05-14-2008, 09:17 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In Heavan
Member: 229987 Status: Offline Sonork: 100.1602834 Thanks Meter: 193 | (((((((((w850i Flashing Complete but..))))))))))))))) plz see log and tell me wat i do now?????????????????? System diagnostics passed. Version 13.11 ready! Do NOT connect the phone at this time! [ --- Attach to Phone --- ] Connecting via SEMC DCU-60... Connect the phone while holding its C button! USB connection established. Baseband chip ID: 0x9900 Protocol version: 3.1 Booting via EROM... Sony Ericsson phone detected. Phone CID: 52 Phone color: Red EROM version: R3A016 Trying CID52 recovery applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 0s Initializing phone hardware... Applet ID: 061220 1711 NPA4_CXC1329130_DB2020_... Flash manufacturer: Intel Flash ID: 0x897E OTP Security Level: 1 (Retail) OTP CID: 49 Phone CID: 52 Phone color: Red Sending applet... Applet ID: 061205 1523 HANCXC9876543210_DB2020... Sending applet... Applet ID: 061201 1314 HANCXC1329129_DB2020_FL... RSA protection state cannot be determined for this CID. Phone hardware initialized OK [ --- Flash Main Firmware --- ] Flash file: "W850i_CXC1250200_Generic_R1KG001_Red52.cw85sw " Waiting for flash file to load... Preparing to program flash... Programming flash... Time: 00:03:46 Flash process done. [ --- Flash Raw File System --- ] Flash file: "W850i_CXC1250489_MidEast_NorthAfrica_R1KG001_Red5 2.cw85fs" Waiting for flash file to load... Preparing to program flash... Programming flash... Time: 00:01:52 Flash process done. [ --- Customize File System --- ] Sending CS applet... Applet ID: 070410 1557 HANCXC1250562_DB2020_CS... Initializing CS applet... Starting up GDFS service... Starting up filesystem, please wait... Building customization... Customizing phone... Done. Writing CDA Article MS string... New value: CDA102568/10 Done. Writing CDA Version MS string... New value: R4A Done. Writing Default Article MS string... New value: cxc1250489 Done. Writing Default Version MS string... New value: R1KG001 Done. Writing langpack string... New value: EUROPE_1 Done. Writing country... New value: Generic Trade Done. [ --- Turn off Phone --- ] Turning off phone... Phone turned off. Phone automatically detached. |
05-14-2008, 10:31 | #2 (permalink) |
Super Moderator Join Date: Aug 2005 Location: UK.... Age: 57
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,783 | Was phone in this Condition Before you flashed it, if so, and you have tried a couple of Different Firmwares, Then Maybe you are looking at a hardware Issue... |
05-14-2008, 23:02 | #4 (permalink) |
Freak Poster Join Date: Dec 2007 Location: karachi
Member: 656238 Status: Offline Thanks Meter: 1 | i fixed many problems like this by flashing only fs. and custumize. may be your phone have ribbing fault. if its software problem just flash with latest fs file and custumize. it will be ok. |
05-16-2008, 09:27 | #5 (permalink) |
No Life Poster Join Date: Apr 2005 Location: between New Zealand - Canada Age: 42
Member: 135110 Status: Offline Thanks Meter: 302 | flash chip could be broken. try to use complete unlock procedure. it means, flash it again and do unlock.. if this does not help, change flash IC and do empty filling but for this procedure you have to use setool. |
05-16-2008, 12:53 | #6 (permalink) |
Member: 229987 Status: Offline Sonork: 100.1602834 Thanks Meter: 193 | Mates i m thankfull to all of you, ur best sugetions helpful for me and i have solved my problem by changing flex cable (Ribon) thanks again |
w850 flashing complete but no power gdfs field i try all file but same | lilong_lee | Universalbox | 4 | 01-12-2010 12:40 |
flashing e51 on usb.phone flashing complete but show phone startup failed | ravin j tejura | Universalbox | 1 | 12-14-2009 14:43 |
w850i Flashing Complete but white& restart | TUR@N ALAM | Cruiser Suite | 2 | 06-03-2009 03:22 |
SE w850i flashed sucessfully but again white screen, why?? | rundll-exe | SETool2 | 10 | 04-14-2009 03:35 |
w850i Flashing Complete but white& restart | TUR@N ALAM | Cruiser Suite | 2 | 05-17-2008 14:33 |
