06-28-2006, 15:09 | #1 (permalink) |
Freak Poster Join Date: Dec 2005 Location: Oslo
Member: 211725 Status: Offline Thanks Meter: 9 | W300i wont flash. Dead Error flashing block at address: 0x44380000 Script error: Flash error [9.74.75] ...after trying to flash the ARM part with Cruiser. Battery ok, tried different cables. Stops at different place every time. Red cid49 Does anybody have an idea? Thanks |
07-20-2006, 12:25 | #5 (permalink) |
No Life Poster Join Date: May 2005 Age: 44
Member: 146630 Status: Offline Thanks Meter: 21 | only cruiser will help u downgread cruiser 1- v9.67 Manually selected W300i Connect phone 2-Unlock RSA 3-Direct unlock 4-Flash Raw_fs /check - customize after write Fs/ in customize options is only "any" 5-detach phone 6-Flash Main flash / after Full flash at the end cruiser will say "Unlock RSA"but no need to "UnlocK RSA"ur set is alive now. I have checked myself. |
08-28-2006, 20:52 | #7 (permalink) |
Freak Poster Join Date: Jan 2006 Location: Ethiopia
Member: 218713 Status: Offline Thanks Meter: 3 | flashing Problem W300i Hi All, I have flashed my W300i with 9.67 according to your instruction on post however i have got stacked on " All threads are terimated" with no error with my first connect phone. i need help how can i by pass this termination and flash my handset? Thanks in advance for your prompt reply. for now Ethio |
08-29-2006, 18:58 | #10 (permalink) |
Member: 218713 Status: Offline Thanks Meter: 3 | Sucess flashing w300i Dear All, I am very much happy that i sucesefuly flash W300i without any error using cruiser 9.67 and 9.74. The problem before was due to batter flat or not fully charged. Thanks for help Regards Ethio Mobile |
08-30-2006, 10:41 | #11 (permalink) |
Member: 218713 Status: Offline Thanks Meter: 3 | W300i Turn off after few minutes Dear All, My W300i not yet fully work even if flashed ok and all are seems working fine except turn off the phone after 1 or 2 minutes. And I am thinking because of many times flashing using 9V batter with crusier it might damaged the charging ic or don't know exactly but i come to conclude it is hardware problem. I therefore kinldy request you guys to help how to solve this turn off problem to give final solution to this w300i handset. i have made heating the board but can't give a solution. for now Ethio Mobile Solutions |
09-07-2006, 17:09 | #12 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2005 Location: In QBits and X86/ASM code Age: 41
Member: 110715 Status: Offline Sonork: - Thanks Meter: 234 | have the same problem.. flashing stops at any addresses 15%, 50%, 5% im goin to try with another battery and post results |
W900i - wont flash, wont read. | mobilextreme | SonyEricsson (USB-Smart) | 6 | 05-24-2006 15:48 |
C975 Wont Flash N Bootloader Wont Erase | hema | Motorola P2k | 1 | 03-23-2006 11:27 |
V3 Dead Wont Flash or anything !!!!!!help :-( | niinemae | Motorola P2k | 18 | 03-23-2006 01:46 |
T200 dead ... and flasher ... wont flash ?!?! | Brka | VLSI, Conexant, Skyworks and Old Models | 2 | 09-09-2003 19:43 |
