Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 05-13-2009, 05:17   #1 (permalink)
Member: 388978
W580 no power, press power on the red light blinking!
I flash W850 two files (Fw, and LP) ok, but can't customize fs. the error displayed: "EROM upgrade works for R3A011 only". Any pros help me to solve this problem. thanks so much.
Old 05-13-2009, 05:23   #2 (permalink)
Member: 388978
or can't customize and errors message displayed: "Could not start GDFS service"
Old 05-13-2009, 05:27   #3 (permalink)
masterspargo's Avatar
Member: 227726
repair GDFS with test point otherwice no slution
Old 05-13-2009, 05:36   #4 (permalink)
NawabN Sahoo's Avatar
Member: 687312
Mate chick that it show its model W580 or K700 if it showed K700 it is GDFS problem, first try to flash it with SE A1 Java Unlocker(cruisersuite),So it will better to post the flashing logs andit is important for helping you better.
Old 05-13-2009, 05:39   #5 (permalink)
Member: 687312
Mate with SE UltimateUnlocker we can repair GDFS withouth TP and for repairing GDFS Suprem logs are needed.
Old 05-13-2009, 05:45   #6 (permalink)
Member: 388978
have you got a picture schematic testpoint of w580? pls post it for everyone. Thanks
Old 05-13-2009, 05:53   #7 (permalink)
Member: 388978
i've just run SE A1 Java Unlocker, pls see the logs file:
[code]
11:39:42 SE A1 Java Unlocker v1.11 by Cruiser Team
11:39:42 Initializing...
! 11:39:42 1. Choose the phone model
! 11:39:42 2. Select main firmware flash file (*.a1sw)
! 11:39:42 3. Select raw FS flash file (*.a1fs)
! 11:39:42 4. Please connect the phone while holding its C button…
11:40:26 Connecting via Generic EMP USB Flash Device (USB4)…
11:40:26 Device driver version: 2.2.0.2
11:40:26 Device driver date: 12-5-2008
11:40:26 Connecting to the baseband CPU...
11:40:26 Entering baseband CPU service mode...
11:40:26 Detected chipset: DB2020
11:40:26 Boot mode: ROM
11:40:26 Initializing flash files...
11:40:32 Sending loader...
11:40:33 Sending loader...
11:40:33 About to flash 46 MB of data…
11:46:24 Sending loader...
11:46:25 System starting up...
11:46:25 GDFS starting up...
[/code]
run to step GDFS starting up.... hang and nothing inform, stop here so long time
Old 05-13-2009, 05:54   #8 (permalink)
Member: 227726
register and get
http://www.gsmkerala.com/forum/showthread.php?t=2719
Old 05-13-2009, 05:59   #9 (permalink)
BENCHENA's Avatar
Member: 116657
it dosen't work with Ultimate Unlocker
w580 after repairing with UU
Old 05-13-2009, 06:00   #10 (permalink)
Member: 227726
w580 tp
W580 red ligh blink
with out logs
Old 05-13-2009, 06:38   #11 (permalink)
Member: 687312
[code]
[/code]
Mate your phone has GDFS problem and you can repair it with TP and withouth TP by SE UltimateUnlocker.
Old 05-13-2009, 06:41   #12 (permalink)
Member: 687312
[code]
[/code]
Mate your phone has GDFS problem you should repair it.You can repair it withouth TP with SE ULtimate Unlocker and needs Suprem logs and also Youcan repair it with TP withouth logs.
Old 05-13-2009, 07:01   #13 (permalink)
Member: 687312
Mate Repairng GDFS with SE ULtimateUnlocker working fine for me I have repaired many K800,W580,S500 and etc but it need suprem logs.If it dosnt need logs Im sure no one will try to repair GDFS with TP.It is safe and no risk of hardware damaging during TP.
I dont know why your GDFS repairing wasnt successfull maybe you havnt chosen a good GDFS backup file.you can see:
http://forum.gsmhosting.com/vbb/showthread.php?t=748189
Old 05-13-2009, 07:02   #14 (permalink)
Member: 687312
Sory for bad link W580 that shows:Model (from GDFS):K700 Successfully Repaired bySE Ultimate Unlocker
Old 05-14-2009, 08:23   #15 (permalink)
kcgckc2002's Avatar
Member: 42539
yeah...
also dont forget to change certificate to "red cid52/53" after successfull direct unlock or repair gdfs...
15:20:41 Selected phone: K530
15:20:41 Connecting via Cruiser UC-20 Cable (COM15)…
15:20:41 Device driver version: 2.4.6.0
15:20:41 Device driver date: 3-13-2008
15:20:43 Connecting to the baseband CPU...
15:20:43 Entering baseband CPU service mode...
15:20:43 Detected chipset: DB2020
15:20:43 Boot mode: ROM
15:20:44 Sending loader...
15:20:44 IMEI: 35350002122180
15:20:44 OTP CID: 51
15:20:44 Effective CID: 49
15:20:45 Restarting phone …
15:20:47 Sending loader...
15:20:49 Writing flash…
15:20:51 Turning off the phone...
15:20:53 Done.
.:Live a Happy Life:.
Sony erricsion W830i , when press power on button , red light blinking nakshatra SETool2 11 01-15-2011 09:06
SE W850i after press on switch only red light blinking gsm_bds SETool2 3 02-24-2010 06:12
Sony erricsion W830i , when press power on button , red light blinking nakshatra Universalbox 1 01-30-2010 12:40
W880 CID53, red light blinking after press power on lamborghini Sony Ericsson Hardware Repair Area 7 05-19-2009 12:04
w550i when power on red light blinks shoeb7 Cruiser Suite 10 01-19-2007 11:17
Page generated in 0.39538 seconds with 12 queries
