Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 10-09-2006, 16:46   #1 (permalink)
laxxe's Avatar
Member: 4205
Thanks Meter: 9
White display after flashing K750i
After I've flashed a K750i, the display is all white - how come? It seems like the phone works (I can turn it on/off, hears sounds etc.).
Old 10-09-2006, 16:48   #2 (permalink)
Alkapone's Avatar
Member: 19265
Thanks Meter: 92
Flash higher version and all will be ok.
Old 10-09-2006, 16:50   #3 (permalink)
laxxe's Avatar
Member: 4205
Thanks Meter: 9
I tried with R1N035.
If I'm trying with R1CA021 I get this message:
Suspicious flash file detected!!!
Report the of*****ng flash file.
Error flashing block at address: 0x45420000
Script error: Flash error [10.00.75]
Old 10-09-2006, 16:53   #4 (permalink)
Alkapone's Avatar
Member: 19265
Thanks Meter: 92
hm, interesting, ok, try a bit lower, like R1BC002, should go. R1N is very old, so lcd driver dont suite.
Old 10-09-2006, 16:56   #5 (permalink)
m_dige's Avatar
Member: 22109
@laxxe
Which software software version did the phone have originally ?
The are different displays on the newest K750i's and therefore new drivers are needed. The new drivers are only included in the latest software versions.
Try to download the software again and reflash. Try and post results.
Best regards
Martin.
DK: Er du på MSN - så kan vi eventuelt snakkes online
Old 10-09-2006, 17:50   #6 (permalink)
laxxe's Avatar
Member: 4205
Thanks Meter: 9
I was pretty sure R1N035 was the original firmware, but R1BC002 fixed the problem - thanks.
my second thread after no response help plz s520x white display after flash check log observer123 Infinity-Box 2 09-10-2009 07:37
3650 white display after Flash / No local mode Skusi WD2 & APE (Symbian Phones) 5 12-23-2008 11:02
S5200 only white display after flash DonaldDuck69 VygisToolbox 1 12-12-2006 16:40
e800 to e808 white display after flashed nesteam TST Dongle 3 07-12-2005 21:31
Page generated in 0.23422 seconds with 8 queries
