Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 01-18-2007, 14:26   #1 (permalink)
shoeb7's Avatar
Member: 196194
w550i when power on red light blinks
when click on attach phone here is the log
System diagnostics passed.
Version 10.08 ready!
[ --- Attach to Phone --- ]
Connecting via Fighter USB Cable...
Powering on the phone...
Baseband chip ID: 0x8040
Protocol version: 3.1
Baudrate = 460800Bd
Sony Ericsson phone detected.
Phone CID: 49
Phone color: Red
Flash certificate: A1_DB2010_49_RED
Trying Red CID49 flash applet...
Sending applet prologue...
Sending applet body...
Time spent entering bootstrap: 1s
Initializing phone hardware...
Applet ID: 060206 1814 NPACXC125872_COMPACTPRODUCTION_ID_LOADER P3H
Flash manufacturer: Intel
Flash ID: 0x890D
OTP Security Level: 1 (Retail)
OTP CID: 49
Sending applet...
Applet ID: 050909 1014 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2A
RSA protection state cannot be determined for this CID.
Phone hardware initialized OK
then 2 step in security rsa tab select cid49 and click replace certificate
[ --- Change Certificate Color --- ]
Preparing to program flash...
Baudrate = 921600Bd
Programming flash...
Phone automatically detached.
Applet error: ERROR|EraseBlock| 04 FF FF FF 43
Error flashing block at address: 0x44070000
Script error: Flash error [10.08.75]
kindly help...
__________________
Old 01-18-2007, 14:43   #2 (permalink)
Masud-GSM's Avatar
Member: 396988
Sonork: 100.1613227
use full charge battary extra power ...................
Old 01-18-2007, 14:45   #3 (permalink)
shoeb7's Avatar
Member: 196194
ok cheif i allready kept on charging. plz tell me my step was right or wrong.
regards
Old 01-18-2007, 15:34   #4 (permalink)
Mainboard's Avatar
Member: 25671
why you change ceritificate? you should read manual man.... use Remove RSA instead
so read manual for step by step solution and don't ask here
Old 01-18-2007, 15:53   #5 (permalink)
shoeb7's Avatar
Member: 196194
it was their in manual check this
This is usually the case with CID37 and later phones. Such phones manifest by a blinking charging LED when attempting to power them on.
It is therefore necessary to restore the flash certificate, to repair EROM or to flash EROM files prepared by us.
i did the sameas it was mention,could u plz sugesst me what to do for this red led blinking problem.
regards
Old 01-18-2007, 16:02   #6 (permalink)
shoeb7's Avatar
Member: 196194
see this i was going as per the manual, may be something wrong happen with me...u kindly suggest.
Old 01-18-2007, 16:11   #7 (permalink)
shoeb7's Avatar
Member: 196194
[ --- Unlock RSA --- ]
Baudrate = 921600Bd
Time: 00:00:01
Flash process done.
Please remove battery from the phone...
Remember to restore the main firmware in the end.
Unlocking RSA damages first 128/256KB of main FW in red CID49 phones.
Old 01-18-2007, 18:29   #8 (permalink)
mily2's Avatar
Member: 290638
now is very good
reconect cable and batery from phone and attach
now you can doit what you need (unlockin flashing etc)
after unlocking you must restore firmware
Old 01-18-2007, 18:36   #9 (permalink)
Masud-GSM's Avatar
Member: 396988
Sonork: 100.1613227
use Curiser Version 10.10 and CruiserFWRestore_v1.10_installer.exe
Old 01-18-2007, 18:58   #10 (permalink)
platforms's Avatar
Member: 83090
Sonork: 1626857
The steps are simple
Attach the phone---Unlock RSA-----Remove battery ---Reattch phone. Flash Main, Flash Rawfs---Detach phone --Remove battery---Reattach phone ,--Unlock RSA again---Remove battery and Reattach phone. Now you need to do the customisation. The last step should be Restoring firmware . Thats all.
Old 01-19-2007, 11:17   #11 (permalink)
shoeb7's Avatar
Member: 196194
thanks to all of you....i will post the result.
regards!
Sony erricsion W830i , when press power on button , red light blinking nakshatra SETool2 11 01-15-2011 09:06
w580 when power on red blink bablusoftware Universalbox 0 09-08-2009 16:18
Nokia6300 is fallen in water,after cleaning the when power on two light on the sides beneto Nokia Hardware & Hardware-Repair Area 1 02-05-2008 06:11
k700i when power on red light blink syed.n Sony Ericsson Hardware Repair Area 2 05-11-2007 20:31
K800 Red light Blinking when power on.. bestncheap MT-BOX 3 01-22-2007 13:12
Page generated in 0.57230 seconds with 12 queries
