03-30-2009, 17:17 | #1 (permalink) |
No Life Poster Join Date: Aug 2005
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | w580i red blink credit deducted, now good Code: 20:07:09 SE Ultimate Unlocker v3.07 by Cruiser Team 20:07:09 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 20:07:09 Initializing... ! 20:07:09 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 20:07:09 2. Choose the phone model ! 20:07:09 3. Select the desired options ! 20:07:09 4. Please connect the phone either via USB while holding 2-5… ! 20:07:09 - or via a serial cable and double-click on it in the device list 20:08:11 Selected phone: W580 20:08:11 Connecting via Generic EMP USB Flash Device (USB1)… 20:08:11 Device driver version: 1.1.0.12 20:08:11 Device driver date: 9-25-2006 20:08:11 Connecting to the baseband CPU... 20:08:11 Entering baseband CPU service mode... 20:08:11 Detected chipset: DB2020 20:08:11 Boot mode: ROM 20:08:11 Sending loader... 20:08:12 IMEI: 35923501895487 20:08:12 OTP CID: 51 20:08:12 Effective CID: 52 20:08:14 Please reconnect the phone (disconnect, connect while holding 2-5) 20:08:23 Sending loader... 20:08:24 Communicating with server… ! 20:08:32 News: Your credit consumption policy: Level 1 (Novice) 20:08:32 Remainig credit (supreme): 1.20 20:08:36 Remainig credit (supreme): 0.87 20:08:39 Please reconnect the phone (disconnect, connect while holding 2-5) 20:08:54 Sending loader... E 20:10:01 Error: 0x07F5EFDA E 20:10:01 Error: 0x6C729765 E 20:10:01 Error: 0x8CDFAB78 E 20:10:01 Error: 0xFA7863EC E 20:10:01 Error: 0x780BA8B0 E 20:10:01 Error: 0x599D63C1 E 20:10:01 Error: 0x10BE36DC E 20:10:01 Error: 0x59AF7680 E 20:10:01 GDFS start-up problem E 20:10:01 Failed! ! 20:10:01 To report errors right-click this window |
03-30-2009, 17:41 | #2 (permalink) |
No Life Poster Join Date: Apr 2005 Location: between New Zealand - Canada Age: 42
Member: 135110 Status: Offline Thanks Meter: 302 | It will not be.. Perform GDFS reconstruction if battery is fully charged and cable not broken. |
The Following User Says Thank You to FilipLudvik For This Useful Post: |
03-30-2009, 20:24 | #3 (permalink) |
Member: 175945 Status: Offline Sonork: ziiyyaad Thanks Meter: 704 | Thanks.... Worked man!!! wrote gdfs w580i.gdfs via gdfs reconstruction... No need to flash phone again!!! Code: 23:19:17 SE Ultimate Unlocker v3.07 by Cruiser Team 23:19:17 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 23:19:17 Initializing... ! 23:19:17 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 23:19:17 2. Choose the phone model ! 23:19:17 3. Select the desired options ! 23:19:17 4. Please connect the phone either via USB while holding 2-5… ! 23:19:17 - or via a serial cable and double-click on it in the device list 23:20:49 Selected phone: W580 23:20:49 Connecting via Generic FTDI Cable (COM48)… 23:20:49 Device driver version: 2.0.0.0 23:20:49 Device driver date: 5-19-2006 23:20:49 Connecting to the baseband CPU... 23:21:03 Entering baseband CPU service mode... 23:21:03 Detected chipset: DB2020 23:21:03 Boot mode: ROM 23:21:03 Sending loader... 23:21:04 IMEI: 35923501895487 23:21:04 OTP CID: 51 23:21:04 Effective CID: 49 23:21:04 Restarting phone … 23:21:07 Sending loader... 23:21:20 Initializing GDFS access... 23:21:20 Writing GDFS… 23:21:41 Code NCK for relock: 4003096313395581 23:21:41 Code NSCK for relock: 9879559719840334 23:21:41 Code SPCK for relock: 7555795068925955 23:21:41 Code CCK for relock: 0652116245104398 23:21:41 Code PCK for relock: 5695447524215592 23:21:41 Code ESLCK for relock: 6476425320840334 23:21:41 Code NCK for unlock: 1444625026412606 23:21:41 Code NSCK for unlock: 5094277565490385 23:21:41 Code SPCK for unlock: 4189706733074333 23:21:41 Code CCK for unlock: 4019463931813560 23:21:41 Code PCK for unlock: 0347506509018345 23:21:41 Code ESLCK for unlock: 7687869490574372 23:21:41 To enter a code, type < * * < on the phone with SIM-card inserted 23:21:41 Turning off the phone... 23:21:43 Done. Y i didnt bought cruiser since long???????? |
03-31-2009, 01:25 | #5 (permalink) |
Freak Poster Join Date: Dec 2006 Location: location,location....
Member: 411486 Status: Offline Thanks Meter: 68 | my opinion is more easy to repair with tp.no credit needed and there easy testpoints for W580.i repaired 6 pieces with tp and i was very satisfied.now if you do not want to open the phone it's your choice. |
04-01-2009, 08:53 | #7 (permalink) | |
Member deceased !! Join Date: Jan 2008 Location: DreamSunlock Canada,TH,CN,BD Age: 36
Member: 670820 Status: Offline Sonork: 100.1583728 Thanks Meter: 1,348 | Quote:
set certificate to: select No certificate change.then connect phone you mast have supreme credit nazmul hossain | |
04-01-2009, 13:39 | #9 (permalink) |
Member: 135110 Status: Offline Thanks Meter: 302 | Why are you asking for a video how to work with Ultimate Unlocker? Have you ever started the Unlocker and tried to work with it? It cannot be more simple. just start the application, choose model of the phone, choose needed action and connect the phone (off course, supreme credits must be bought and the setting´s tab be filled up) |
04-01-2009, 23:13 | #11 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: karachi .. Age: 38
Member: 749969 Status: Offline Sonork: 100.1581886 Thanks Meter: 771 | Quote:
because when i try many times on tp2.. after this setool cant detect and show cid of phone. and gives error.. this means that i damaged flash ic many times and customer is not satisfied with me | |
04-01-2009, 23:15 | #12 (permalink) | |
04-02-2009, 08:28 | #13 (permalink) |
Member: 135110 Status: Offline Thanks Meter: 302 | Videos: http://cruisersuite.com/default.aspx...hinfo&aiid=395 Credits and prices: http://www.cruisersuite.com/default....y_csca_credits I recommend you to read homepage next time (www.cruisersuite.com) |
. . . : : : Dead W580i - Red Blinking Light : : : . . . | E_H | SETool2 | 8 | 11-27-2009 10:14 |
w580i red blink... | ZIYAAD STRYKER | Cruiser Suite | 11 | 04-03-2009 20:18 |
W580I RED BLINK fail in tp | OSLEC | Sony Ericsson | 3 | 12-22-2008 16:10 |
w580i red blink not connecting stage two | BaNgErS | Cruiser Suite | 5 | 11-10-2008 16:42 |
w580i red blinking repaired with dream | alfox | DreamBox | 0 | 04-14-2008 11:14 |
