09-05-2006, 20:00 | #1 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 437 | Why Mobile Start CHARGING?When connect Cable?? |
09-05-2006, 20:20 | #2 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 437 | Now i have a V600i to unlock how should i proceed??? ok i plug the cable and place battery i press on Attach phone.... And no response from the SOFTWARE.... But i noticed as soon as i connect the cable to the phone, it start charging... on the DISPLaY it write: System diagnostics passed. Version 9.74 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Powering on the phone... Powering on the phone... and on the second display (it is written in RED) Script error: No response to send-request [9.74.172] Script error: No response to send-request [9.74.172] Please can someone explain me how to go through!! |
09-05-2006, 20:43 | #3 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Use the search - This has been discussed many times. Charging instead of booting is a common problem and almost always indicates: 1. A problem with the cable you're using 2. A problem with the connectors on the bottom of the phone. I can tell you what it does not indicate, and that's that it's a problem with Cruiser. You have a hardware problem somewhere you need to fix. |
09-06-2006, 04:50 | #4 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 437 | i have tried this also... i click attach then i put the battery but still it start CHARGING by itself. Even if cruiser soft is not on when am pluging the cable to the mobile phone start charging! Why it is so? my ADAPTER is FT4in1.. But in the contrairy using the k750 Cable for model that goes to that cable it works even if it dispalys charging.. But for the t68Cable ... it does not read the mobile phone at all!! |
09-06-2006, 05:41 | #5 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 54
Member: 105625 Status: Offline Thanks Meter: 44 | Comon, read what he writes. I'll explain a little more: 1. The phone is dirty at the connector. Scratch the metal a little, and check that the pins on your cable is OK also. On such old phones, it's actually rare that that area is really clean. 2. The cable is not getting a good power supply. Try disconnecting other USB-devices, or change usb-port. 3. If it's still not working: a) Your phone is damaged. b) Your cable is damaged. 4. If problem is still not fixed you are lying. |
E370 turn on when connect cable | Ciux | UST Pro II | 1 | 08-08-2008 11:15 |
c65 turn off when connect cable | Satyam321 | S-Gold Based Phones | 6 | 03-25-2007 20:04 |
..::Mobile Start CHARGING.When connect Cable::.. | zakiyyboss | Cruiser Suite | 14 | 10-16-2006 02:13 |
Nokia 3610 show not charging when connect with charger | TechPhone | Nokia Hardware & Hardware Repair | 2 | 01-27-2004 20:29 |
Ericsson T20 Doesn't Start Charge When Battery Is Empty | ARC | Sony Ericsson Hardware Repair | 6 | 04-03-2002 04:00 |
