Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 06-22-2006, 20:11   #1 (permalink)
GsmTracer's Avatar
Member: 279960
Thanks Meter: 56
W900 Can't Customize... With 9.74
[ --- Customize File System --- ]
Waiting for the phone to turn off...
Should the communication hang, reinsert battery.
Baudrate = 460800Bd
Sending applet prologue...
Sending applet body...
Applet ID: 050810 0923 NPA1CXC125871_PRODUCTION_ID_LOADER R2B
Sending CS applet...
Applet ID: 060115 0405 CRUCXC1327363_SEMC_CS_LOADER_1_V26
Initializing CS applet...
Starting up GDFS service...
Starting up filesystem, please wait...
Building customization...
Customizing phone...
Done.
Writing CDA Article MS string...
Getting stuck there...
tried many times... 2 phones tested both phones can't customize after flashing
used files..
W900i_CXC1250057_Generic_R5BC004_Red49.cw9sw
W900i_CXC1250058_EMEA6_R5BC004_Red49.cw9fs
Old 06-22-2006, 20:27   #2 (permalink)
Member: 16801
Thanks Meter: 3
you are rewrite primary certificat if you cen customize phone convert it to brown then flash with brown flash and than you can customize it....
Old 06-23-2006, 17:23   #3 (permalink)
GsmTracer's Avatar
Member: 279960
Thanks Meter: 56
i converted the phone to brown with tp... may be lead have phone.. he will check.. or any others have they'll found bug... b'coz now i got three phones same problem can't customize after flashing... (i depended other tools for customizing w900) other operations ok recovery 49 then i flashed erom.. then flashed gdfs.. main .. fs... crc's.. only costomising problem.. also tried lower baudrates...
i just noticed this bug... i can do it with other tools..
Old 06-23-2006, 18:29   #4 (permalink)
rjsoo7's Avatar
Member: 39014
Thanks Meter: 7
Error Customizing W900i
I have the same error too when cutomizing W900i
Lead please check ?
Thanks
Old 06-23-2006, 19:13   #5 (permalink)
*phone-company*'s Avatar
Member: 60001
Sonork: 100.106474
Thanks Meter: 151
hm, i just do a w900i cid 49...unlock and flash completly...no errors...maybe your used Files are damage???? Try other Firmwareversion
Old 06-23-2006, 20:33   #6 (permalink)
Member: 85833
@lead
I have same problems.
Mister Lead this reduces the reputation CRUISER.
Check,solve this problem and help please!
Old 06-24-2006, 23:42   #7 (permalink)
iyass's Avatar
Member: 23534
Thanks Meter: 17
my friend here is cruiser section !!!! so if you are using cruiser you have to face this problem ....
this problem happen with all ppl around the world !!!
see this thered
http://forum.gsmhosting.com/vbb/show...ghlight=string
this also :
i have same problem with 2 phone from 3
when i flashe the phone and it work after this its stick in please wait .
i try to unlock but after unlocking the phone is dead and i have to flashe it from begining again
we need new update to fix this problem
b r
iyass
Old 06-24-2006, 23:44   #8 (permalink)
iyass's Avatar
Member: 23534
Thanks Meter: 17
what frimware version you advice us to use
or tell us what you are using as frimware and the stap you did
b r
iyass
Old 06-25-2006, 10:54   #9 (permalink)
Member: 60001
Sonork: 100.106474
Thanks Meter: 151
hi,
i used R5BC005 with language EU2
- attach to phone
- remove rsa
- flash main (i used W900i CXC1250057_Generic_R5BC005_RED49)
- flash fs (i used W900i CXC1250058_Europe2_R5BC004_RED49)
- remove rsa
- customise phone
- restore rsa by clicking restore firmware button.
This works for me...
This was a customers phone....(He flash it with multiserver before but after a few days only whitescreen)
I flashed it again in the same way i just explaned at the beginning of this post. This phone worx fine
regards, Andree
Old 06-26-2006, 12:43   #10 (permalink)
iyass's Avatar
Member: 23534
Thanks Meter: 17
hi,
- attach to phone
- remove rsa
- remove rsa
- customise phone
regards, Andree
here is the result:
System diagnostics passed.
