05-11-2006, 17:23 | #4 (permalink) |
No Life Poster Join Date: Nov 2004 Location: In a Ganja plant! Age: 38
Member: 91298 Status: Offline Thanks Meter: 6 | He never said he was using TP... come on now, he could have forgot to remove RSA, change colour etc. Give the guy a bit of help... br, Danny. |
05-11-2006, 17:44 | #6 (permalink) |
Member: 91298 Status: Offline Thanks Meter: 6 | Ok do the following. Download some flashes that you know are listed in the Customise menu, and EVEN MORE - make sure there is a restore file available for the files you are choosing. Now - connect phone, remove RSA, flash FS first, then flash MAIN FW part last - now RSA back to normal. now try customise phone... if it cusomises ok then its done. If not then I havnt a clue - we need full normal support, how can we flash a DB2010 phone or CID49 locked down phone - simply we cant if Customise doesnt work in RED with RSA ON, becuase I know it doesnt work with rsa off because I tried, not tried other way yet. br, Danny. |
05-11-2006, 18:19 | #7 (permalink) |
No Life Poster Join Date: Jul 2004 Location: 127.0.0.1 Age: 79
Member: 545165 Status: Offline Thanks Meter: 578 | ok now since update i have unlocked and reflashed 6 X w550i with no problems i think maybe when error at 42% it is connection probs or low battery ???? i messed with 2 X w550i and always managed to revive with reflash, |
05-11-2006, 19:28 | #8 (permalink) | |
Freak Poster Join Date: Apr 2005
Member: 140076 Status: Offline Thanks Meter: 4 | thanks mobileextreme and fonecellar very quick replies iam getting here but now suddenly iam getting this error Applet error: ERROR GETTING THE FIRST FLASHDEVICE The applet has intentionally turned the phone off! Script error: Unspecified [9.54.74] i have flashed many w550 with tp, 9.54 is giving me a bit of problem may i have to get use too now i cannot attach phone in normal in recovery49 i get this error anyone experinced can suggest comments or should i try with the tp method might not be able to give you more result here for 10 hours cos its closing time to late i need help forsure so post your ideas thanks regards c.g Quote:
w550 flashing error HDR block not accepted,error: 0E | neeraj1st | SETool2 | 4 | 01-23-2010 07:44 |
W550 flashing error use smartcard | mohit_kripalu01 | Universalbox | 3 | 07-20-2009 08:09 |
w550 flash error... | Amit Tank | Universalbox | 1 | 09-02-2007 13:32 |
w550 flashing error | ketan.d.chauhan | Universalbox | 1 | 06-20-2006 21:36 |
w550 flash error | melsoft | Universalbox | 3 | 06-13-2006 13:50 |
