06-22-2006, 07:28 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: IRAN(land of heros) Age: 44
Member: 115172 Status: Offline Thanks Meter: 212 | "W550i customization FAILS" Here's a W550i,flashing all the parts,unlocking,changing primary certificate,and other actions could be done properly but the only problematic part is when i want to do CUSTOMIZATION.All the time it fails to do that,What's the possible reason? |
06-22-2006, 10:39 | #5 (permalink) |
Member: 115172 Status: Offline Thanks Meter: 212 | this is the LOG: System diagnostics passed. Version 9.74 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 49 Phone color: Brown Flash certificate: A1_DB2010_49_BROWN Trying Brown CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Applet ID: 060206 1814 NPACXC125872_COMPACTPRODUCTION_ID_LOADER P3H Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 49 Sending applet... Applet ID: 060222 0202 CRUCXC1250166_1_SEMC_COMPACTPRODUCTION NAN Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Brown Reading secondary certificate... Secondary certificate CID: 36 Secondary certificate color: Brown GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. RSA protection is normal. Phone hardware initialized OK [ --- Customize File System --- ] Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Applet ID: 060206 1814 NPACXC125872_COMPACTPRODUCTION_ID_LOADER P3H Sending CS applet... Applet ID: 060118 0311 CRUCXC1327364_COMPACT_SEMC_CS_LOADER__V26 Initializing CS applet... Applet ID: 060118 0311 CRUCXC1327364_COMPACT_SEMC_CS_LOADER__V26 Baudrate = 921600Bd Starting up GDFS service... Starting up filesystem, please wait... And in the result window:Failed! |
06-22-2006, 13:38 | #8 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Romania Age: 42
Member: 188359 Status: Offline Thanks Meter: 9 | Remove RSA before attempt to customize FS I know it's already been said, but I think it's the reason why you're getting this error. Either this, or you're not flashing the right firmware into the phone. |
06-22-2006, 15:00 | #9 (permalink) |
Member: 115172 Status: Offline Thanks Meter: 212 | I converted the phone back to RED,then Unlocked RSA,reattach phone and tried to customize the phone but this time i get this message: "No response This may indicate damaged EROM area! Try repairing the phone via testpoint method. If it is an old phone, try converting it to brown first." PS:I'm using R4BA041 Brown CID 49,if it's related to firmware then which version is prior to this one?!!! |
06-25-2006, 20:33 | #11 (permalink) |
Freak Poster Join Date: May 2004 Age: 68
Member: 66340 Status: Offline Thanks Meter: 5 | I kill two W810I for failing on customerization ,anyone have experience to confirm "remove RSA before customerize" is proper solution. I am afraid to kill more phones on this small "CUSTOMERIZATION" process. |
iPhone 3.1.2 custom firmware (+screenshots) (+ custom for off 3G!) | nguyenhai2310 | iPhone 4 / iPhone 4S | 12 | 04-09-2011 01:26 |
A2 Initializating file system error !! Cant customize !! Help plz | Dany | Universalbox | 2 | 03-29-2010 12:35 |
Exclusive Z3X software for Samsung Z series Russian custom. and NEC 3G Russian custom | blang | Main Sales Section | 0 | 11-06-2007 22:47 |
ddp customize ppm | Boki_ | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-08-2002 22:16 |
