Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 04-12-2009, 13:58   #1 (permalink)
asif_ae's Avatar
Member: 334999
W350i cid red53 reset file not found for unlocking plz help urgent
i flash fone with red 53 files but problem is still
plz help urgent
thanks
Old 04-12-2009, 14:31   #2 (permalink)
Maiwand khan's Avatar
Member: 295886
Sonork: 100.1583369
flash with generic files from support or make restoration file
search for making rest file in forum'
u will find ur salution
always post operation log to get help quick
Old 04-12-2009, 14:42   #3 (permalink)
Member: 1002064
Sonork: 100.1594824
Use Se A1 Fast Java Unlocker
that will generate rest file in Phone
Put that file in suggested location of operation window.
repeat process and enjoy.
Old 04-12-2009, 14:56   #4 (permalink)
asif_ae's Avatar
Member: 334999
thanks this is log
  06:51:06  SE A1 Fast Java Unlocker v1.01 by Cruiser Team
  06:51:06  Initializing...
! 06:51:06  1. Please see the documentation first (tab 'Info')
! 06:51:06  2. Choose the phone model
! 06:51:06  3. Please connect the phone while holding its C button…
  06:51:16  Connecting via Generic EMP USB Flash Device (USB1)…
  06:51:16  Device driver version: 2.0.0.4
  06:51:16  Device driver date: 9-12-2007
  06:51:16  Connecting to the baseband CPU...
  06:51:16  Entering baseband CPU service mode...
  06:51:17  Detected chipset: PNX5230
  06:51:17  Boot mode: EROM
  06:51:17  EROM version: R4A018      prgCXC1250596_EROM_PNX5230_ALVA_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
  06:51:17  Sending loader...
  06:51:19  Starting up System...
  06:51:19  Starting up GDFS...
! 06:51:24  Rest-file not found, creating…
  06:51:24  Starting up FS...
! 06:51:32  1. Disconnect the cable from the phone
! 06:51:32  2. Turn the phone ON
! 06:51:32  3. Find the created rest-file in your phone file folders, with the following name:
! 06:51:32  - R11AA011_1205-7402_VODAFONE_JH.rest
! 06:51:32  4. Download the rest-file into the following folder (see documentation):
! 06:51:32  - C:\Documents and Settings\asif\Application Data\Cruiser Suite\SE A1 Fast Java Unlocker
brother this log
and give me link i have no much time for search
plz urgent
yhanks
Old 04-12-2009, 14:59   #5 (permalink)
asif_ae's Avatar
Member: 334999
itry these flash files but problem is still
W350i_1204-3117_Generic_R10AB002_Red53.a1sw
W350i_1204-3119_HongKong_R10AB002_Red53.a1fs
W350i_1204-3119_TMobileIntB_R11CA002_Red53.a1fs
W350i_1207-9752_TMobile_R11CA002_Red53.a1sw
W350i_1204-3119_VfeLive2_R11AA011_Red53.a1fs
W350i_1205-7402_Vodafone_R11AA011_Red53.a1sw
polz explain
thanks
Old 04-12-2009, 15:05   #6 (permalink)
Member: 1002064
Sonork: 100.1594824
Can u really read?
Now put accepted sim card in Phone power up Mobile
Find that file in Others Folder
Trasfer to ur Pc with Blue tooth or Usb cable
Put in
U have to create 2 folders manually
Simply try to Unlock again and Post result.
The Following User Says Thank You to Indus For This Useful Post:
Old 04-13-2009, 04:28   #7 (permalink)
asif_ae's Avatar
Member: 334999
thanks problem solve
Originally Posted by Indus View Post
Can u really read?
Put in
thanks great job ffffffffffffffffff
Old 04-13-2009, 07:09   #8 (permalink)
Member: 1002064
Sonork: 100.1594824
great
When u use cruiser never worry for any rest file since it can generate when rest is missing
so never flash any db20xx , pnx 5230 for rest files
Old 04-13-2009, 11:56   #9 (permalink)
ismabdi's Avatar
Member: 461554
i have some problem i need wrwe t can but the file i get from the phone
regards
Old 04-20-2009, 03:53   #10 (permalink)
Member: 1002064
Sonork: 100.1594824
regards
sory cant understand.
plz explain it lil
Old 04-20-2009, 14:25   #11 (permalink)
Member: 360127
to do this
hi, please modify the propier on windous options folder, see all documents. this folder normally is hidden. do it and all its ok.
k790 in flashing :Warning! K790RE53.UA file not found for this phone!: pakmobiles Universalbox 1 12-12-2009 11:10
Warning! W880RE53.UA file not found for this phone! kifah Universalbox 3 03-23-2009 05:25
error Prtoection card not found! ET TEAM plz help ezysuresh ET-BoX 6 01-15-2009 13:42
w710i UA FILE NOT FOUND FOR THIS PHONE dharmdev Universalbox 4 10-29-2007 16:25
Warning! K610RE52.UA file not found for this phone! PETERB Universalbox 1 06-17-2007 14:49
Page generated in 1.01188 seconds with 11 queries
