07-07-2006, 20:28 | #1 (permalink) |
Junior Member Join Date: Mar 2006
Member: 240124 Status: Offline Thanks Meter: 0 | W550 Customize failed ! when i Converting RED cid to Brown after Programing flash Error message is : "" Applet error: ERROR|EraseBlock| 04 FF FF FF 43 Error flashing block at address: 0x44070000 Script error: Flash error [9.71.75] "" Phone : W550 I have same problem in 2 phones ! PLEASE HELP ME !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!! |
07-07-2006, 20:31 | #2 (permalink) | |
Freak Poster Join Date: Jan 2006
Member: 221308 Status: Offline Thanks Meter: 0 | Quote:
07-07-2006, 20:44 | #3 (permalink) |
No Life Poster Join Date: Aug 2004 Location: US/DK/S
Member: 76964 Status: Offline Thanks Meter: 2 | I assume this error occurrs when you are changing the certificate? If that is the case, try the protected EROM procedure. http://forum.gsmhosting.com/vbb/show...23&postcount=6 |
07-07-2006, 22:04 | #5 (permalink) |
Member: 76964 Status: Offline Thanks Meter: 2 | You have good external power connected (3V DC, fresh batteries)? Your phone battery is fully charged? You have tried with a fully charged battery from another phone? You have tried lowering flash speed? You have tried with older version of Cruiser (9.68 or older)? The delay for the customisation is normal, it happens to all of us, just be patient. |
07-09-2006, 14:30 | #7 (permalink) |
Member: 240124 Status: Offline Thanks Meter: 0 | Hi Yes I Have Good external power 3V DC with Fully Charged Yes I tested It ( lower Speed ) & I use latest Version of cruiser & FW restore I flash very SE phones same W550 but I have 2 phones with same problem ! please Help me ! |
07-14-2006, 09:18 | #9 (permalink) |
Freak Poster Join Date: Jan 2005
Member: 108579 Status: Offline Thanks Meter: 3 | w550i problem Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Brown Reading secondary certificate... Secondary certificate CID: 36 Secondary certificate color: Brown GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. RSA protection is normal. Phone hardware initialized OK [ --- Write to GDFS --- ] Waiting for the phone to turn off... Should the communication hang, reinsert battery. |
07-14-2006, 09:23 | #10 (permalink) |
Member: 108579 Status: Offline Thanks Meter: 3 | [ --- Customize File System --- ] Waiting for the phone to turn off... Should the communication hang, reinsert battery this arrore and ri attech batt. so this arroer [ --- Customize File System --- ] Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Applet ID: 060206 1814 NPACXC125872_COMPACTPRODUCTION_ID_LOADER P3H Sending CS applet... Applet ID: 060118 0311 CRUCXC1327364_COMPACT_SEMC_CS_LOADER__V26 Initializing CS applet... Applet ID: 060118 0311 CRUCXC1327364_COMPACT_SEMC_CS_LOADER__V26 Baudrate = 921600Bd Starting up GDFS service... Starting up filesystem, please wait... and Failed! so plz halp me |
07-14-2006, 09:34 | #11 (permalink) | |
Junior Member Join Date: Jun 2006
Member: 298836 Status: Offline Thanks Meter: 0 | Quote:
Do this job (customize/finalize) with other tools.Working for me | |
07-14-2006, 18:25 | #12 (permalink) | |
Member: 76964 Status: Offline Thanks Meter: 2 | Quote:
I suggested that a couple of entries up...... http://forum.gsmhosting.com/vbb/show...08&postcount=3 | |
Customize Failed !!! | armeen | Cruiser Suite | 4 | 03-06-2008 17:34 |
new bee flash dead w550 ,configuration fail | mccm | Cruiser Suite | 4 | 01-25-2007 07:26 |
w550 customize is failure | chinaxp | Cruiser Suite | 0 | 05-13-2006 11:41 |
customization failed... | batazoli | Cruiser Suite | 4 | 04-21-2006 21:41 |
V802se Vodafone customize fail | deepcook_dalat | Cruiser Suite | 8 | 07-26-2005 04:33 |
