Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 05-05-2006, 12:57   #1 (permalink)
Member: 32106
Thanks Meter: 11
w550 strange problem, please help
hello
i hade two peices of w550i which give me hard work. i had flash many w550i with out problem , but those give me headace. i want to change language to them , but after flashing succesfully i have only white screen, what i am doing wronge.
i had convert to broun ,flash ARM flash file and write raw fs flash file, with out making customize, i had made customize for the first one it is Dead now, for the second i did not make customize,only white screen. Now when i look in the back front of the phones i found out it is writting .Not Type Approved. pro type not for sale. and the emei number of the phone is writting., so what shell i do , is their any solution for that problem.
Old 05-06-2006, 18:36   #2 (permalink)
Member: 113283
Thanks Meter: 7
try changing back to red and finalize
make sure you are using the right cid
Old 05-08-2006, 17:16   #3 (permalink)
Member: 32106
Thanks Meter: 11
still same problem
Thanx for replay , but i still have the same problem.i can flash but when i want to finalize gdfs . it give me gdfs access terminated.
phone only have white screen. phone cid:49 - flash certificate A1_DB2010-49-red. otp cid:36. may be because phone cid:49 and otp cid:36 are diffirent. pleze help me.
Old 05-10-2006, 08:55   #4 (permalink)
Shoja's Avatar
Member: 170494
Thanks Meter: 9
Question hi
hallo,
i hove the same probleem.
can somebody help us.
http://forum.gsmhosting.com/vbb/show...34#post1740434
Old 05-10-2006, 09:13   #5 (permalink)
muppet's Avatar
Member: 42570
Thanks Meter: 11
If you have a Prototype phone you might be out of luck, Cruiser doesn't really support those 100%
Having said that, can you flash RawFS to the phone without problem? What about direct unlock?
Old 05-10-2006, 09:29   #6 (permalink)
Member: 32106
Thanks Meter: 11
lead please help.
thanx for replay, what about tornado with HWK can i flash this kind of phone with this box, any way protype phone i had it before with k300i and was able to flash them with out any problem, i hope that lead can help us i have many phones from s600i with white screen .
Old 05-10-2006, 10:44   #7 (permalink)
Member: 32106
Thanks Meter: 11
strange idea may beee
i have a similar phone and is working. if i back up full firmaware and flash it to the dead phone would it work, plezeee some body helpppp.
w550 earphone problem. please help me.... winika2006 Sony Ericsson Hardware Repair 0 12-11-2008 16:59
2 v200 with 2 strange problem.please help????????? GOODNESS Samsung Hardware Repair 3 07-23-2006 16:41
a,s 55 strange problem please help servtelgsm Siemens Hardware Repair Area 0 04-18-2004 16:28
Siemens SL55 with strange problem. Please HELP! doctormike E-Gold Based Phones 0 09-18-2003 20:47
Page generated in 0.17895 seconds with 10 queries
