11-12-2008, 13:31 | #1 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | w580i with red light blinking problem i try to connect it with se ultimate unlocker , and repair the gdfs but i get this error .. do i need any credit for this ? how much credit will be deducted when i do repar the gdfs ? and what is the best method to repair this problem ? today i have activated my cruiser -06 version .. please help.. thanks Code: 17:54:07 SE Ultimate Unlocker v3.04 by Cruiser Team 17:54:07 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 17:54:07 Initializing... ! 17:54:07 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 17:54:07 2. Choose the phone model ! 17:54:07 3. Select the desired options ! 17:54:07 4. Please connect the phone either via USB while holding 2-5… ! 17:54:07 - or via a serial cable and double-click on it in the device list 17:54:38 Selected phone: W580 17:54:38 Connecting via Generic EMP USB Flash Device (USB4)… 17:54:38 Device driver version: 2.1.0.0 17:54:38 Device driver date: 3-20-2008 17:54:39 Connecting to the baseband CPU... 17:54:39 Entering baseband CPU service mode... 17:54:39 Detected chipset: DB2020 17:54:39 Boot mode: ROM 17:54:39 Sending loader... 17:54:39 IMEI: 011271************ 17:54:39 OTP CID: 51 17:54:40 Effective CID: 52 17:54:41 Please reconnect the phone (disconnect, connect while holding 2-5) 17:55:10 Sending loader... 17:55:10 Communicating with server… 17:55:14 Remainig credit (supreme): 0.00 E 17:55:15 Error: 0x16D3BA97 E 17:55:15 Error: 0x834ACC0E E 17:55:15 Error: 0x51A411A0 E 17:55:15 Error: 0x78E56923 E 17:55:15 Error: 0x5C5AEBE3 E 17:55:15 Error: 0x3D35EAF1 E 17:55:15 Not enough credit E 17:55:15 Failed! ! 17:55:15 To report errors right-click this window |
11-12-2008, 13:43 | #2 (permalink) |
No Life Poster Join Date: Apr 2005 Location: between New Zealand - Canada Age: 42
Member: 135110 Status: Offline Thanks Meter: 302 | there is necessary to have Supreme credit. DB2020´s are not for free. |
The Following User Says Thank You to FilipLudvik For This Useful Post: |
11-12-2008, 20:08 | #3 (permalink) |
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | how much credit will be deducted when i do repair the gdfs ? and what is the best method to repair this problem , so that i dont have to waste my credit ..? |
11-13-2008, 19:51 | #7 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Indonesia Age: 47
Member: 551188 Status: Offline Sonork: 100.1580118 Thanks Meter: 59 | see the documentation in C:\Program Files\Cruiser Suite\Documentation put the pass in setting tab of UU. Do job see what happen......... |
11-14-2008, 21:30 | #8 (permalink) |
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | thanks i have repaired my w580i with SE Ultimate Unlocker by gdfs reconstruction , but now there is one more problem it says CONFIGURATION ERROR after the set is ON how to repair this ... please tell me the steps // thanks |
11-14-2008, 22:26 | #10 (permalink) |
No Life Poster Join Date: Jan 2006 Location: JAMAICA Age: 46
Member: 220143 Status: Offline Thanks Meter: 108 | Mine is comming up with same error I was planning to full flash my set. But I can find any flash files for CID 49 for this model. Can I change it to CID 52 or CID 53? How do I perform this? |
11-19-2008, 22:34 | #12 (permalink) |
Insane Poster Join Date: May 2005
Member: 147293 Status: Offline Thanks Meter: 1 | Dear Sir, I have the same problem. The redlight on the side of W580 is blinking. When I connect to the cruisersuite after pressing "C", the cruisersuite did not attach the phone. Is that any way to repair it with cruisersuite? It is CID53. Thank you. |
11-19-2008, 22:42 | #13 (permalink) | |
Member: 135110 Status: Offline Thanks Meter: 302 | Quote:
hmm, once again. we need to see the process log. anyway, Ultimate unlocker requires boot room mode, use 2 + 5. | |
11-20-2008, 04:20 | #14 (permalink) |
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | connect the usb cable while pressing 2+5 button on the phone at the same time .. then ultimate unlocker will recognise it and give u the details .. and u should have supreme credit to repair this problem .. any help needed let me know .. |
w580i only red light blinking | lakshmireddy | Cruiser Suite | 3 | 09-05-2009 05:06 |
w580i only red light blinking....... | karthickpabks | Sony Ericsson Hardware Repair | 1 | 08-01-2009 21:04 |
w580i only red light blink | karthickpabks | Sony Ericsson | 6 | 07-29-2009 06:00 |
W580i with red light blinking | nikill | Sony Ericsson Hardware Repair | 0 | 09-01-2008 06:30 |
k610i with red light blinking when turn on!!! | ruko | Cruiser Suite | 3 | 10-05-2007 16:15 |
