Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Junior Member Join Date: Jan 2010
Member: 1202182 Status: Offline Thanks: 1
| F305 Problem Hi I have problom to flash and unlock F305. my first attempt fail due to lack of credits. After that i the phone is dead. When i try to flash it again i get this message Code: 20:46:12 D - Flasher Unlocker for S1 v2.15 by Cruiser Team 20:46:12 Initierar... ! 20:46:12 1. Välj telefon modell ! 20:46:12 2. För flashning, välj flash filer och tillhörande val ! 20:46:12 3. Dubbelklicka på rätt enhet (seriell kabel) ! 20:46:12 - eller koppla in telefonen via USB medan du håller ner C-knappen 20:46:42 Ansluter via SEMC USB Flash Enhet (USB1)… 20:46:42 Enhetens drivrutin version: 2.2.0.5 20:46:42 Enhetens drivrutins datum: 4-1-2009 20:46:42 Kopplar till baseband CPU… 20:46:42 Startar baseband CPU service mode… 20:46:42 Telefon typ: F305 20:46:42 CDA info: 1214-3104 R11A 20:46:42 Telefon mjukvara: 1207-9123 R1DA015 20:46:42 IMEI: 35216203188094 20:46:42 Skickar loader... 20:46:46 Läser TA… 20:46:51 Meddelar sig med server… ! 20:46:54 Nyheter: Your credit consumption policy: Level 1 (Novice) 20:46:54 Remainig credit (supreme): 0.38 20:46:57 Kommer att programmera 33 MB av data… E 20:47:25 Fel: 0xF984FBBB E 20:47:25 Fel data: 0xF984FBBB - 00000004:1F000000 E 20:47:25 Fel: 0xA8A269DB E 20:47:25 Fel: 0xF984FBBB E 20:47:25 Fel data: 0xF984FBBB - 00000004:1F000000 E 20:47:25 Fel: 0x211D5295 E 20:47:25 Fel: 0x8FFD7AD1 E 20:47:25 Fel: 0xBEC4BBA1 E 20:47:25 Fel: 0xF509DBE3 E 20:47:25 Fel: 0xED8715EB E 20:47:25 Fel: 0x7C7E4156 E 20:47:25 Fel: 0x55D37C39 E 20:47:25 Fel: 0x568034E8 E 20:47:25 Fel: 0xCC214C8D E 20:47:25 Fel: 0x447A48D3 E 20:47:25 Fel: 0x07F5EFDA E 20:47:25 Frånkopplad kabel upptäckt E 20:47:25 Inkompatibel flash fil eller flash fel E 20:47:25 Misslyckades! ! 20:47:25 Koppla från batteri och kabel från telefon! ! 20:47:25 För att rapportera fel, högerklicka i detta fönster Is it possible to flash F305 with W395 flash file?? Last edited by Mainboard; 01-06-2010 at 22:37. Reason: disturbing font style |
| | #2 (permalink) |
| A english version Code: 21:01:11 D - Flasher Unlocker for S1 v2.15 by Cruiser Team 21:01:11 Initializing... ! 21:01:11 1. Choose the phone model ! 21:01:11 2. For flashing, select flash files and additional options ! 21:01:11 3. Double-click on the appropriate device (serial cable) ! 21:01:11 - or connect the phone via USB while holding its C button 21:02:59 Connecting via SEMC USB Flash Device (USB1)… 21:02:59 Device driver version: 2.2.0.5 21:02:59 Device driver date: 4-1-2009 21:02:59 Connecting to the baseband CPU... 21:02:59 Entering baseband CPU service mode... 21:02:59 Phone type: F305 21:02:59 CDA info: 1214-3104 R11A 21:02:59 Phone software: 1207-9123 R1DA015 21:02:59 IMEI: 35216203188094 21:02:59 Sending loader... 21:03:03 Reading TA… 21:03:08 Communicating with server… ! 21:03:11 News: Your credit consumption policy: Level 1 (Novice) 21:03:11 Remainig credit (supreme): 0.38 21:03:14 About to flash 33 MB of data… E 21:06:40 Error: 0xF984FBBB E 21:06:40 Error data: 0xF984FBBB - 00000004:1F000000 E 21:06:40 Error: 0xA8A269DB E 21:06:40 Error: 0xFD75DAA6 E 21:06:40 Error: 0xE09A592A E 21:06:40 Error: 0xF509DBE3 E 21:06:40 Error: 0xED8715EB E 21:06:40 Error: 0x7C7E4156 E 21:06:40 Error: 0x55D37C39 E 21:06:40 Error: 0x568034E8 E 21:06:40 Error: 0xCC214C8D E 21:06:40 Error: 0x447A48D3 E 21:06:40 Error: 0x07F5EFDA E 21:06:40 Cable disconnect detected E 21:06:40 Incompatible flash file or flashing error E 21:06:40 Failed! ! 21:06:40 Please disconnect battery and cable from the phone! ! 21:06:40 To report errors right-click this window |
| | #5 (permalink) |
| F305_LP_1207-9146_NORDIC_R1BA018_RED.s1fl F305_FW_1207-9123_GENERIC_R1BA018_RED.s1fl which Customizations could be suitable for this flashfile? Last edited by aa666; 01-07-2010 at 21:04. |
| | #6 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2008
Member: 670274 Status: Offline Thanks: 1
| dear aa666, i'm not sure which one is suitable, it seems that those are missing in our support area. I can just recommend to try if some of them works, or wait for next flashfile update. Regarding the incomplete flashing, i just recommend to verify that the battery is fully charged, because it seems like a unexpected response came from the phone during flashing GLaDOS |
| The Following User Says Thank You to GLaDOS For This Useful Post: |
| | #7 (permalink) |
| It seems to be the battery. I change it and then it works great. Thank you for your help. I also tryied to flash it with F395 files and that work great to, but i don´t have a swedish Customizations so i have to wait until i found a file. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| f305 problem | -==unloOok==- | Cruiser Suite | 0 | 07-21-2009 17:55 |
| f305 problem | julipsike | Universalbox | 0 | 07-12-2009 19:50 |
| SE F305 LOGS problems! help Urgent please!! | zepterpeter | Universalbox | 2 | 05-04-2009 13:08 |
| problem with unlock F305?? | Red-1Lotfi | SETool2 | 2 | 03-25-2009 01:20 |
| F305 always problem | zata222 | SETool2 | 1 | 02-15-2009 21:45 |
