Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 03-20-2005, 14:39   #1 (permalink)
s4sajii's Avatar
Member: 6919
Thanks Meter: 12
fighter shows S/n ?????????
Virus stuck my pc.. i had to format the Hdd...
now when i install the fighter again... its shows the s/n ???????
what happen...is my hardware is damaged...?
or some mistake in instalation..
helpppppppppppppppppppppp
br
Old 03-20-2005, 15:01   #2 (permalink)
jusluke's Avatar
Member: 26867
Thanks Meter: 3
br
uninstall usb drivers/ smart e-gate driver not detectd by your pc. its like running the soft without the dongle thats why your s/n is ?????????
Old 03-20-2005, 17:24   #3 (permalink)
muppet's Avatar
Member: 42570
Thanks Meter: 11
Download the Cruiser 3.20 installer.
Install everything into [i]C:\Program Files\Fighter[i]
When the install has finished, delete the cruiser.exe and copy into the folder the latest fighter.exe
Your fighter will now work fine.
Old 03-20-2005, 17:31   #4 (permalink)
Member: 39069
Sonork: 100.1606677
Thanks Meter: 190
http://forum.gsmhosting.com/vbb/showthread.php?t=166772
only this solution work fine for me. fighter or cruiser the same.
Old 03-20-2005, 20:46   #5 (permalink)
muppet's Avatar
Member: 42570
Thanks Meter: 11
Vansy: The new Cruiser installer automatically takes care of that fix, so if he uses the Cruiser installer he doesn't need to follow those steps.
Old 03-20-2005, 22:27   #6 (permalink)
Member: 39069
Sonork: 100.1606677
Thanks Meter: 190
Yes, I known but last Sunday I took 2 hours to intall for my friend's Cruiser to his PC never succesfull, untill I did this way working.That's why I still post here again.
Old 03-22-2005, 03:25   #7 (permalink)
s4sajii's Avatar
Member: 6919
Thanks Meter: 12
i did install the 3.20 installer.. but the prob still same..the s/n is ?????? ,,
i have changed the pc.. install new xp and install the 3.20 installer and copy the fighter exe in the folder and run it.. but still same ..
br
Old 03-22-2005, 03:36   #8 (permalink)
muppet's Avatar
Member: 42570
Thanks Meter: 11
Are you ticking the "SmartCard Base Components" option? This is the option that will fix the problem for you.
Old 03-22-2005, 03:47   #9 (permalink)
s4sajii's Avatar
Member: 6919
Thanks Meter: 12
All options are ticked only the "auto intall drivers (experimentel) " is not ticked.
br
Old 03-22-2005, 03:59   #10 (permalink)
muppet's Avatar
Member: 42570
Thanks Meter: 11
Well, try this and see if it helps: http://forum.gsmhosting.com/vbb/showthread.php?t=195576
Old 03-22-2005, 11:11   #11 (permalink)
CHAPRAN's Avatar
Member: 31906
Thanks Meter: 101
when we instal3.20 then pluge dongle in usb and instal...after instal then put cable to usb.....instal driver and look
LG-KH1800 SHOW (KOREAN PHONE) UNLOCKED DONE AGAIN! PIC'S and PROCEDURE INSIDE Ligalig LG 1 03-30-2010 07:40
n70 show network full but i try call show now network covarege???? gsm_khorshed Nokia Hardware & Hardware Repair 0 01-02-2008 11:53
T610 showing NO ACCESS after IMEI change by Fighter MC Harami Sony Ericsson Hardware Repair 1 09-03-2004 00:40
SphereGSM fighter and SE fighter 45PR1 Cruiser Suite 1 12-08-2003 17:23
Page generated in 0.20041 seconds with 9 queries
