the baseband CPU...
15:44:46 Entering baseband CPU service mode...
15:44:46 Detected chipset: DB2012
15:44:46 Boot mode: ROM
15:44:46 Sending loader...
15:44:47 IMEI: 35379602458655
15:44:47 OTP CID: 51
15:44:47 Effective CID: 51
15:44:47 Restarting phone …
15:44:49 Sending loader...
E 15:44:53 Error: 0xE1E2479D
E 15:44:53 Error: 0x916000B5
E 15:44:53 Error: 0x10BE36DC
E 15:44:53 Error: 0x59AF7680
E 15:44:53 Failed!
! 15:44:53 To report errors right-click this window
Old 05-23-2009, 15:48   #6 (permalink)
bogdanrex0's Avatar
Member: 289243
Thanks Meter: 15
Unhappy
i forget mention that model is w 200i and handset going to me in dead condition
Old 05-26-2009, 00:42   #7 (permalink)
bogdanrex0's Avatar
Member: 289243
Thanks Meter: 15
no response?!? no answer /!? need help but nobody answer where is support then?!?? please don,t sleep
w.b.r. bogdanrex0
Old 05-27-2009, 20:02   #8 (permalink)
Member: 1040359
Thanks Meter: 2
As i know, i select K320 model and ignore for error because you just need BROWN CID color... So you can repair gdfs without TP.
The Following User Says Thank You to iloveasih For This Useful Post:
Old 05-27-2009, 22:35   #9 (permalink)
nasagih's Avatar
Member: 551188
Sonork: 100.1580118
Thanks Meter: 59
w.b.r. bogdanrex0
look at here brother.......
w 200i gfds repair
Old 05-28-2009, 15:51   #10 (permalink)
bogdanrex0's Avatar
Member: 289243
Thanks Meter: 15
w 200i gfds repair
thanks bro for helping but agree with you it won't help due to" sending loader error" as you can see it's impossible to fix it w/o testpoint couse can't write gdfs into the phone better use other tool like sadtool etc... anyway thanks for all
w..r. bogdanrex0
Old 05-28-2009, 19:06   #11 (permalink)
nasagih's Avatar
Member: 551188
Sonork: 100.1580118
Thanks Meter: 59
you are welcome........
Old 06-08-2009, 07:10   #12 (permalink)
mdalamgir's Avatar
Member: 694638
Thanks Meter: 163
When I flash w200i cid52 with cruiser-07 alawyes Show 'sim erorr'.please anyone help me,how to flash w200i cid52 with cruiser/free tools.
plea...............s help.
thanks
Old 06-08-2009, 10:37   #13 (permalink)
nasagih's Avatar
Member: 551188
Sonork: 100.1580118
Thanks Meter: 59
thanks
post your log using 13.20...
Old 06-08-2009, 11:35   #14 (permalink)
Member: 1044145
Sonork: jafbox
hello guyz, i have w200i and i want to unlock it through setool2g, when i connect, it dosnt connect. even that i press "c" when i connect but it still dont connect. so what can i do? please help me
Old 06-08-2009, 11:36   #15 (permalink)
Member: 1044145
Sonork: jafbox
Thumbs down hello
need SERIAL cable old style COM cable to unlock kf900 ?? platinumLA FuriousGold 4 09-19-2009 00:10
w200i unlock ok but problem geepee777 DreamBox 8 10-16-2008 14:52
W200i unlock OK BUT still Insert correct sim card denard Cruiser Suite 16 07-11-2008 18:51
K750i serial cable from cheap "china" T28 serial cable csarlee Sony Ericsson 1 10-12-2005 07:23
Gx20 serial cable transform to gx30 serial?? Mobile Sharp 0 10-16-2004 00:23
Page generated in 0.43182 seconds with 8 queries