Version 9.72 ready!
[ --- Attach to Phone --- ]
Connecting via Fighter USB Cable...
Powering on the phone...
Baseband chip ID: 0x7100
Protocol version: 3.1
Baudrate = 460800Bd
Sony Ericsson phone detected.
Phone CID: 49
Phone color: Red
Flash certificate: A1_DB2000_49_RED
Trying Red CID49 flash applet...
Time spent entering bootstrap: 1s
Initializing phone hardware...
Flash manufacturer: Intel
Flash ID: 0x890D
OTP Security Level: 1 (Retail)
OTP CID: 49
Sending applet...
Applet ID: 050926 1419 NPA1CXC1250163_SEMC_FLASHLOADER R2A
RSA protection state cannot be determined for this CID.
Phone hardware initialized OK
[ --- Unlock RSA --- ]
Preparing to program flash...
Programming flash...
Time: 00:00:01
Flash process done.
Phone automatically detached.
Baudrate = 460800Bd
Phone CID: 49
Phone color: Red
Flash ID: 0x890D
OTP CID: 49
Sending applet...
[ --- Flash Main Firmware --- ]
Flash file: "W900i_CXC1250057_Generic_R5BC004_Red49.cw9sw"
Waiting for flash file to load...
Time: 00:10:38
Flash process done.
[ --- Flash Raw File System --- ]
Flash file: "W900i_CXC1250058_EMEA6_R5BC004_Red49.cw9fs"
Time: 00:07:11
Flash process done.
Time: 00:00:01
Flash process done.
Baudrate = 460800Bd
Phone CID: 49
Phone color: Red
Flash ID: 0x890D
OTP CID: 49
Sending applet...
Defeating RSA protection...
Baudrate = 460800Bd
Waiting for acknowledge...
Applet ID: 060514 1351 CRUCXCxxxxxx_S_LOADER_SEMC R1D
Initializing applet...
Baudrate = 460800Bd
Defeated!
Sending applet...
Applet ID: 060525 0202 CRUCXCxxxxxx_PRE_LOADER R1A
Done.
Failed!
[ --- Detach Phone --- ]
All threads terminated.
Baudrate = 460800Bd
Phone CID: 49
Phone color: Red
Flash ID: 0x890D
OTP CID: 49
Sending applet...
[ --- Restore Firmware --- ]
Baudrate = 460800Bd
Baudrate = 460800Bd
Identifying firmware...
Firmware ID: prgCXC1250057_GENERIC_SA
Firmware version: R5BC004
Defeated!
Sending applet...
Sending applet...
Applet ID: 060508 0204 CRUCXC1250164_SEMC_PRODUCTION NAND
Searching for FW restoral file...
File name: R5BC004_CXC1250057_GENERIC_SA.cw9sw
FW restoral file found.
RSA protection was set back to normal.
Time: 00:00:06
Flash process done.
after all this the phone restart alone with sim and work fine without sim
i hope you can help me here
b r
iyass
Old 06-26-2006, 14:16   #11 (permalink)
mehdi_naghous's Avatar
Member: 158513
Thanks Meter: 32
no need customize fs
u just flash by r5a
+989131154402
mansooreyan
Old 06-26-2006, 16:42   #12 (permalink)
Member: 60001
Sonork: 100.106474
Thanks Meter: 151
why you don`t use the newest version of cruiser??? @iYass...9.72 is old version try it with 9.74 and post result again...and maybe FS version you used is demaged??? Try this i wrote EU2 (only for testing)
when will cruiser 9.68 expire? becasue 9.74 has bugs hridaya Cruiser Suite 20 09-08-2006 09:23
@ LEAD .. 9.74 bugs .. pls reactivate 9.66 rjsoo7 Cruiser Suite 3 08-29-2006 11:44
W900 can't customize fs lwilson Cruiser Suite 1 06-25-2006 18:14
Unlocking SE K750i with cruiser-9.74 the following problem: adigem00 Cruiser Suite 1 06-24-2006 13:53
can i upgrade cruiser 9.23 to 9.74 Amit Tank Cruiser Suite 3 06-12-2006 14:44
Page generated in 0.29469 seconds with 9 queries
