03-29-2006, 12:13 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: india
Member: 135945 Status: Offline Thanks Meter: 85 | W900i dead when tryin to Flash Main FW!pls see the error!!! While trying to flash a W900i phone using cruiser 9.22 the flashing stops at 25% and gives this below error!; Version 9.22 ready! Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 49 Phone color: Brown Flash certificate: A1_DB2000_49_BROWN Trying Brown CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 49 Sending applet... Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Brown Secondary certificate not found. GDFS configuration not found. OSE configuration not found. TestProgram configuration not found. Done. Phone hardware initialized OK Flash file: "W900i_CXC1250057_EU1_R4CA004_Brown49.cw9sw" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Programming flash... AND AT 25% IT GIVES ME THIS BELOW ERROR ----------------------------------------------------------------- Error flashing block at address: 0x20720000 Script error: Flash error [9.22.75] Pls help me find a soluton to fix this phone? looking for your suggestions? WBR ReyTech. |
03-29-2006, 14:28 | #2 (permalink) |
Member: 135945 Status: Offline Thanks Meter: 85 | @all whoever hve the same problem? follow the below mentioned link! http://forum.gsmhosting.com/vbb/showthread.php?t=215456 WBR ReyTech. |
03-30-2006, 06:59 | #3 (permalink) |
Crazy Poster Join Date: Jan 2006
Member: 225444 Status: Offline Thanks Meter: 0 | Still problem? Why not try following flash options: Extended config - ON VPPFLASH=12V - OFF Check erase - OFF Verify data - OFF No erase - OFF I see that trick from Lead suggestion: http://forum.gsmhosting.com/vbb/showthread.php?t=271027 |
BIG PROBLEM WHEN TRYIN TO UNLOCK K800i CID52 | SonyK800i | Seking Server | 17 | 10-02-2008 12:11 |
6230i when tryin to use camera "Memory Full pls delete memory" whereas it empty insid | ReyTech | Griffin | 6 | 06-17-2006 17:16 |
W900i dead when tryin to unlock thru SETOOL! how to repair now with crusier?? | ReyTech | Cruiser Suite | 15 | 04-03-2006 15:36 |
"NO BOOT CORE DETECTED" in A60 phns when tryin to flash win WINSWUP! How to revive?? | AE177 | E-Gold Based Phones | 8 | 02-20-2005 12:19 |
