02-14-2008, 19:57 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Canada
Member: 219362 Status: Offline Thanks Meter: 31 | W810i shows "Charging error, Stop Charging" and "Charging Alien battery" after flash Customer brought me a CID 49 W810i to unlock and debrand. Everything went normally except now the battery will not charge on the unit. When you plug the charger in while the power is off, it shows the message "Charging Error, stop charging". When you plug the charger with the power on, it shows the message "Charging Alien battery". I have put another battery (BST-37) in the same phone, and the result is the same. I have put battery from this phone into another W810i and it will charge, so the problem is with the phone unit itself and not the battery. Could this have been caused by the debranding process (I have debranded many times before without problems)? Or does it seem hardware related. Please advise. Thanks in advance. |
02-15-2008, 06:02 | #2 (permalink) |
No Life Poster Join Date: Apr 2005 Location: between New Zealand - Canada Age: 42
Member: 135110 Status: Offline Thanks Meter: 302 | you did answer yourself probably looks like a hardware problem but try to flash full gdfs and then RAW FS, customize, direct unlock, ARM. If this doesn't solve the problem, it's really a hardware problem.. regards, Filip btw: was the phone before debranding alright? Did you try charging? |
02-20-2008, 20:31 | #3 (permalink) | ||
Member: 219362 Status: Offline Thanks Meter: 31 | Quote:
I just tried to write GDFS, but it does not complete. Quote:
Please advise. Thanks in advance. | ||
02-20-2008, 22:44 | #7 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Sweden Age: 46
Member: 374297 Status: Offline Thanks Meter: 51 | Try this GDFS via Flash Main Firmware C:\Program\Cruiser\Supplementary Files\Full_GDFS\W810\W810i_FullGDFS_version1.cw81s w C:\Program\Cruiser\Supplementary Files\Full_GDFS\W810\W810i_FullGDFS_version2.cw81s w |
02-20-2008, 22:46 | #8 (permalink) |
Member: 135110 Status: Offline Thanks Meter: 302 | it looks pretty bab. do you have USB smart because USB smart is using another access to GDFS. could be helpful for your phone regards, Filip |
02-20-2008, 23:18 | #9 (permalink) | |
I will try these - what are the steps, do I unlock RSA and flash one type and that's it, or are there more steps? | |
02-20-2008, 23:38 | #12 (permalink) |
Member: 135110 Status: Offline Thanks Meter: 302 | ARM part = MAIN FW so: I 1 - Connect phone 2 - unlock RSA 3 - flash version 2 of GDFS file 4 - flash FS 4a - maybe again unlock RSA 5 - customize FS 6 - MAIN FW BR |
02-21-2008, 00:52 | #13 (permalink) | ||
Here is my log: Quote:
K800i "Charging error, stop charging" | dariozz | Sony Ericsson Hardware Repair | 15 | 03-07-2012 10:37 |
N73 error sync phone plz plz plz help after flashing | smokerzonez | Nokia Base Band 5 ( BB-5 ) | 3 | 11-26-2008 21:19 |
V220 show bootloader and sw version only after flashing | J.F.M. | Ultima Box Light | 4 | 04-06-2007 13:28 |
Images and folders on 7210 after flash? | Fasterbaby | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 02-18-2003 21:40 |
NO power up and no local mode after flash with afd | unlockgod | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 01-08-2003 02:28 |
