10-09-2007, 07:38 | #1 (permalink) |
Crazy Poster Join Date: Apr 2004 Age: 56
Member: 62725 Status: Offline Thanks Meter: 0 | W810i cid50 flash/unlock problem can someone please help? I have a w810i phone to unlock which is cid 50 i have unlocked the RSA but there is no restore file for the version of firmware so i have reflashed the phone several times but cannot find a version that has a restore file cpmpatible with it. The only one on the support site is R4EA031 red 50 but the FS File is R4ED001 and i havent got a restore file for this so the phone is dead, can anyone please help? |
10-09-2007, 08:55 | #2 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Mexico Age: 41
Member: 57203 Status: Offline Thanks Meter: 227 | if you dont have a compatible restore you only need flash main instead restore in your case you must make this Attach unlock RSA (log-) flash main flash FS(optional) Direct unlock (PLEASE DONT USE READ CODES) customize FS(only if you flashed FS) Shutdown FS or Turn off phone (necesary) enjoy |
10-09-2007, 09:31 | #4 (permalink) |
Freak Poster Join Date: Jan 2006 Location: Juarez "Most Violent City" Age: 49
Member: 221355 Status: Offline Thanks Meter: 25 | I have tried as Badillo says, but sometimes you might get an error on customizing with the w300 CID 50 or the W200 CID 50. And if you disconnect and flash the phone again it is still locked and you lose a credit. I have done the following: Attach phone Unlock RSA (log-) Restore firmwareAttach unlock RSA (log-) flash main Direct unlock Disconnect Hope it helps you out. |
10-09-2007, 19:11 | #5 (permalink) | |
Member: 57203 Status: Offline Thanks Meter: 227 | Quote:
when you get customize error turn off phone attach and only customize you dont need to flash again i hope to be usefull | |
10-09-2007, 19:43 | #6 (permalink) | |
Freak Poster Join Date: May 2006 Location: East Coast UK Age: 43
Member: 273918 Status: Offline Thanks Meter: 0 | Quote:
good luck regards, mrmcox | |
10-12-2007, 07:22 | #13 (permalink) |
Freak Poster Join Date: May 2006 Location: Cape Town, South Africa
Member: 281082 Status: Offline Thanks Meter: 5 | for some reason my cruiser can't find the phone when it's plugged into the dcu-60 cable... all the drivers for the phone are installed, but i've never sucessfully connected any phone via dcu-60 cable. the cable works, coz we use it on unibox! |
w810i cid 49 unlocking problem | koolmobile2006 | SETool2 | 8 | 05-26-2009 16:55 |
W810i Cid50 Red Blink Problem......... | dil_PAKISTANI | Universalbox | 3 | 11-23-2008 17:11 |
w810i cid 50 unlock probleme | raoul plus | Sony Ericsson | 2 | 09-28-2008 14:05 |
t 100 flashing/unlocking problem | krishnainfotec | Sony Ericsson Hardware Repair | 1 | 12-04-2004 11:18 |
K700i Prototype flash/unlock problem | dimon | Griffin | 0 | 11-18-2004 18:27 |
