12-27-2006, 15:22 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: SALMAN SOFTWARE SADDAR RWP
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | z300 insert correct sim card Salman Ahmed |
The Following User Says Thank You to Y2ksalman For This Useful Post: |
12-27-2006, 16:50 | #4 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 25671 Status: Offline Thanks Meter: 719 | enter on phone <**< and check how many tries you have to enter unlock code, normally you should (5) but if you have 0, someone already tried enter wrong unlock codes... if you can, post picture of phone when you enter unlock menu by <**< |
12-29-2006, 14:34 | #5 (permalink) |
Member: 194511 Status: Offline Sonork: 03335548581 Thanks Meter: 1,607 | i can't post the picture when i put the codes it say not allowed [ --- Read Codes --- ] Calculating codes... Code NCK: 14681289 Code NSCK: 50788948 Code CCK: 10997337 Code SPCK: 40997928 PhoneLock: 0333 Codes calculated. Phone automatically detached. and here is this codes can any one solve this problem and i also think its barred fone Salman Ahmed |
12-30-2006, 23:52 | #8 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 36
Member: 137426 Status: Offline Thanks Meter: 50 | I have the same problem with SE Z300. Some other unlocker put in codes wrong more than 5 times. No it says not allowed when entering the right codes. Also flashing is not supported by cruiser. Maybe some one knows a solution to this problem... help will be appreciated. Also have problems with some SE J220. When entering the right codes, still says "insert correct simcard". All locks are open when checking <**<. |
12-31-2006, 16:24 | #9 (permalink) |
Insane Poster Join Date: Jul 2005 Location: Poznan Age: 42
Member: 159284 Status: Offline Thanks Meter: 4 | me too have this problem, got z300 and still saying insert correct sim card, cruiser read codes and it's only thing it can do, hwk cnt boot the phone : " certificate rejected" error. what can we do with this? anybody know how to reset the counter of codes input? |
01-09-2007, 17:16 | #11 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Where money is made Age: 33
Member: 390642 Status: Offline Sonork: 100.1573430 Thanks Meter: 2,476 | attch phone,go to locks tab and the clik on read codes...then you put a sim from an other operator and press in the phone **left key * and selec network then you put the nck code that u have un cruiser and that's all |
01-09-2007, 18:03 | #12 (permalink) | |
Freak Poster Join Date: Dec 2003
Member: 46116 Status: Offline Thanks Meter: 4 | Quote:
all will be ok.. bcs i faced same problem like after unlocking by code, when we remove battery fast it will be lock again, but after putting phone on till the light goes off all will be ok.. thanks.. | |
k320 insert correct sim card with test card | fofolpo | SETool2 | 6 | 01-28-2009 14:47 |
Z310a, whwn I put test sim card it shows insert correct sim card. | manistar | SETool2 | 6 | 01-21-2009 20:11 |
z300 insert correct sim | persianuser | SETool2 | 4 | 08-26-2008 12:30 |
z300 insert correct sim card | Y2ksalman | Cruiser Suite | 15 | 04-23-2007 09:23 |
SE Z300 insert correct sim card??? | sin_daemon | Sony Ericsson | 0 | 01-19-2007 16:25 |
