03-03-2006, 21:46 | #2 (permalink) | |
Freak Poster Join Date: May 2005 Location: LONDON
Member: 144445 Status: Offline Thanks Meter: 0 | Quote:
the tp photo is in the manual. | |
03-03-2006, 23:20 | #3 (permalink) | |
No Life Poster Join Date: Sep 2003 Location: Belgium - SYRIA
Member: 39014 Status: Offline Thanks Meter: 7 | Tp W900 Quote:
make sure you solder the TP wire ti the right side of the Resisitor. and the second wire is well Grounded .. I prefer to use Switch. | |
03-04-2006, 05:27 | #4 (permalink) | |
03-04-2006, 08:37 | #5 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Timeless zone! Age: 35
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | Yes just use a wire soldered with a little pin and connect to tp and dont solder the resister becaz it can easilly damage the resister.....SO be care full....and connect them when cruiser says....Ok Br Muneeb Akhtar Raza |
03-07-2006, 21:16 | #6 (permalink) |
Freak Poster Join Date: Jan 2005
Member: 105787 Status: Offline Thanks Meter: 2 | AFTER I CONNECTED THE TESTPOINT, EVERYTHING LOOks ok but i got Applet error: ERROR GETTING THE FIRST FLASHDEVICE The applet has intentionally turned the phone off! doesnot support [9.22.30] help |
03-07-2006, 21:30 | #7 (permalink) | |
No Life Poster Join Date: Aug 2004 Location: Stockholm www.sumpansmobil.se Age: 57
Member: 79724 Status: Offline Thanks Meter: 15 | Quote:
Looks like you have damaged the Resisitor when you have done TP. Do a search in forum, and you will find salution on problem. BR Nizze | |
03-08-2006, 00:24 | #10 (permalink) | |
someone said can build a new bridge across it...but i am not sure and didn't test this solution. | |
03-10-2006, 00:31 | #12 (permalink) | |
Member: 39014 Status: Offline Thanks Meter: 7 | W900i TP Quote:
I already done more than 14 W900 units with this way and this is the most successfull metods. I know one should be very carefull , but since the TP is covered with a speacial glue then u have to scratch it !!! and this is dangerous too. | |
8310 just blinking after connect to MFI | j2000 | BlackBerry (RIM) | 9 | 09-18-2010 08:36 |
6120c shorted after connecting to shorted usb | tailang | Nokia Hardware & Hardware Repair | 0 | 06-04-2008 18:29 |
6288 phone dead after connecting to bb5box | bhart | BB5BOX | 29 | 09-26-2007 13:07 |
Know how: reading flash memory in SE K750i/W800i after connecting to Cruiser program. | Vishay | GSM Programming & Reverse Engineering | 7 | 03-09-2006 12:17 |
S40 shutoff after connecting to a "data cable" | pongwoo | NON Siemens Brand (ODM Phones) | 1 | 01-07-2003 16:56 |
