09-12-2006, 15:29 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: Poland Age: 37
Member: 109224 Status: Offline Thanks Meter: 6 | W810i ... dead :( Code: [ --- Attach to Phone --- ] Connecting via UC-10 Universal Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 230400Bd Sony Ericsson phone detected. Phone CID: 49 Phone color: Red Flash certificate: A1_DB2010_49_RED Trying Red CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Applet ID: 060206 1814 NPACXC125872_COMPACTPRODUCTION_ID_LOADER P3H Flash manufacturer: ST Microelectronics Flash ID: 0x2019 OTP Security Level: 1 (Retail) OTP CID: 49 Sending applet... Applet ID: 060305 1000 104_DB2010_FLASHLOADER_P5G_CXC1326738 RSA protection state cannot be determined for this CID. Phone hardware initialized OK [ --- Flash Main Firmware --- ] Flash file: "DB2010_W810_EROMBrown49_signed_by_Brown49.erom4" Waiting for flash file to load... Preparing to program flash... Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 230400Bd Sending applet prologue... Sending applet body... Waiting for acknowledge... Code: No response This may indicate damaged EROM area! This seems pretty bad... Script error: Unspecified [9.70.41] |
09-13-2006, 08:33 | #3 (permalink) |
Member: 109224 Status: Offline Thanks Meter: 6 | I can't do that always .... No response This may indicate damaged EROM area! This seems pretty bad... Script error: Unspecified [9.70.41] On each version 9.60 9.70 9.74 |
09-13-2006, 12:17 | #5 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Nadi
Member: 210669 Status: Online Thanks Meter: 97 | @ danillo, please do as Crazy_ratata say, after that you will be able to flash the phone. before attaching the phone chose: Recovery CID49 and than attach and than got to the "security" tap and press Repair Certificate, and than you will be able to flsh the phone. i'm using a W810i and it had the same problem, olnly you have to write W810 i_CXC1250316_Generic_R4CK003_Red49.cw81sw and W810i_CXC1250324_Europe2_R4CK003_Brown49.cw81fs anf you phone will be back to alive Bet Regards, Nischal Ram |
09-13-2006, 12:40 | #7 (permalink) |
Member: 210669 Status: Online Thanks Meter: 97 | Dear danillo, did you try to change the baudrate? please change it, it does affact it when you try to , Repair, customize, and Shutdown FS. AND ALSO slow it down when flashing Best Regards, Nischal |
09-15-2006, 19:22 | #11 (permalink) | |
No Life Poster Join Date: May 2005 Location: Denmark Age: 42
Member: 146369 Status: Offline Thanks Meter: 119 | Quote:
but try this, this is a 100% working method: 1. Attach phone 2. Unlock RSA 3. Direct unlock 4. Restore Firmware 5. Flash Main & FS 6. Costumize FS | |
W810i dead after flash :( | taroussa | Cruiser Suite | 2 | 10-24-2008 01:05 |
E1 Totaly Dead.. :( :( Not enter Boot Mode.. | LoveLess | Motorola P2k | 9 | 12-03-2007 14:23 |
E1 Totaly Dead.. :( :( Not enter Boot Mode.. | LoveLess | Motorola Hardware Repair | 1 | 12-01-2007 10:17 |
W810i Problems :( | UnlockBR | SonyEricsson (USB-Smart) | 8 | 07-22-2006 08:32 |
C28 dead :( , i ned flash c28 ver6.1 for total flasher | cianyika | x1x to x45/x50 | 0 | 04-06-2001 15:32 |
