07-15-2006, 09:58 | #1 (permalink) |
Junior Member Join Date: Jul 2006
Member: 311040 Status: Offline Thanks Meter: 0 | Cruiser!!! Is it a peac of crap or am i dummmmm?? After hearing a lot about Cruiser i decided to buy one. I ordered Cuiser Pro2 and when i received the product i was exited. Now, after 4 days i´m begining to give up. I installed the software in 3 PC´s and it keeps giving me the same results: ============================================= System diagnostics passed. Version 9.74 ready! [ --- Attach to Phone --- ] Connecting via UC-10 Universal Cable... Powering on the phone... [ --- Detach Phone --- ] All threads terminated. [ --- Attach to Phone --- ] Connecting via UC-10 Universal Cable... Powering on the phone... [ --- Detach Phone --- ] All threads terminated. ===================================== When i press detach phone after some hours of waiting it gives me the following answer: Bootstrap error: EAccessViolation What´s wrong? i tried with new cables and nothing helps. Thank you anyone if you could help. |
07-15-2006, 10:33 | #5 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: 127.0.0.1 Age: 79
Member: 545165 Status: Offline Thanks Meter: 578 | Quote:
well have you read manual ????? you just bought it and seem to condem it already with out reading any instructions/manula DUMMMMM? HEAD no its not CRAP it maybe the best s/e tool but impatient dummmm heads cant use it unless they read manual, then they sometimes become cruiser users so you have one of two options 1- stay a dummmmm, or 2 read manual | |
07-15-2006, 11:57 | #6 (permalink) | |
Member: 311040 Status: Offline Thanks Meter: 0 | Quote:
Nice words from you! I read the manual nothing helps.. Thew phone is fully charged. When i try to connect it it keeps on powering on and off. Nice tool | |
07-15-2006, 12:12 | #8 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: www.sw-box.com Age: 19
Member: 152573 Status: Offline Thanks Meter: 58 | Quote:
if u try to flash phone model with k750 cable, can attach the cable pic? coz outside got 2 kind of cable.. 1 need to attach 3 volt external battery to it and another dun need.. i am sure this is not cruiser problem Regards alex | |
07-15-2006, 12:15 | #9 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Palestine/Germany Age: 53
Member: 15593 Status: Offline Thanks Meter: 19 | Cruiser Hello vodapone, which phone you to unlock? If it is a W800i,W550i or else you need external Voltage(3-3,5 Volt). If self use Cruiser and it works without problem.Maybe you need testpoint? noko |
07-15-2006, 13:44 | #11 (permalink) | |
yes@vodapone and a nice start with your first post and heading 'is it a peac of crap or am i dummmm? no its no a peace of crap does that answer ?????? you have not even stated what phone you are using, it makes a difference, if you are using k750i have you connected external 3v power ???? maybe you will get a better answer if you give a clue what phone you are working with | |
07-16-2006, 10:09 | #13 (permalink) |
Freak Poster Join Date: Apr 2006 Location: NORWAY Age: 41
Member: 266315 Status: Offline Thanks Meter: 0 | I seem to remember having the same problem.....are you sure you have selected the correct cable? And what kind of cable is it? Drivers for the cable installed? (I had the TMS cable, and forgot to install drivers correctly) BR saphiens |
07-16-2006, 20:30 | #14 (permalink) |
No Life Poster Join Date: Sep 2003
Member: 38307 Status: Offline Thanks Meter: 66 | Which phone are you trying to work with? Some time you will have to remove battery and some time you will have to remove the cable. Try these combination and it will work. If you are using K750 cable (most of the time), you will need 3 Volt external power to help. |
Is it possible to use setool or cruiser flash with furious ? | gsmnice | FuriousGold | 4 | 12-07-2007 06:01 |
Is It Getting Out Of Control? | drgmobile | Off Topic Zone | 22 | 01-08-2007 19:24 |
Is it workin HWK with LG or not?! | Gozha | HWK | 31 | 09-20-2005 17:36 |
is it possible to insert irda or blutooth through software | GSM MIND | Motorola P2k | 1 | 07-29-2005 03:40 |
IS it the end of UFS? | after89 | UFS2 + UFS3-Tornadoflasher | 9 | 06-24-2005 21:12 |
